Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 12-01-2017, 05:38 PM   #1221
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Mike, I would mount it in the doghouse area around a bulkhead. It will be easier to wire it in to your existing AC wiring there, Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 12-01-2017, 05:39 PM   #1222
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Originally Posted by mayco View Post
Ordered the heater/pump this morning. We shall see. It says to install on the outflow side of the heater core. Not sure if it would make any difference though, inlet or outlet side.
https://www.amazon.com/Simate-Engine.../dp/B015U67F7E
I'm hoping there is enough room behind the hood to install it there, you know how tight that is Tony.
It shouldn't be a problem mounting it, as they are pretty small units, (had one as a block heater on my Toyota Tercel). Getting power to it wouldn't be that hard either, (from the outside receptacle to the grill).
May I also suggest a small ceramic heater with a fan, placed on the dash towards the windows to at least get them warm and dry before you set off.
Also using a Rain-X anti fog conditioner on the inside of the windshield would be inexpensive and easy to do.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 12-01-2017, 05:54 PM   #1223
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Cheers
Tony
Got the Rain x purchased along with some super dooper glass cleaner today. Did the cab side windows. Yes Tony we put a small ceramic heater up on the dash to get it started, sometimes two. Thanks for the tip on the defogger, wasn't aware of that product.
I was planning on just using the cord it comes with for power Bob, and plug it in to an extension cord. But you bring up an interesting idea. I could hard wire it into the coach's 120ac and activate it with a switch, hadn't even considered that idea. Hmmmmmm interesting idea. I think I like that.
mayco is offline   Reply With Quote
Old 12-01-2017, 08:08 PM   #1224
bobmiller1's Avatar
If you run it to the existing wiring, it will be one less thing to fool with in the winter....you are really going to like it once it's installed.....I suffered for about 7 years outside before I installed mine, Regards, Bob
Old 12-02-2017, 09:42 AM   #1225
mayco's Avatar
So when I go to install this inline heater I was thinking that I would use a couple soft jaw clamps on either side of the section of hose where it will live. This may be a stupid question but....are the heater hoses, before and after the heater core, full of coolant when the motor isn't running? I assume they are but just wondering. So I'll use clamps to isolate the small section of hose to install the pump. Anything else I should be thinking of?
I think there is a flow direction labeled on the pump. The way I understand it works is circulating the coolant through the motor and heater core but won't include the radiator due to the thermostat. Do you think it would really matter which side of the heater core it's installed on? I'm going to crawl under today and look at access to the hoses, I don't think I can squeeze it behind the grill.
Old 12-02-2017, 09:43 AM   #1226
mayco's Avatar
Old 12-02-2017, 10:41 AM   #1227
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
Mike....let me know when you will be out this way and we will work something out to get together. It will be good to see you two and catch up!
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 12-02-2017, 10:49 AM   #1228
mayco's Avatar
I will Steve, our schedule is still up in the air a bit. We know we'll be in Denver over Christmas though.
Old 12-02-2017, 11:53 AM   #1229
Mike,
The heater hoses should have coolant in them. The cooling system is pressurized to something like 15 psi but that doesn't mean the pressure is the same throughout the cooling system. But I would think even with a low pressure there would be some coolant in the lines.
If the heater manufacturer recommends it be placed in a certain location I'd tend to want to follow those directions if possible.
1975 24' Argosy Motor Home
Old 12-02-2017, 12:02 PM   #1230
mayco's Avatar
Yup, good advice Brad. After looking it over some more, I think if I take the grill off or swing it down, I can install the pump a few inches from the side of the overflow tank. taking note of the heat of the pump.
Old 12-02-2017, 12:30 PM   #1231
Sounds like a good plan.
Just an FYI on the front grille. The bolts holding the grille in place are a royal pain in the you know what to get out. Be prepared to bend your elbow the opposite way to get access
Once you do get them out I'd suggest replacing them with stainless equivalents. The ones I removed on Peanut were severely rusted and took forever to break free.
Oh yeah, you'll need 7/16" wrenches.
Old 12-02-2017, 12:38 PM   #1232
Add HEAVY to Brad's correct observations above!
Old 12-02-2017, 12:41 PM   #1233
mayco's Avatar
Yup Brad Ive been there done that. I had to take mine apart all the way back to access the harmonic balancer so Ive been in there deep.
Old 12-03-2017, 06:34 AM   #1234
Ahh, so you already know about the pain involved
The idea of a removeable grille is great, the implementation by Airstream does leave a lot to be desired.
Old 12-08-2017, 09:00 AM   #1235
mayco's Avatar
Alright fellas, headed west this morning. Please...........
BLESS OUR BEAST!
Old 12-08-2017, 09:52 AM   #1236
1986 34.5' Airstream 345
Alliance , Ohio
Safe travels for you, Lynn and Wriggly. Enjoy and keep us posted.
mehes is offline   Reply With Quote
Old 12-08-2017, 10:34 AM   #1237
BLESS OUR BEAST!
Yeah....I'm jealous
Enjoy your trip!
Old 12-08-2017, 03:53 PM   #1238
mayco's Avatar
First stop, Longbranch State Park near Macon MO. We love this park this time of year.
No one here but us chickens, we have seen a good deal of wild life here (other than my lovely bride)
ID:	300587Click image for larger version
ID:	300588Click image for larger version
ID:	300589Click image for larger version
Weather is good, in the 30s.
Old 12-08-2017, 04:45 PM   #1239
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Safe travels to you and Lynn have a great holiday
shepherd57 is offline   Reply With Quote
Old 12-08-2017, 05:15 PM   #1240
mayco's Avatar
To you and Ann also John. We are off to a late start, hoped to be on the road by the first but stuff got in the way. You keep it between the lines and hope to see you in a few weeks!
1982 turbo diesel 310 :: 2013 Airstream turbo diesel 310 mayco Airstream Registry Discussions 1 07-28-2015 12:58 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
