01-10-2017, 02:35 PM
#741
Richmond
, Kentucky
Sorry Mike, but you just gave me my laugh for the day
Fortunately, or unfortunately depending on your point of view, you're not the only one that makes what seems like a logical decision at the time that ends up coming back to haunt you
The good news is at least a replacement is available.
1975 24' Argosy Motor Home
01-10-2017, 04:01 PM
#742
Dazed and Confused
Hillsburgh
, Ontario
Originally Posted by bkahler
Mike, are you sure you have aluminum sheeting under the plywood? On the 86 345 I dismantled Airstream had used a galvanized steel sheet laid on top of the 1"x2" framework.
Brad, my 83 has aluminum sheeting in strips across the framing. The aluminum is clad in the same vinyl as what is on the walls. The sheets are 24" (from door to cockpit is 68+", so three sheets, each overlapping the next sheet) as opposed to the full one piece sheeting they put under your 345; then 5/8 blue coated marine ply on top.
AS siliconed the sheets together but the silicone hasn't held up; the only saving grace is that the sheet towards the back sits on top of the sheet toward the cockpit by an inch or so.
Second pic shows sheeting where I cut it and the vinyl cladding. The vinyl is on both sides.
@Mike
I know three people with a spare Keeler!
Cheers
Tony
01-10-2017, 06:10 PM
#743
Richmond
, Kentucky
Tony, that's the first that I've seen where the sheeting was the vinyl clad aluminum. The 86 345 had one long sheet of galvanized laid down and then one LONG sheet of OSB laid on top of it.
It's interesting that there are so many variations in how these things were built.
01-10-2017, 06:13 PM
#744
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim
, New York
I don't think any 2 were made the same. Regards, Bob
01-10-2017, 06:51 PM
#745
Dazed and Confused
Hillsburgh
, Ontario
Time to turn the tables....are you sure "one long sheet of OSB". A 28' or so piece of OSB from the cockpit (sorry I'm not politically correct) to the rear? I'm not saying it couldn't be done....but in 1986?
Cheers
Tony
01-11-2017, 05:57 AM
#746
Richmond
, Kentucky
Cheers
Tony
Tony, I was wrong about the long sheet of galvanized. It was actually a sheet made up of multiple panels that were seamed together.
However I'm pretty sure about the one piece OSB sheet. If you look at the video below check out what's in the back ground at the 2:03 mark.
I believe that is one long sheet of OSB for the floor. When I was dismantling the 345 I remember looking for seams in the OSB figuring it would be easier to rip the floor up at the seams. I couldn't find any seams but I did find a ton of nails holding the OSB to the frame along with screws
01-11-2017, 06:06 AM
#747
1982 31' Airstream 310
champaign
@Mike
Cheers
Tony
That is the same way mine is Tony n Brad. Now that I remember, it is vinyl clad sheets running crossway over the frame with seems. Mine is/was factory plywood subfloor, with joints, not OSB. Ive had only a small portion of it exposed but enough to run into a joint or two.
01-11-2017, 06:56 AM
#748
Richmond
, Kentucky
I'm pretty sure my 84 310 had plywood floors but I don't remember if it had galvanized or aluminum under the wood. All I know is trying to rip the OSB from the frame was a nightmare. I had to use a cutting torch and literally burn the heads of the nails and screws off (along with burning a lot of wood in the process!) before I could get the wood decking to lift up.
01-11-2017, 12:43 PM
#749
champaign
Drove up into the Poudre canyon this morning, Gods country no doubt! Just gorgeous, took an SUV up not the Airstream. Wasnt sure what the road conditions were going to be. Could have easily made it with the rig it turns out. This is the Colorado I fell in love with way back in 1980 when I was out here doing an internship with the City of Longmont.
The water soooo clear and clean!!!
I would sure learn how to fly fish if we move out here!
01-11-2017, 11:03 PM
#750
1986 34.5' Airstream 345
Alliance
, Ohio
Mike, I hope you realize your posts are making my four years to retirement seem like an eternity. As the guy in the office next to me used to say, 'I'm not getting old fast enough'.
01-12-2017, 06:19 AM
#751
north blenheim
, New York
Ditto, Lance. Regards, Bob
01-12-2017, 07:45 AM
#752
champaign
Trying to get a decent picture of the moon over the rig this morning. Just incredible!
01-13-2017, 09:20 PM
#753
champaign
We were going to start home tomorrow, leaving Fort Collins headed east through Kansas on US36. Took a look at the weather report and it looks like a serious and heavy ice storm is predicted in the entire eastern half of the state.....BUT, here is one of the coolest things about AirForums, our group of dedicated crazy Classic Motorhome owners, and our Classic Motorhome Get Togethers....I shoot an IM to Vycan, who lives in KS, to get the real scoop on the weather and potential travel hazards... he gets back to me in MINUTES and gives me the local info and recommends we wait it out here in CO for a few more days. THAT my brothers is just the coolest thing ever. What a fine group we have here and what an invaluable resource we are to each other here on the Forums....AND the annual get together gives us all a chance to meet face to face at least once a year and solidify those friendships. When I can tell my son "well I talked to my friend in Kansas and he said........." that's pretty dog gone awesome to me fellas!!
and THANK YOU Vycan for getting back so promptly on the weather, sure appreciate the heads up!
Mike n Lynn
staying put down in Lyons for a few days
01-14-2017, 04:29 PM
#754
champaign
01-14-2017, 10:06 PM
#755
1994 36' Classic 36 Diesel
Colorado Springs
Ice yesterday missed us and hit MO, lots of people out of power last night and this morning. Supposed to get more Ice tonight in Kansas, and Snow in MO. We'll see.
1994 36' Classic Diesel Pusher
01-15-2017, 05:12 AM
#756
champaign
Looks like we may be here a couple more days... thanks Vycan
01-16-2017, 02:57 AM
#757
Colorado Springs
Freezing rain is over tonight.
01-16-2017, 03:18 AM
#758
1995 36' Classic 36
Ludington
, Michigan
I'm in Boulder loading up a big U haul truck. Hitting the road to Michigan Wednesday for Michigan. Hoping for a two day shot at the weather. I'll be cruising i80.
01-16-2017, 05:43 AM
#759
champaign
Heyyyy Dave. Just down the road. Safe travels friend.
01-16-2017, 05:47 AM
#760
champaign
Thanks Vycan, We are going to stay at least one more day so looks like we will hit the road Tuesday. Depending on the reports. We'll be traveling US36. May stay here till Wed if need be.
Beautiful snow this morning.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
