10-19-2020, 11:29 AM
#781
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Originally Posted by Magnet18
If you like waiting for stuff, you will really like ordering from that company. My order was supposed to ship Aug 24th...its not even in production as of today.
AIR #13
10-19-2020, 01:11 PM
#782
Churubusco
, Indiana
Well, I was briefly hopeful I wouldn't need to replace my whole system... Maybe not if it's that slow a turnaround, not worth limping it on one part at a time.
Heard good things about the lippert systems but be prepared for the price shock
10-19-2020, 06:51 PM
#783
1991 35' Airstream 350
Columbia
, Tennessee
Rob, the best way is to grind the welds and re-use the old ones. Do not know of replacements.
They are stout and not much to go wrong with them.
Remember the welds go along the sides, not across the springs. That will cause a stress riser that will cause the spring to possible break at the the weld points!
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
10-21-2020, 08:07 PM
#784
Churubusco
, Indiana
Cleaned up what was left of my front banana wraps. The center is OK, the ends are literally disintegrating in places where the plastic is drawn thin, and in multiple pieces held together with tape.
Taped it up into it's correct shape, and put a layer or two of glass on the inside, re-forming the places where there was no plastic at all.
I also got some fiberglass impregnated waterproof bondo for cleanup of the details before painting.
It has been about 10 years since my last fiberglass project, and I quickly remembered why. Not my best talent.
10-21-2020, 08:20 PM
#785
Churubusco
, Indiana
Teeny tiny left handed drill bits showed up, drilled out that blasted broken screw in the window, and went around all the windows installing the last 8 inches of schlegle that didn't get covered by the 96" long strips. Well worth doing, cuts down the draft immensely.
One extra 96" strip was about right for my 7 windows. Another window and I would have needed a second
10-21-2020, 09:52 PM
#786
1986 34.5' Airstream 345
Londonderry
, New Hampshire
How well does the fiberglass resin stick the banana wrap plastic?
10-22-2020, 07:27 AM
#787
Churubusco
, Indiana
The banana wraps are ABS, i cleaned them up with scotch brite and lacquer thinner.
Checked this morning and the bond seems very good, I'm not worried about separation
10-22-2020, 09:43 AM
#788
Columbia
, Tennessee
Good to hear Rob, I used the MEK slurry process, with the fiberglass, slow way too do it, but looking like it's holding up good. The fiberglass and epoxy will be much faster for sure.
AIR Member 12654
1991 350LE "Zephyr"
10-22-2020, 10:00 AM
#789
Churubusco
, Indiana
Yes, MEK is a surefire way as well, I used that in my shower pan where I really didn't want leaks.
I might need to do the MEK again to rebuild cracked and broken corners on the spare tire cover. I think if I was to put bondo on the spare tire cover corners it probably wouldn't last long.
The fiberglass adhesion to ABS is good, and since these are just cosmetic fiberglass and bondo will be much faster. Plus I worried the MEK would make the very thin ABS flimsy and lose its shape.
10-22-2020, 05:35 PM
#790
Churubusco
, Indiana
Driveshaft ready to go back in, holding off till i finish the rest of the rear end
10-23-2020, 05:07 PM
#791
Churubusco
, Indiana
Bondo last night, sanding and cutting tonight, threw a first coat of primer on, makes the trouble spots obvious but it's coming along. I'm just happy that it's in one piece.
The P-30 turn signals from eBay are close but not exactly the right size. I recall having trouble finding even these. Might need to modify the wraps with fiberglass, since I'm here anyway...
10-24-2020, 01:50 PM
#792
Churubusco
, Indiana
well shoot, the new springs came with 9/16" ID bushings, but the old bushings are all 5/8" ID. All other dimensions are the same.
So I think the correct part number is RB-129, rather than the included bushings which were RB-136
Anyone know if a hammer is a decent way to swap these or if I should plan on buying beer for my hydraulic press guy?
1983 Airstream 310 Class A Motorhome
-Rob
10-24-2020, 02:33 PM
#793
Columbia
, Tennessee
I think you need to buy some beer![emoji106]
AIR Member 12654
1991 350LE "Zephyr"
10-24-2020, 02:34 PM
#794
Columbia
, Tennessee
I found the orginal ones, USA made at mill supply. Housing and lens.
AIR Member 12654
1991 350LE "Zephyr"
10-24-2020, 03:41 PM
#795
Churubusco
, Indiana
Brad PMd me and let me know the right part number is GM 916558
Fortunately he's selling me some NOS units he has laying around
Searching online I didn't see that part number on mill supply, is there an alternate number?
10-24-2020, 03:53 PM
#796
Churubusco
, Indiana
Mcmaster parts for the bolts that hold in the transverse rod pins, and the right size spring shackle bolts
The washers that were on the transverse rod pins... Well... I think they used to be flat...
They are a weird size. 1-1/8" ID, 3-1/8" OD, 1/8" thick. Can't find them online anywhere. If I had a lathe I'd just make them, but I might just hammer them flat. They shouldn't be seeing torsion loads like that, i think the only reason they did was because the bushings wore out and the bags were flat at the same time.
1 Top-Lock Distorted-Thread Locknut
Zinc-Plated High-Strength Grade C Steel, 5/8"-18 Thread Size
92501A534 1
pack of 25 10.37
pack $10.37
2 Top-Lock Distorted-Thread Locknut
Zinc Yellow-Chromate Plated Grade C Steel, 1/2"-20 Thread Size
99291A260 1
pack of 10 5.91
pack $5.91
3 Zinc Yellow-Chromate Plated Hex Head Screw
Grade 8 Steel, 5/8"-18 Thread Size, 5" Long, Partially Threaded
91257A833 4
packs of 1 2.79
pack $11.16
4 Zinc Yellow-Chromate Plated Hex Head Screw
Grade 8 Steel, 1/2"-20 Thread, 2-1/2" Long, Partially Threaded
91257A750 1
pack of 10 15.02
pack $15.02
10-24-2020, 05:50 PM
#797
Churubusco
, Indiana
Ready for paint tomorrow
10-24-2020, 06:29 PM
#798
Columbia
, Tennessee
Those washers are what came off the bushings. They will be attached to the new neoprene bushings.
AIR Member 12654
1991 350LE "Zephyr"
10-24-2020, 06:39 PM
#799
Columbia
, Tennessee
Here's my invoice from mill supply for the front parking/turn signal complete assembly.
AIR Member 12654
1991 350LE "Zephyr"
10-24-2020, 08:22 PM
#800
Churubusco
, Indiana
Doh. Totally overlooked that. Glad you've got a good memory.
Here's my invoice from mill supply for the front parking/turn signal complete assembly. Attachment 381685
Good find! A couple years ago I searched mill supply high and low and couldn't find them
