08-26-2015, 08:45 AM
#21
1984 31' Airstream310
Honokaa
, Hawaii
Originally Posted by bkahler
Care to share details of your LED installation?
Yes, please, what bulbs did you buy and where did you get them? Night driving is always sort of a roll of the dice for me.
08-26-2015, 10:59 AM
#22
1982 31' Airstream 310
Henniker
, New Hampshire
I expected questions on the headlights! Mine were horrible, the right low beam barely lit-a sickly yellow glow. I installed a Daniel Stern relay upgrade and the LED lights came from Amazon: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The light on low beam is probably comparable to what my sealed beams should have been. The high beams are like daylight! They were expensive, but I could not drive with the old setup.
I was surprised after I installed them that on low beam, only the top 1/3 of the lights are on. If you look at them you can see the LEDs are in three rows. They look odd during the day but at night the light fills all of the reflectors and looks normal from the front when you get back about 30 feet. Up close you can see that just the top strip is on. When driving the light is good on low beam, nice white light, not bright enough to be offensive to others.
The high beams are remarkably bright, lighting well of the shoulders of the road. I am very happy with them.
08-26-2015, 11:11 AM
#23
Henniker
, New Hampshire
Any idea what cam you're getting with the 502?
I ordered the motor referenced by Hans 34.5 in post #12. The cam specs can be seen in the link.
08-26-2015, 11:20 AM
#24
Henniker
, New Hampshire
I agonized over the choice between the HT and HO. GM lists the torque stats at different RPMs making it hard to compare the two. I finally plotted the GM data on one graph. The HO has more low RPM torque, then the HT is slightly higher from about 2500 - 3200 RPM, then the HO is dramatically better after that. Both should be considerably better than my 80s 454.
1982 310 motorhome 454
Henniker New Hampshire
1982 310 motorhome 502
08-26-2015, 11:26 AM
#25
Henniker
, New Hampshire
With the small differences in the torque curves and the HO at 450 hp vs 377 hp for the HT, I thought the HO was a better value. The HT does not come with an intake manifold or water pump. By the time I added those items in the HT was more money.
08-26-2015, 01:13 PM
#26
1966 24' Tradewind
2005 22' Safari
Bastrop
A dropped valve sure does create havoc ,
08-26-2015, 05:38 PM
#27
1987 34.5' Airstream 345
northern IL
I think the Quadrajet is not going to give you the fuel needed as it is.
Your going from what was it 280 hp to 450. You may know all this.
Keep a eye on the plug color. It's going to be a fun MO to drive.
08-26-2015, 06:03 PM
#28
Dazed and Confused
Hillsburgh
, Ontario
Airstream list the 454 at 230 hp stock. Given the age of the motor I'd be surprised if it was making 175hp just before she gave up the ghost.
That dropped valve must have made quite a racket for a couple of seconds.
Looking forward to seeing pics of the new 502 go in. Wow 450hp, I wonder what a 310 looks like with wheelie bars.
Cheers
Tony
09-01-2015, 09:15 AM
#29
Henniker
, New Hampshire
Progress has been slow this week. Stripped parts from the 454 and got most of them on the 502. Quadrajet does not fit. Waiting for parts to finish swapping over. I'm hoping everything comes soon so I can get the motor in this weekend.
09-01-2015, 12:23 PM
#30
Richmond
, Kentucky
Originally Posted by chiefair
Progress has been slow this week. Stripped parts from the 454 and got most of them on the 502. Quadrajet does not fit. Waiting for parts to finish swapping over. I'm hoping everything comes soon so I can get the motor in this weekend. Attachment 246984
That's interesting about the quadrajet. What is the fitment issue? You might look into using an Edelbrock carburetor. I plan on running an Edelbrock 1406 600 SCFM caruburetor. With a 502 you'd likely need a slightly larger one!
1975 24' Argosy Motor Home
09-02-2015, 12:54 PM
#31
Henniker
, New Hampshire
The Quadrajet bolt pattern is too narrow for the GM supplied intake. GM recommends a Holley 850 for this motor, so that's what I got. Should be painful at the pumps! (not that it wasn't before). I would love to have gone with fuel injection but this project has run up against financial reality.
Keith
09-02-2015, 01:31 PM
#32
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Despite all the hassle and financial set backs you went through, I share your excitement about having a new Motor. It will be well worth it !!
AIR #13
09-02-2015, 02:55 PM
#33
1995 36' Classic 36
Ludington
, Michigan
Keith
A properly tuned carb will be pretty close an EFI system. Especially some of the aftermarket stuff. Maybe even better.
09-02-2015, 04:02 PM
#34
northern IL
I think that new engine could be better on fuel you won't have to smash the right foot to the floor to get the MO moving. And going down the road it should sound Bad Azz.
09-02-2015, 04:46 PM
#35
Dazed and Confused
Hillsburgh
, Ontario
There is some truth to your reasoning, as I remember in the early 90's my girlfriends parents at the time were looking to buy her a car, a Ford Taurus with 4 cylinder. Just out of curiosity I remember asking the salesman what the difference was in MPG between the 2.3L four and the 3.8 six was. The four got 1mpg better in the city but the six got 3 better mpg on the highway.
However apples to oranges, an 850 double pumper on a 502 punching a 8.5' x 10.6' 15,000 lb hole in the atmosphere is going to cost you a lot more than the 650 double pumper 340 in my 69 Dart GTS convertible that I use to own. Yes it sounded Bad Azz too.
Cheers
Tony
09-05-2015, 07:47 PM
#36
Henniker
, New Hampshire
Preparing to install the 502.
Tight fit!
09-05-2015, 07:54 PM
#37
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Can't wait to hear how it runs; maybe born of out necessity but that is a serious performance improvement.
09-05-2015, 10:47 PM
#38
Mission
Really dumb question ...
why not a diesel?
7.3/7.4 or 8.2?
09-05-2015, 11:50 PM
#39
northern IL
I think it would be a lot more work. And you need to change the rear end gear ratio and the list goes on. You would need to keep it a long time for the diesel swap to pay off. I can see doing it but would I do it I hope not.
09-06-2015, 03:18 AM
#40
champaign
Beautiful!!! Is that the first 502 anybody has heard of being installed in a classic? Wish you the best of luck through the rest of the install!!
Mike
