Old 07-03-2018, 06:33 AM   #1
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Maintenance/repair checklist
Hi,
Can you set out your ideas for key maintenance/replacement items. I've already installed the following items and i have got some planned work on the radiator, what should i aim to do next? What would be your priorties
Installs/upgrades
Rebuilt transmission
Airbags - front and rear
Rebuilt throttle body
New master cylinder
New hydroboost
New front brake cables
New belts and hoses
New temp sensor
Replacement batteries
Fuel filter
Brakes serviced
New Sony stereo
Platinum Spark Plugs
Fan clutch replaced
GM Original Equipment Ignition Distributor Cap
ACDelco D470 Professional Ignition Distributor Rotor
ACDelco D503A Professional Ignition Coil
GM Original Equipment Ignition Control Module
ACDelco D1987 Professional Ignition Distributor Pickup
ACDelco OEM PT166 Ignition Coil Connector Pigtail
ACDelco EP386 GM Original Equipment Electric Fuel Pump Assembly
ACDelco-TS7-Original-Equipment-Strainer
ACDelco TS1 GM Original Equipment Fuel Pump Strainer
ACDelco 213-1165 Professional Oxygen Sensor
ACDelco 213-1545 GM Original Equipment Manifold Absolute Pressure Sensor
ACDelco CV774C GM Original Equipment Positive Crank Ventilation (PCV)
ACDelco 24205853 GM Original Equipment Automatic Transmission Pressure Control Solenoid Valve Filter
ACDelco D1505B GM Original Equipment Headlamp Switch
Regular oil changes
Planned changes
Radiator change or flush
New water pump
Trans gasket and oil change
Window gaskets
Boom Sounds is offline   Reply With Quote
Old 07-03-2018, 06:50 AM   #2
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
This wont apply to your setup but I have a spare set of injectors with the pod for my TBI setup. The pod is set to 30 psi not the stock 15 and the injectors are tuned to match. I still need to get a spare ECM with chips ready to roll.
On the radiator, except for the lower efficiency in the transmission cooler, the Aluminum one I just installed is working fine. The external cooler took care keeping the tranny fluid in range
Do not take life too seriously.
You will never get out of it alive.
WayneG is offline   Reply With Quote
TT Arrival Checklist & Departure Checklist Rocinante On The Road... 27 06-29-2020 07:34 AM
Maintenance Checklist debbietaylor 2005 and newer - Bambi all models 4 04-05-2017 09:50 PM
Maintenance and/or pre-trip checklist? dgray 2006 - 2010 International 3 05-21-2009 07:52 AM
Repair and Maintenance Link 74Argosy24MH Link Archive 0 12-30-2004 06:26 PM
Fixing things-'RV Repair and Maintenance Manual Joan D'Andrea Our Community 6 09-19-2002 04:49 PM
