Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 07-30-2021, 04:59 PM   #2081
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Thanks for the information fellas! I got an early start on the project this morning and didn’t see your posts before I got done. Eh, not the end of the world I just hope I don’t have ant leaks. I haven’t tested it yet, thought it might be wise to wait a couple days for the seaplane to cure a bit. Maybe I don’t need to since it’s not water soluble, what do you guys think?
I’d been putting this project off for the last couple years because I didn’t have any “bad” leaks AND I wasn’t real sure how to tackle it step by step. I recently did a tank cleaning with an enzyme based cleaner and once I had flushed the tanks several times and then added fresh water and the cleaning liquid, both valves started leaking BAD! The only thing I could think of is that the cleaner ate away the gunk from the valves that had been acting like a sealant. Sooooo, I had no choice but to get off my bum and tackle the job. I thought quite a bit about how I was going to approach it and the light bulb went off.
First thing was to cut the old valves out with the saws all and I purposefully cut the Y fitting leaving the old valves in place so that I had something to pull on with some leverage to get the 3” pipe out of the tank collars.
Attachment 400710
The gray tank pipe came out just fine but I couldn’t get the black tank pipe to budge…I needed more leverage.
So I drilled a 1/2” hole all the way through the collar glue joint and was able to slip a large thick shank screw driver through the holes and that gave me more to pull on. I wiggled and pulled and it finally came out.
Attachment 400713
Then I unbolted the tank hubs off the ends of the new Valterra unit
Attachment 400715
Cut my 3” pvc pipe, one end needed to be 3” and the other end 4”. These dims would account for 1.5” to slide into the tank, 1.5” for the glue joint, and then an extra inch on one end to slide the pipe into the tank and then back out to mate up with the valve. Really, that was the key to the install. Cut n glue up the tank hubs first and go ahead and install them before the valves and the Y fitting
Attachment 400716
My trusted helper there under the coach helping me……
ONCE AGAIN! She’s one heck of a wife I gotta say.
At that point it was a matter of starting on one end and assembling the unit back together. When I got to the other end, I was able to slide the longer pipe out to meet up with the valve. That was a struggle. Ended up having to use a pipe clamp to pull the pipe back out of the tank collar.
Attachment 400718
So there she be. Hope like hell it doesn’t leak, knowing now that the 635 is a sealant/adhesive. It won’t. I know it won’t. Right?
Soooo, do you think I should let it sit for a couple days to let the sealant cure a bit?
mayco is offline   Reply With Quote
Old 07-31-2021, 07:49 AM   #2082
mayco's Avatar
ID:	400744Attachment 1Click image for larger version
ID:	400745Click image for larger version
Old 07-31-2021, 07:53 AM   #2083
mayco's Avatar
ID:	400747Click image for larger version
Old 07-31-2021, 08:44 AM   #2084
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Originally Posted by mayco View Post
Great Job, Mike! I assume that will the one and only time the valves will be on top of the Dining Room?
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 07-31-2021, 09:05 AM   #2085
cmadmaxman's Avatar
Columbia , Tennessee
That looks all to familiar!
Great job Mike, think you will be happy with the new setup. Have had these valves on our 310 for over 14 years, and now on the 350, no leaks yet!
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (274,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 07-31-2021, 06:11 PM   #2086
mayco's Avatar
Thanks fellas. It wasn’t a fun job but not as bad as I thought it would be. I’m just glad to finally get it done. Well, hopefully it’s done. I’ll put water in it tomorrow and see. It should be good to go though.
Old 08-01-2021, 02:03 PM   #2087
mayco's Avatar
Wahooooooooo! No leaks in any of the joints! Fantastic!
I have one more question about our waste tanks. Are they made of polyethylene, polypropylene, or just what type plastic? I found a very small crack in the gray water tank and am wondering if there is a sealant that can be used on it. That 635 seamed to bond real well to it. It’s very small, like a 1/2” or so but I’m getting an occasional drip from it.
Old 08-01-2021, 05:21 PM   #2088
mayco's Avatar
I snooped around on the internet and found a video about this product. It looks very promising.
https://www.google.com/url?sa=t&rct=...MOPV4Z5-eet1u6
Old 08-01-2021, 07:03 PM   #2089
Airstream Driver
1994 30' Excella
Images: 49
For what its worth, I have repaired at least 3 ABS ( I assume) drain pans of the original AC units with 635. Surface has to be dry and cleaned with a solvent like denatured alcohol or lacquer thinner. It bonds super good and has been lasting for years
AIR #13
Old 08-01-2021, 08:15 PM   #2090
mayco's Avatar
I was thinking about using 635 Peter but I’m not sure what type of plastic our holding tanks are. Mine are the original tanks. I thought I had read that the tanks are either polyethylene or polypropylene and I wasn’t sure if the 635 would adhere well enough. It sure seemed to adhere well on the pvc pipe that slid into the tanks for the waste valves. This Tap product is specifically for those two plastics, awful expensive though with shipping. There are several sealants that will work for ABS but this is the only one I found that states it’s for either of those two polys. Argh……I can’t find the threads on the forum here that mention the material that our tanks are made of. Since they aren’t black and more like a milky white, I am assuming they aren’t ABS.
Old 08-01-2021, 09:34 PM   #2091
Kvsterling's Avatar
West Chester , Ohio
The tanks are made of LDPE (polyethylene). Great for not reacting to chemicals, hard to fix because nothing seems to stick to it.
Nice thing, it is a thermoplastic! Plastic welding (like a big soldering iron) is probably your best bet. I got mine off Amazon and did some major tank surgery successfully with the sticks the welder came with.
http://www.amazon.com/dp/B07RG8K18D/...ing=UTF8&psc=1
Just practice and check for leaks, you got this!
Kvsterling is offline   Reply With Quote
Old 08-29-2021, 07:55 AM   #2092
mayco's Avatar
After about 3 years of procrastinating and being unwilling to get off the $$$, finally bit the bullet and ordered a WeBoost cell signal booster for the rig. Hope to install this week. Rotated tires yesterday and confirmed just how old I’m getting
Old 08-29-2021, 08:30 AM   #2093
Airstream Driver
1994 30' Excella
Images: 49
Mike, I trust you got the "RV" version of the WeBoost? The home version has a limited "LTE" bands it will boost. I bought the home version last year and it work very well when the right Band was transmitted by the tower. Omni directional Antennas are a must as well. You can get an app called "LTE Discovery" to see the current Band you are on. Unfortunately, I do not know how to force change your cell phone to a different Band, others may know.
AIR #13
Old 08-29-2021, 08:57 AM   #2094
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Yeah Mike, I’ve had my cell booster for 3 years now, excellent for streaming AMC or TCM. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 08-29-2021, 08:58 AM   #2095
mayco's Avatar
Ya I did Peter. The latest incarnation;
weBoost Drive Reach RV (470354) Cell Phone Signal Booster Kit, Made in The US, All Networks & Carriers - Verizon, AT&T, T-Mobile, Sprint & More, FCC Approved
It’s pricey, $500, but I justified by saying it’s money spent for entertainment. We really don’t spend much on entertainment type things other than traveling in the 310….boring eh.
Old 09-04-2021, 10:26 AM   #2096
mayco's Avatar
Finished up the cell signal booster install. Ended up using a heavy bracket that came with the unit for the exterior antenna mount. Made use of the heavy gauge metal bracket that once held the original backup camera.
They sure didn’t supply an abundant amount of cable with the kit. I was able to route it over the roof along side my camera cable, down through the refrigerator vent. Had to cut a small hole in the vent cover in order to get a fish tape down. I got that patched n sealed.Click image for larger version
The interior antenna is small and……well, not ugly I guess.
ID:	403411Click image for larger version
I drilled through the floor in the fridge compartment, ran the cable for the interior antenna over to the wall under the tv, and then up inside the wall between the interior skin and the plastic wall on that side. So it’s hidden nicely.
Old 09-04-2021, 03:44 PM   #2097
dadstoy's Avatar
1982 28' Airstream 280
_ , _
Hey Mike. Is your table a single leaf? So no latch on it?
dadstoy is offline   Reply With Quote
Old 09-04-2021, 05:37 PM   #2098
mayco's Avatar
Kind of…I made the table so it’s custom. It does have an extension leaf that is stored in a cabinet. I saw that you were looking for something to replace the “bent nail” contraption.
Surely there is hardware out there somewhere that would be an upgrade to that thing. I’m not even sure what to call it.
My leaf attaches with two dowels that are glued to the leaf and they slide into holes on the edge of the table. It then has a latch that pulls it tight.
Old 09-04-2021, 06:08 PM   #2099
mayco's Avatar
Here ya go,
ID:	403439Click image for larger version
ID:	403440Click image for larger version
ID:	403441Click image for larger version
ID:	403442Click image for larger version
Old 09-04-2021, 08:42 PM   #2100
dadstoy's Avatar
_ , _
Beautiful table Mike. I like that you made the extension shorter so folks can walk around it!
1982 turbo diesel 310 :: 2013 Airstream turbo diesel 310 mayco Airstream Registry Discussions 1 07-28-2015 12:58 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
