Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 05-24-2018, 03:24 PM   #1
KB6YAF's Avatar
2004 39' Land Yacht 390 XL 396
Shelton , Washington
My 310 stopped accepting Shore Power - HELP
I was camping last week, hooked up to shore power, running the a/c unit because of the heat, when all of the sudden, everything STOPPED. I grabbed my VOM and check the voltage, wiring, etc. All seemed good, but the 120vac going into my motor home was not powering it up. So, I fired up my Onan generator. That was all good. It provided 120vac and could also run the rear a/c unit, but after I turned the generator off, NO AC voltage at all.
Any one know what I should check, and HOW to do that before I take it to an electrical specialist?
If it is a simple fix, I might be able to do that, but I do need help evaluating why I don't get shore power coming into the motor home.
Thanks in advance.
Russell Decker, Olympia, WA
KB6YAF is offline   Reply With Quote
Old 05-24-2018, 04:12 PM   #2
2007 22' International CCD
You may have a transfer switch that allows you to use generator or shore power interchangeably and automatically. Sounds like the shore power set of contacts or the coil has failed, and the relay is just allowing generator power through (the default).
You will have to find this gadget, usually in a metal enclosure with the generator and shore power wiring coming in to it, and supply to the breaker panel going out of it. It's probably defective, and needs to be replaced...I doubt they are reparable..
Search around in the forums for more data--I don't have one in my trailer, so I'm shooting in the dark a little...
Rich, KE4GNK...
Old 05-24-2018, 04:51 PM   #3
1995 36' Classic 36
Ludington , Michigan
I had a similar issue last fall.
Bad connection in the transfer switch got hot and melted and shorted the control board.
That purple wire was the replacement for the burnt black wire. You can see the shorted control wire under it.
Real happy with the new switch
http://www.dyersonline.com/progressi...hoC1-0QAvD_BwE
Kota is offline   Reply With Quote
Old 05-24-2018, 05:10 PM   #4
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
On my '82 310, the transfer switch is located in the street side rear most outside compartment. It's a black box about 10" square mounted on the inside wall of the compartment. Good luck!
mayco is offline   Reply With Quote
Old 05-25-2018, 10:00 AM   #5
Magnet18's Avatar
Churubusco , Indiana
Of note, make sure ACs are off when transferring power or plugging in
Those things can draw a massive surge if they try to kick straight on to high
Check your breakers, but yea, sounds like a transfer switch
Mine is located in the same box as the extension cord
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 05-25-2018, 11:59 AM   #6
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
Here is a page that may be helpful, For the transfer between shore and generator, my 84 has a single DPDT relay like this:
Do not take life too seriously.
You will never get out of it alive.
WayneG is offline   Reply With Quote
Old 05-25-2018, 03:50 PM   #7
KB6YAF's Avatar
Well, it is fixed. I now have shore power into my 310. First, I want to thank all that replied to my dilema. You guys are awesome.
So, the fix was this...... I started off by determining if there was indeed ac voltage going into the automatic transfer switch in the rear of the 310. I pulled out my VOM, plugged in the shore power and noticed I was not getting ac voltage into the transfer switch, so I started back tracking. I followed the power cable back out of the transfer switch box to a small junction box where it married up to the cable spool. I took the wire nuts off of the wires and measured the voltage. Well, I had no voltage there either. So, from the spool plug to the junction box had to be the problem. I dialed up the ohms on my VOM, unplugged shore power, then started to test for continuety. The results were that the green (ground) wire was fine, the white (neutral) wire was fine, but the black (hot) wire had a break in the spool somewhere. I then disassembled the big yellow 30amp plug from the end of the cable spool and attached it to the short lead going directly into the transfer switch and plugged that into shore power via my 30 amp extention cable.....VOILA.....SUCCESS!!! Within a few seconds, the automatic transfer switch box came to life and transferred the full 120vac into my Airstream 310. Later, I will remove the cable spool and sell it. I have always been leery of those things.
Once again, thank you for all that offered help in this problem,
Russell, in Olympia, WA.
Old 05-26-2018, 12:33 PM   #8
mayco's Avatar
Good work!
Dometic refrigerator won’t run on shore power& water heater light on when on shore po fotoman1527 General Repair Forum 23 05-03-2022 05:29 PM
Fan stopped, now Dometic fridge stopped-what now? BWright2016 General Repair Forum 10 08-27-2017 12:14 PM
Shore power inlet stopped working? DerrickB Electrical - Systems, Generators, Batteries & Solar 2 10-08-2016 06:02 AM
4 Corners Unit is Now Accepting Applications flyfshr WBCCI Forum 70 04-15-2007 08:49 PM
