Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 08-16-2017, 04:04 PM   #1081
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
ID:	292415Click image for larger version
ID:	292416Click image for larger version
Turned out nice. Its really going to change our kitchen storage. No stain just poly, it's a little lighter than the door above but it will honey over time. I stripped and refinished the other cabinet doors a couple years ago, as you can see they already have that nice honey tone. Put a push latch on it. Held it as far as I could to the left so cutting boards cookie sheets can slide in on the right. The slide unit seems well made, got it from Lowes online.
mayco is offline   Reply With Quote
Old 08-17-2017, 12:47 PM   #1082
gaiaenviro's Avatar
1987 32.5' Airstream 325
dripping springs , Texas
Originally Posted by mayco View Post
Do any of you want this ice maker/freezer? Or can you think of any good ideas for repurposing? Freezer works great, have no idea about the icemaker. Otherwise it's going to recycle. Just thought I'd ask .....
I'm interested in the ice maker if it has not yet founded a home...
-Bill
gaiaenviro is offline   Reply With Quote
Old 08-17-2017, 02:54 PM   #1083
mayco's Avatar
It's yours Bill if you want it. I can get you dimensions if you want to estimate shipping costs. I don't have a scale to weigh it but I'm guessing around 40lbs or so.
Like I had said the freezer works great but I never hooked up the ice maker so I don't know about it. I would imagine you can get a replacement ice maker but not for sure.
Old 08-18-2017, 10:25 PM   #1084
gaiaenviro's Avatar
Perfect! Whenever you have time shoot me the measurements and I'll figure out the shipping. Is there a company that is easier for you? Or is something like a ups pickup good? Thanks!
-Bill
Old 08-19-2017, 04:51 AM   #1085
mayco's Avatar
14w x 24h x 16d. UPS is a as good as anything here Bill. Let me know timing and I'll box it up somehow. Ive got some pretty large cardboard sheets I can probably use.
Mike
Old 08-19-2017, 09:43 AM   #1086
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Mike
I have one too, if you need a spare Bob.
Cheers Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 08-26-2017, 10:00 AM   #1087
mayco's Avatar
Ok Diesel dudes, how often do you drain the water from the Racor fuel/water separator?
When you do, do you take the top off and pour fuel in to prevent air in the line? Is there a visual clue, when looking at the clear bowl, that indicates water? When I look at mine I'm not really sure what I'm looking for as far as water is concerned. Ive seen written instructions to drain it at every fill up, is that a good practice?
Thanks fellas!
Mike
Old 08-26-2017, 06:49 PM   #1088
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Mike I rarely drain water in the coach filters. If you buy fuel from high volume stations it is not much of a problem. Maybe high humidity areas like Florida may be a problem but the key is your fuel source.
When I was living on my boat I saw water but some of the old fuel docks were not in the best shape. When your fuel looks like coffee with cream, you are going to be draining your tank.
When you look at the bowl you can see a line with the water on the bottom and fuel floating on top. Sometime you have to look pretty close because all the crap in the fuel winds up in the bowl and it just looks like a bunch of yucky stuff. If you do drain a small amount from the bottom of the bowl normally you won't have a problem, maybe a rough idle for a few seconds. If the entire bowl is full of water you probably will have to refill the filter with fuel.
Cheers, Dan
~ Margaret Thatcher ~
Smartstream is online now   Reply With Quote
Old 08-26-2017, 07:40 PM   #1089
Dazed and Confused
Isuzusweet's Avatar
Mike, I'm with Dan on this one.
Back in the day of our beasts, not many people drove diesels; maybe a couple guys had diesel pick ups (not many), a few Merc 240/300 TD's and VW Rabbits. Diesel was smelly, icky, oily stuff that no one wanted to be around; so unless you filled up at a busy truck stop the chances of you getting water in the fuel at your local Mom and Pop gas station, (if it sold diesel at all), was pretty good.
Now days the refineries are better, the fuel is being used at a high rate, so it's almost always new stock and the new modern diesel is formulated with additives, with moisture in mind. Not to mention that I do used a good fuel conditioner.
Have I checked my water separator, yes (I don't have the racor like you do), but seriously, not very often.
Cheers
Tony
Old 08-27-2017, 01:13 AM   #1090
Tony don't forget some of us oil burners drove Peugeots. My first was a '79 504 followed by several 505s. They had lousy resale value so you could pick up a really nice car a year or two old for very few dollars.
Cheers, Dan
Old 08-27-2017, 06:25 AM   #1091
mayco's Avatar
Thanks fellas. I have drained the bowl but only when I've done a filter change. I appreciate the good info. Totally makes sense. I don't feel so neglectful now.
Old 08-28-2017, 08:29 AM   #1092
Dazed and Confused
Isuzusweet's Avatar
Reminds of the time I did some work for a gentleman on Saltspring Island as a very young lad. He had a couple of 504 station wagons if I recall and had a very interesting way of starting them. He would get in and start cranking; a huge cloud of dark smoke would ensue, ever so slowly changing to grey until it would finally light off and he would clatter away. This process would take well over a minute, if not two, and he'd be on the starter the whole time.
Loved the 505's, but they were built for southern France and Africa; if they so much as saw a salt shaker they quickly turned into a pile of iron oxide.
Thanks for the memories Dan.
Cheers
Tony
Old 09-10-2017, 03:35 PM   #1093
mayco's Avatar
Finished up installing a new camera system today....still have some odds and ends left I guess. I went with the rear view safety two camera system, https://www.rearviewsafety.com/rvs-7...ra-system.html.
I decided to go ahead and run new cable, provided with the system, and follow the same path as my old camera for the backup camera. Anchored the cable on the roof up to the refrigerator vent, down the vent and through the floor, under the rig up to the heater core, up through the floor there. The multiplexor for the system sits behind the passenger kick panel.
ID:	294548Click image for larger version
ID:	294549Click image for larger version
ID:	294550Click image for larger version
For the passenger side view camera I mounted the camera just behind the wheel well, cable runs through the skin there, anchored it high along the rear of the well, over to the frame rail and then zip tied towards the front of the rig and came up through the same hole as the cable for the rear camera.
ID:	294552Click image for larger version
I ordered the optional 9" monitor and I'm glad I did.
ID:	294554Click image for larger version
I need to talk to their tech team on Monday about some setup items for the monitor. Its not as intuitive as I would guess it would be. The multiplexer is set up with three camera ports. Since I'm only using two, I would like to toggle between just those two. The way it is currently set, I have to toggle through all three (one blank) to switch between the two cameras. That kinda sucks. But it seems like a good system, especially compared to the ancient one I had. Good aircraft grade connectors. Nice picture on the monitor. It will be really nice to have that side view camera when driving round cities in six lane traffic. I'm happy with the investment. Around $350 with the 9" monitor upgrade.
Old 09-10-2017, 03:56 PM   #1094
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Very clean install Mike
martin300662 is offline   Reply With Quote
Old 09-10-2017, 04:07 PM   #1095
Dazed and Confused
Isuzusweet's Avatar
Geez; Perfect length 31', perfect motor, Allison transmission, two overhead fans, rear camera, side camera, beautiful wife with a state pension....what more does a man need or possibly want?
Did I mention you have an Allison? You don't mind if I name drop Allison to Lynn a few times this meet? Lynn, who's this Allison Mikey likes and talks about so much?
That's okay, you should see the present John and I bought for our coaches. She's a very petit raven haired Irish girl that doesn't mind dropping her top when the sunshines.
Cheers
Tony
Old 09-10-2017, 05:02 PM   #1096
mayco's Avatar
Hmmmmmmmmm, tell me more about this lass
Old 09-10-2017, 05:07 PM   #1097
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
I think Tony's been surfing the silicone love doll site recently.......just saying, Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 09-10-2017, 05:16 PM   #1098
bobmiller1's Avatar
Also....speaking of Allison, I just requested a quote from my Jasper buddy today (Sunday) and he answered me....pretty sure I'm going to go forward with the Detroit 8.2 Litre Turbo and the Allison 540. If I like the way it performs and I think I will being that I have been driving the same tool truck for 28 years with that set up and at 28,000 lbs. or 12,712 Kilos I am pretty sure that the 370LE which tilts in between 16,000 - 18,000 should be even better. If that set up works then maybe a Gear Vendors for highway use. The other option was to install an (Allison) there she is again, 1000 which would require an electronic package to shift because it is an electronic transmission. No wires to deal with on the Detroit 8.2 or the Allison (did I say that name again) 540. Regards, Bob
Old 09-10-2017, 05:26 PM   #1099
mayco's Avatar
Thank you Martin, it went pretty smooth. I'm slower than heck anymore, the hardest part was on my back running the cable under the rig. That used to be no big deal, now it hurts !
Old 09-10-2017, 06:03 PM   #1100
bobmiller1's Avatar
yeah Mike, I feel your pain....same for me. but I still enjoy it, but man, I pay for it the next day, nice install by the way, Regards, Bob
1982 turbo diesel 310 :: 2013 Airstream turbo diesel 310 mayco Airstream Registry Discussions 1 07-28-2015 12:58 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
