10-23-2018, 01:42 PM
#1521
1982 31' Airstream 310
champaign
10-25-2018, 06:12 AM
#1522
Dazed and Confused
Hillsburgh
, Ontario
[QUOTE=mayco;2171552]Took off for one of our favorite local spots here in central Illinois, Fox Ridge State Park. Really a nice park with a couple lakes, trails, and one of the nicest state park campgrounds we have ever stayed at. Just over and hours drive from home so it's super handy for a quick getaway. They did an incredible job laying out the campsites here. Most every site is a winner......big sites with heavy vegetation and trees between each one. The park is rarely crowded especially this time of year. One of our very favorite short getaways...
Beautifull!
We've already had snow.[emoji19]
10-25-2018, 06:41 AM
#1523
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim
, New York
My view this morning ! Regards, Bob
10-25-2018, 08:10 AM
#1524
champaign
We are still hitting the 50s during the day, 30s at night. Really beautiful weather.
10-25-2018, 01:32 PM
#1525
Churubusco
, Indiana
Same here, 40s-50s and sunny during the day, some of my favorite weather for the year
(Except for when I run out of propane and wake up cold, )
1983 Airstream 310 Class A Motorhome
-Rob
10-27-2018, 11:11 AM
#1526
1989 34.5' Airstream 345
Ebro
, Fla Panhandle
Magnet18, If you are planning to stay aboard thru the winter and are plugged into elec. you should get one or two of these space heaters. You can keep comfortable down into the teens using these. For way less cost than using the propane furnace.
https://www.amazon.com/Lasko-755320-...s=lasko+heater
These coupled with plastic film covering the inside of your windows will make for an easier winter.
https://www.amazon.com/3M-Indoor-Win...70_&dpSrc=srch
This is a good choice for covering your windows.
Get those and some good warm house slippers and your good down into the teens.
Cheers Richard
10-27-2018, 12:28 PM
#1527
champaign
Richard, do you like the taller ceramic heaters more than the small, more compact ones? We have three of the short, 750/1500w ceramic heaters on board and use them whenever we are plugged in. They do a pretty good job but I wish the fan was a bit stronger. Again, I'm glad installed the additional shore power cord so we can run more electric heat. Wondering if there is advantages to the taller Lasko heaters?
Since we do a good deal of winter camping I ended up cutting reflectix for a good deal of our windows. I know the R value isn't much but it helps a great deal with keeping us warm. All you have to do is remove it from a window and you'll see how much cold it keeps out...and heat in the summer. Ive been leaving the reflectix in place year round for a few of our windows.
10-27-2018, 03:14 PM
#1528
north blenheim
, New York
And all this time I thought you were just being anti-social ! Regards, Bob
10-27-2018, 03:17 PM
#1529
north blenheim
, New York
Although I haven’t tried really cold weather yet, while I was in Cooperstown for the Columbus Day weekend, I used the floor heat both front and back and it worked awesome, current draw is only about 8 amps when they are both working. Regards, Bob
10-27-2018, 04:58 PM
#1530
champaign
That is so neat Bob. It will be interesting to see how much, if any, supplemental heat you will need in addition to the floor system. You're the only one Ive seen that installed floor heat so no one to compare to. Very cool, luxurious!
10-27-2018, 05:23 PM
#1531
Ebro
, Fla Panhandle
That floor radiant heat sounds nice Bob, does it heat the air space well?
Mike, I did have another brand shorter heater. It seemed to really draw a lot of amps for not that much heat. The very small footprint of the towers work well to live around and they do well at moving the warmth around.
With the Windows, for me it's as much about blocking the wind blowing up the drain vents as the cold coming thru the glass. So sealing the total window space from the interior works well for me. Probably using both would be optimal.
I leave the leave the plastic liners up all winter, even when driving somewhere.
Fortunately winters here in the Panhandle are more mild than those in northern Az at 5,000' elevation, so less of a battle.
Cheers Richard
10-28-2018, 07:28 AM
#1532
Churubusco
, Indiana
Thanks Richard, that one looks like a good deal, those digital control ones are nice, most cheap space heaters are impossible to set a specific temp and I'm either cold or cooking. (In college I wintered in a hundred year old house in west Lafayette, with some of the coldest temps on record, i think between the 30 guys in our house we tried every space heater on the market )
I've got a second 30 amp shore cord, and soon I'll be running new plugs off of it to make the most of it
I'm also considering:
This on the floor in front of the shower
https://www.amazon.com/gp/aw/d/B0013...KIKX0DER&psc=1
And two of these as well under the desk
https://www.amazon.com/Cozy-Products...jAL&ref=plSrch
And maybe even this IN the shower, but this is a bit of a stretch
https://www.amazon.com/gp/aw/d/B01H2...KIKX0DER&psc=1
What I'm really excited for, is I've already ordered this
https://www.tinywoodstove.com/produc...the-dwarf-3kw/
I've talked with multiple people who have installed it (or other stoves of similar size) in RVs that winter some pretty cold places, and I don't expect to be disappointed
It doesn't arrive until December, which is fine, I've got plenty to keep busy until then!
I also have enough 2" fireproof rockwool insulation to do the whole underside of the rv, i need to get around to installing that. Last spring I had carpet, and the new vinyl floor is WAY colder, about like standing outside barefoot.
Slippers are great, but I don't want to be in pain when I forget them, lol
-Rob
10-28-2018, 01:45 PM
#1533
Churubusco
, Indiana
For sense of scale on that stove, it's about 10 inches tall
-Rob
10-28-2018, 01:51 PM
#1534
champaign
Where are you thinking of locating the little wood stove?
10-28-2018, 02:25 PM
#1535
Churubusco
, Indiana
Re-purposing the volume currently occupied by the drivers side closet and drawers, it appears I have space to put a washer dryer combo in, and put the woodstove on top. The top of the washer dryer will be about bellybutton height on me, which will give enough space for a hearth and then the stove and still meet all the minimum clearances, and the chimney can go straight up and out
Check out my thread for pics
http://www.airforums.com/forums/f311...ml#post2167844
-Rob
10-28-2018, 03:32 PM
#1536
Dazed and Confused
Hillsburgh
, Ontario
Right above the main fuel tank refuelling hose.......your not thinking of do a 70's VW in cabin gasoline heater conversion are you?
Be careful.
Cheers
Sidekick Tony
10-28-2018, 03:53 PM
#1537
north blenheim
, New York
Sounds like trouble to me......a fire suppression system for sure, except on the inside.....Regards, Bob
10-28-2018, 04:14 PM
#1538
champaign
Scardy cats!
10-28-2018, 04:17 PM
#1539
Dazed and Confused
Hillsburgh
, Ontario
Halon gas.......just need to wake up and don gas masks.[emoji40]
10-28-2018, 05:14 PM
#1540
champaign
There is no doubt that wood burners put out some of the best heat there is. Ive heated small homes with a wood stove and loved it. I couldn't do it in my 310 though. Couldn't dedicate the space and wouldn't want to deal with the mess. Wood is messy going in and messy cleaning out. If we were more stationary in the use of the rig I might consider it. Plus I don't think I want more tasks to do in order to use the rig, like cutting, splitting, and finding storage to carry the wood. Sounds cool though.
