Old 05-18-2020, 02:46 PM   #1
Huntington Beach , California
Need help: Leaf spring U bolt lengths on 82 310
Hello,
I'm rebuilding my rear end and don't have the old U bolts anymore. Can someone help me and measure the length of the U bolts that holds the leaf springs in place?
BTW, the leaf springs are 22-617HD? Can someone confirm?
thank you very much for your help!
Best regards
Clemens
clemensk is offline   Reply With Quote
Old 05-19-2020, 01:56 PM   #2
1982 31' Airstream 310
Henniker , New Hampshire
Mine appear to be 11.5 inches long
1982 310 motorhome 502
Henniker New Hampshire
chiefair is offline   Reply With Quote
Old 05-19-2020, 01:58 PM   #3
They do have 1.25” of thread below the nut so you could go a little shorter.
The width is 2-5/8”
Old 05-19-2020, 02:00 PM   #4
2-5/8 between them, not center to center.
Old 05-19-2020, 10:57 PM   #5
Thank you very much! That is a great help. I will order 11" because I suspect I need the extra thread to compress the springs. When I cut old U bolts the springs kind of jumped.
Old 05-30-2020, 10:34 AM   #6
1987 34.5' Airstream 345
Menomonee Falls , Wisconsin
Hey
They will need to know total length of ubolt
How thick it is
How wide it is measured between the threads
Do not order these u bolts from northern tool or some place like that you want a high grade u bolt look for a spring shop heavy truck repair shop it will be fine threaded the nut will be tall the washers will be a lot thicker than a hardware store washer they will be a dark gray color not shiney . You buy cheap you ll lose that axle when they RIP the threads or just brea km. Dj
davejay is offline   Reply With Quote
Need 1953 35" replacement leaf spring or ??? Streamer1492 Axles 5 07-18-2014 02:40 PM
leaf spring help.. on '59 Overlander stain Axles 6 06-28-2009 07:46 AM
Leaf spring suspension grommets Scott S Axles 10 06-02-2008 07:26 AM
Leaf Spring Assist for my TV VSP Raleigh Tow Vehicles 2 01-12-2007 03:14 AM
How many leaves in a leaf-spring axle??? 1959newbie Axles 20 08-05-2006 04:53 PM
