Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 07-03-2021, 10:19 PM   #1
1982 28' Airstream 280
Cooper Landing , Alaska
Question Need Switch for Step - '82 Excella Mh
Seeking source for OEM (or equal)step switch (located in door frame). If anyone knows of one, please advise.
As the OEM switch has probably long been unavailable, advise amp rating an improvised momentary pushbutton switch (normally on) would need to be...
The service manual does not state the fuse rating - nor the location of the inline fuse (inquired about the location in a separate thread)
Thanks for any help...
Fred Hudspeth (aka xengineer)
xengineer is offline   Reply With Quote
Old 07-04-2021, 03:30 AM   #2
Smartstream's Avatar
Port Angeles , Washington
Try this. https://www.elecdirect.com/cole-hers...nger-7-16-long.
Part #9269
Cheers, Dan
~ Margaret Thatcher ~
Old 07-05-2021, 02:37 AM   #3
Question
Thanks, Dan -
9269 is shown to be a normally open switch (i.e., when button not depressed, contacts are open).
The service manual for my 28' 82 Excella describes the switch operation, when door is opened, as completing circuit to open vacuum solenoid/ dump vacuum/drop step. Unless I have misinterpreted the manual, it appears I would need a normally closed switch, 9050-1 (i.e., when door is open/ button not depressed, switch contacts are closed, sending current to vac solenoid).
Advise if I am missing something....
Incidentally, the fuse, a 10 amp, is NOT in line. Upon further searching, I found that is on the chassis fuse block, top left/yellow wire. The fuse block is on the bulkhead/right of steering column - NOT easy to access!!
'Most appreciate your quick response to my post Saturday, 03Jul'21
Fred
Old 07-05-2021, 03:39 PM   #4
When I ordered the switch from Airstream years ago they sent the wrong switch so I guess they used both depending on the vacuum solenoid used. If I remember correctly vacuum holds the step in so pushing the button in would close the circuit activating the solenoid allowing vacuum to pull the step in.
If you look at the switch there should be a number next to the button. You also can pull the switch and with the engine running touch the wires together to see what the step does. And yes the fuse block is a real joy.
The switch can be a pain. If the door hinge is sloppy the switch can operate unexpectedly. Mine has a shim in the jamb to increase the button travel. I also suspect as the switch wears the point of operation vs. button travel may change.
My 345 uses the same switch on an electric step. When I bought a new motor drive it came with a magnetic switch. I haven't changed it yet but it might be an option depending on how sensitive it is. Good luck
Cheers, Dan
Old 07-12-2021, 02:45 AM   #5
Thanks much, Dan -
You are correct re "If I remember correctly vacuum holds the step in so pushing the button in would close the circuit activating the solenoid allowing vacuum to pull the step in...You also can pull the switch and with the engine running touch the wires together to see what the step does."
I did the latter and confirmed that when wired directly with the engine running, the step retracts. So - I will order the switch you advised in your first post.
'Most appreciate your guidance...
Fred
Old 07-12-2021, 02:55 AM   #6
Anytime, glad I could help.
Cheers, Dan
Location of Inline Fuse for Step Switch/1982 Excella Mh xengineer Classic Motorhomes 0 07-03-2021 10:03 PM
Need DeWinterizing Step by Step 51coke Winterizing, Storage, Carports & Covers 39 03-17-2021 11:04 AM
Step by Step 1959 Over59 1954 - 1959 Overlander 237 11-18-2015 04:41 PM
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 10:47 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 03:35 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
