Old 12-14-2019, 08:57 AM   #101
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Originally Posted by bkahler View Post
I suppose this is where it's going to start getting interesting. Thinking about it, the original airstream tracks are somewhat flexible in that they give slightly with the weight of the window. I would think there would be a downside that give in that it would be easier to cock the window while trying to open it. The ones I print are pretty much a solid mass so no real give to them...........
Keep me posted on what you find.
You appear to be spot on Brad. I made a simple 'stick gauge' the length of the distance between the top and bottom track, and the center is approx 1/16" shorter than the edges, ie the top/bottom rails bow together slightly. Your insert is solid so that 1/16" translates to the gap at the center of the rail being under the height of the window, causing the binding.
I work around for me was to sand the bottom of the insert until the gap was constant (between top and bottom insert), seems perfect now!
martin300662 is offline   Reply With Quote
Old 12-14-2019, 05:52 PM   #102
That's good to hear. It would be pretty difficult to 3D print a track in the same profile as the original track. 3D printing doesn't like to print large overhangs which is what the original track required. I tried different methods when I was coming up with the design but the success rate was really low in getting them to print properly.
1975 24' Argosy Motor Home
Old 12-15-2019, 05:38 AM   #103
Keen amature
1975 20' Argosy 20
Chestfield , Kent
What you have designed is perfect if each window is square Brad.
Unfortunately either due to a lack of quality of the OEM suppliers, coupled with Airstreams liberal use of a '3lb persuader' to make things fit during construction, means I doubt any classic motorhome window is truly 'square'.
It really was a 5 min customization of the insert for it to work perfectly. Just something others using them need to consider.
Old 12-15-2019, 06:06 AM   #104
Well we all know Airstream build quality is top notch so your windows must have been installed incorrectly by AS NE
Your solution to the problem is probably the only solution out there. It would be impossible to 3D print a strip that is not flat on the bottom. The basis of 3D printing is the print bed is perfectly flat.
The one thing that can be done is the strips can be made thicker should someone have a window that is out of spec the other way although I think just shimming with shim stock would be an easier approach in this case.
Thanks!
Old 12-15-2019, 09:08 AM   #105
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
The only thing square on my Airstream is the faceframe for my cabinetry......other than that, nothing is square on an Airstream.
Cheers
Sidekick Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 12-15-2019, 10:04 AM   #106
Cheers
Sidekick Tony
Old 06-11-2022, 11:47 AM   #107
Undereducated AS Newbie
1989 34.5' Airstream 345
Charlotte , North Carolina
How many slides would a company make for us?
Sent this PM to Brad, our current 3D printer guru:
Could you send me the window slider 3D files? I'm going to a Plastecs South Tech gathering-they offered free admission!! https://bityl.co/CeL8
Figure on carrying 1 of my slides & your files.
Goal is to hopefully connect with someone who could provide the answer to our prayers. Would you guesstimate the desired quantity of slides that could be ordered? I anticipate either 3D printing or injection molding providing our solution. Any ideas you would have for additional products to interest a supplier?
As promised I'm also posting here to try to get an objective number to drum up interest from a supplier.
Perhaps the best response for anybody interested would be to send me a PM with your individual need/potential order quantity. I'm planning on attending on the 15th, so your response by 6/14/22 before 7 PM would be appreciated.
wimpy is offline   Reply With Quote
Old 06-13-2022, 10:33 AM   #108
No PM was received.
Screen window insert for rear/sink window? MaineStreamer 2005 - 2010 Safari 0 08-02-2015 11:09 AM
Front Passenger Slider Window Handle JudgesArgosy Argosy Motorhomes 15 01-14-2013 08:28 AM
I3500 Slider Door Window Leak RoadJager Sprinter and B-van Forum 9 09-26-2012 06:42 AM
Side window insert mouth012006 Upholstery, Blinds, Walls & Interior Finishes 0 04-06-2010 07:34 PM
Drivers slider window. Inland RV Center, In Commercial Listings 0 10-18-2005 04:09 PM
