Old 06-27-2017, 11:28 PM   #1
1987 34.5' Airstream 345
KC , Missouri
New Tag installed and back on the road
Last fall I had a tag bearing fail on the 345, destroying the hub, and leading to a new tag axle. It has been a journey....
I am still looking for a 10-bolt hub, in the mean time I have had adapters made to go from the 8-bolt hubs now available to the 10-bolt wheels, keeping the rig looking pretty much as it was.
The adapters are my current solution, I am wide open to others! Such as:
- Leads on a 10-bolt hub
- Anyone ever welded and re-machined a hub successfully?
- 8-bolt wheels of the same size and appearance on my Alcoa's?
All thoughts appreciated.
DHC1 is offline   Reply With Quote
Is this a factory installed solar panel ? I think it's factory installed and ... JacobMerridy Electrical - Systems, Generators, Batteries & Solar 1 01-14-2017 09:23 AM
installed new regulator and lines excellaf350 LP Gas, Piping, Tanks & Regulators 5 10-17-2013 03:21 PM
Back and forth, back and forth.....what 2 do??? WILDRTEXAS Upholstery, Blinds, Walls & Interior Finishes 19 11-30-2009 05:24 PM
tag axle drum and hub assembly str8strm Mechanics Corner - Engines, Transmission & More... 13 12-20-2007 02:26 PM
Awnings for Road Side and Back (16' CCD) RDM16CCD Awnings 4 05-27-2006 08:13 PM
