11-24-2020, 08:19 AM
#921
Churubusco
, Indiana
And since I had time... Dan, Peter, eat your hearts out
11-24-2020, 08:34 AM
#922
Churubusco
, Indiana
forgot to mention, I made some upgrades while I was in there
1983 Airstream 310 Class A Motorhome
-Rob
11-24-2020, 11:16 AM
#923
1982 28' Airstream 280
Port Angeles
Thanks, I can rest easy now.
Cheers, Dan
~ Margaret Thatcher ~
11-24-2020, 05:08 PM
#924
1991 35' Airstream 350
Columbia
, Tennessee
How is this Dan!
I almost did it! Just could not paint the plated caliper's.
Peter made me do it
New Bendix rotors, Bendix pads, and Raybestos plated caliper's all the way around!
Hey Rob, check you master cylinder, you might be surprised what you might find in it!
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
11-24-2020, 05:10 PM
#925
Columbia
, Tennessee
Like the Brembo on the caliper Rob! Cool
AIR Member 12654
1991 350LE "Zephyr"
11-24-2020, 05:59 PM
#926
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Originally Posted by cmadmaxman
Attachment 383752
How is this Dan!
Peter made me do it
Attachment 383753
you guys are getting close, was really hoping for a little different shade of red, can you redo please?
AIR #13
11-24-2020, 07:17 PM
#927
Columbia
, Tennessee
Was thinking of going Tennessee orange! Go VOL's
AIR Member 12654
1991 350LE "Zephyr"
11-24-2020, 10:14 PM
#928
Churubusco
, Indiana
Attachment 383752
How is this Dan!
Peter made me do it
Attachment 383753
Will do! Pretty sure this brake system was overhauled a few years ago, hopefully it's clean, fingers crossed. At least the lines aren't rusty. I can do new calipers and cylinder a heck of a lot faster than lines!
Also, were those bolt in replacement calipers?
11-24-2020, 10:19 PM
#929
Churubusco
, Indiana
That's the flash making it look more orange than it really is, I promise it's a perfectly acceptable shade of red when viewed in person. Tell ya what, you can come look for yourself, and if you're not happy I'll let you paint it whatever color you like, as long as you promise to also flush and bleed the system while you're here
11-24-2020, 10:39 PM
#930
Churubusco
, Indiana
Created an access hatch for the fuel tank pickup connections, and made progress on the heated floor install. Routing all those wires in a flat bundle took for freaking ever.
11-25-2020, 01:51 AM
#931
Port Angeles
Attachment 383752
How is this Dan!
Peter made me do it
Attachment 383753
You guys are doing great.
I'll have to yield to Peter on the shade. I'm pretty much color blind so I can't really even guarantee that they're red, I just have to take your word for it.
Cheers, Dan
11-25-2020, 05:46 AM
#932
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy
, Tennessee
The opening you cut for your tank sending unit is it located in front of or under the front framework for the bed, I noticed the two pieces of plywood in the pic. Thought about cutting one even though I have installed new flooring. Thanks for any help.
11-25-2020, 06:48 AM
#933
Churubusco
, Indiana
Here is a more zoomed out pic compared to the bed, it looked like there was initially a bigger hole but they put the bed over top of it, so I had to cut along the bed, then cut through the aluminum underneath.
I'm planning on leaving it accessible even after the floor is in
Hope that helps
11-25-2020, 08:28 AM
#934
Columbia
, Tennessee
Yes Rob, exact replacement, brand new and zinc plated with all the hardware. Front and back same caliper, 2 right, 2 left. The front hoses have been replaced recently by the PO, but have now replaced the remaining 3 hoses on the rear end.
Your looking good and the heated floor install. Are you going to try and insulate the under side of the floor? I have done that on the 310, but no heated floor.
AIR Member 12654
1991 350LE "Zephyr"
11-25-2020, 09:15 AM
#935
Churubusco
, Indiana
Thanks, do you by chance still have part numbers readily available? Looks like a nice upgrade for the next brake job
Insulating the underside with aluminum backed foam is on my to-do list... I'll see after installing the heated floor of I still think it's necessary. Planning on going to Arizona this winter, so I'm a lot less concerned
11-25-2020, 09:27 AM
#936
Columbia
, Tennessee
Here is the part numbers from Rock Auto:
BENDIX PRT1483 Rotor $ 50.79 $ 0.00 2 $ 101.58
BENDIX PRT1480 Rotor $ 58.79 $ 0.00 2 $ 117.58
CENTRIC 15066304 (150.66304) Hydraulic Hose $ 6.22 $ 0.00 1 $ 6.22
RAYBESTOS FRC4157N Caliper $ 50.79 $ 0.00 2 $ 101.58
RAYBESTOS FRC4158N Caliper $ 53.79 $ 0.00 2 $ 107.58
RAYBESTOS BH38267 Hydraulic Hose $ 14.53 $ 0.00 1 $ 14.53
RAYBESTOS BH38264 Hydraulic Hose $ 16.60 $ 0.00 1 $ 16.60
We are going to be in AZ, after a stop in Austin TX. We will be there for Christmas with my Dad and for a couple of months after that. We will be west of Phoenix about 50 miles. Just off I10 exit 103. If you in the Phoenix area, maybe we can hook up!
AIR Member 12654
1991 350LE "Zephyr"
11-25-2020, 09:48 AM
#937
Churubusco
, Indiana
Thanks!
And definitely! Not sure where all we'll be yet, but heading that way right after new years, planning to spend the winter exploring the state, hopefully we can meet up!
You taking your 310?
11-25-2020, 11:41 AM
#938
Columbia
, Tennessee
No, plans to take the Zephyr.
AIR Member 12654
1991 350LE "Zephyr"
11-25-2020, 08:08 PM
#939
Churubusco
, Indiana
Cool!
Didn't know it was that close to road ready!
11-25-2020, 09:48 PM
#940
Columbia
, Tennessee
Yep, pretty close. We took her to Alabama a couple of weekends ago with the grands. All worked good, but was having a brake dragging, so that is when I decided to just replace the whole lot all the way around.
AIR Member 12654
1991 350LE "Zephyr"
