Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 03-19-2017, 04:28 PM   #61
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
I don't think those breakers have a good reputation. As I understand it, they auto reset once they cool down, which means if you have a fault on the circuit, it will happen again, and again......I suspect it would be preferable to have a proper reset button on each breaker so that you can isolate particular circuits if required.
Boom Sounds is offline   Reply With Quote
Old 03-20-2017, 02:41 AM   #62
Vernon , EU
I have never see the same breaker !
I think i change them for reset button .
Steph27 is offline   Reply With Quote
Old 03-20-2017, 03:34 AM   #63
I don't think we sell them or at least use them extensively in Europe
https://m.delcity.net/store/12V-Auto...98669.h_198846
Old 04-04-2017, 12:55 PM   #64
Vernon , EU
The decision is made, I change the plumbing, I build a new distribution, because I change the water heater of the place, I set up a system of heating and water heater combined. I changed the charger, and the fridge, I redo a simple network in 220 v, and I dismantle the generator that will no longer serve me.
Start work plumbing
Old 04-04-2017, 01:04 PM   #65
split window's Avatar
1992 25' Airstream 250
at Home , Niedersachsen
Hi Seph
I wish you many sucsess with your nice 290...
Hope for you, that you are soon on the road again.
best regards Peter
split window is offline   Reply With Quote
Old 04-04-2017, 01:32 PM   #66
Vernon , EU
Thank you
While I did the inside, I looked for a good address for the polishing, and I found not too far from my home, and I will start the mechanics.
Shock absorber, front spring, airbag, and think about how I will operate the air system.
I think I will make a system with the possibility of inflating directly from the cockpit, with pressure gauge for the front and rear circuit.
Old 04-04-2017, 02:01 PM   #67
The Airbags I fill and check like Tires.
For the front is a Manometer in front of the Engine...
It is ok for me and work.
If I need, I have a smal 12V Compressor to refill.
Peter
Old 04-05-2017, 01:04 AM   #68
For your shock absorbers, I can highly recommend Bilstein heavy duty shocks and Bilstein steering stabiliser
Old 04-08-2017, 01:53 PM   #69
Vernon , EU
Today i dismantle the bathroom.
Bur i have a small problem
I broke the system for fixing toilette
I wanted to disassemble the wooden cladding, I wanted to disassemble this fixing, and this broke
I dont understand for changing ??
How to change it?
Do you know if this is going off?
https://i58.servimg.com/u/f58/11/61/36/11/img_5617.jpg
https://i58.servimg.com/u/f58/11/61/36/11/img_5616.jpg
https://servimg.com/view/11613611/2183
https://servimg.com/view/11613611/2182
Old 04-08-2017, 06:06 PM   #70
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
How to change it?
you can buy a new part here:
screwed one: http://odmrv.com/catalog/index.php?m...roducts_id=662
glued one: http://odmrv.com/catalog/index.php?m...oducts_id=1200
some are screwed, most are glued. You need to be very careful to get the old one out if it is glued.
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 04-09-2017, 02:01 AM   #71
Vernon , EU
Cool, thanks for the link, I did not know this site.
I will look if it is glued or screwed!
Can you help me a little ??
I do not find on the site the joint that is between the toilet and this part?
Can you put me the link?
Even if I improve in language, I still struggle to succeed to understand everything ..
Old 04-09-2017, 09:00 AM   #72
Airstream Driver
1994 30' Excella
Images: 49
No other joint. The toilet flange either screws into the top of the tank or you glue it. But first you need to install a new piece of Plywood, which needs to be secured tightly around the edges. Then you screw or glue the new flange to the tank opening. Be very careful not to use too long screws when you fasten the flange to the new plywood or you will make holes in the top of the tank.
Make sure the mounting holes line up for the new toilet (red arrows)
AIR #13
Old 04-09-2017, 09:56 AM   #73
Vernon , EU
I am happy, it is a screw system, I understood the assembly, but I had a joint between the toilet and the black fixture.
Thank you for your help, I will order, hoping that it can deliver in france
Old 04-09-2017, 12:35 PM   #74
Airstream Driver
1994 30' Excella
Images: 49
you have a seal or a gasket between the toilet and the black ring. New toilets typically come with a new seal. if not you can order them cheaper than this :
http://odmrv.com/catalog/index.php?m...oducts_id=1074
like this one:
https://www.rvsupplyparts.com/catalo...3vp-10690.html
AIR #13
Old 04-09-2017, 12:42 PM   #75
Vernon , EU
I write a message, i hope it's possible to ship France
Old 04-10-2017, 10:20 AM   #76
Vernon , EU
He can ship in France, cool. I buy it
Tomorow morning, i start whit my friend the mechanic.
Old 05-03-2017, 11:00 AM   #77
Vernon , EU
Come on, the mechanics have begun: replacing the 4 stirrups, changing all the hoses, 4 absober shock, front air bag and spring front nine, front stabilizer bar, and steering amorto, as well as DA hoses leaking from Everywhere: While it is on hold, I take the opportunity to polish the rims 8)
Old 06-14-2017, 07:24 AM   #78
Vernon , EU
My RV comme back home
So i start the interior
Picture before after
Old 06-18-2017, 02:37 AM   #79
Halle Stephan
I see you still have a lot of work on your beautiful Airstream.
You do a good job and step by step it looks better and better.
I wish you continued success and that you will soon be back on the road with your car. You will experience how much joy it makes and have a smile on your face ...
It would be nice to welcome you at the next AS meeting in Germany.
This time it was 5 Airstream ... hope next time more
Best regards Peter
Old 06-19-2017, 03:13 AM   #80
Vernon , EU
thank you for the compliments. I take my time to do things right. I advanced on the work of the bathroom. I painted the inside of the closet, and I found a wood with an aluminum veneer that I like a lot, the bathroom guards are vintage spirit 80's but in modern and functional. I hope to be ready for the next European meeting next year
1985 290 window tracks Trvsrocker General Repair Forum 0 10-19-2016 01:33 PM
1985 290 Motorhome purchase? jmgraham Airstream Motorhome Forums 5 11-15-2014 09:03 PM
Exterior Woodgrain Vinyl '87 290 RobbieG01 Clearcoat, Exterior Paint & Trim 4 03-08-2005 12:21 PM
1989 290 325 345 370 Picture Brochure - Merry Xmas RichardT General Motorhome Topics 5 12-31-2004 06:00 PM
290 & 345 frisco kid Off Topic Forum 6 09-04-2004 12:29 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
