Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 05-13-2021, 12:46 PM   #1461
Originally Posted by Magnet18 View Post
Oh, and no surprise, the shop did confirm the transmission fluid is "packed full of metal"
Not that I really suspected anything else, but removes the tiny nagging thought about it being the overdrive.
It'll probably be a couple weeks before they can yank the transmission and find the actual failure point, but I'll post any pics/info as I get them
I'm assuming you have no plans to re-connect to the lower radiator transmission cooling section. That is likely to be packed with metal chips as well.
1975 24' Argosy Motor Home
Old 05-13-2021, 01:14 PM   #1462
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver , Colorado
So what does this mean for those of us who will need/want to address the transmission (and or gearing) in the future? I'm not having any problems at the moment, but having only three gears (and not being able to hear myself think for the whine on the interstate), I have been "mildly" looking into upgrades and changes.
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
kidjedi is offline   Reply With Quote
Old 05-13-2021, 04:14 PM   #1463
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Don't ya hate when Brad points out crap like that, just when you think you are having a great day
AIR #13
PeterH-350LE is online now   Reply With Quote
Old 05-13-2021, 04:43 PM   #1464
Magnet18's Avatar
Churubusco , Indiana
Yeaaa the shop already pointed that out too. In order for the warranty to be valid they must replace the transmission cooler and lines (hopefully with an even bigger one )
Magnet18 is offline   Reply With Quote
Old 05-13-2021, 04:53 PM   #1465
Magnet18's Avatar
I would go 4l80e / 4l85e
You can't split the gears like a gear vendors, but you get the overdrive for the highway, and if you run into trouble parts are a LOT easier to find/replace, after the 4th shop that agreed then backed out, I was wondering about that route a lot
Old 06-04-2021, 12:15 AM   #1466
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Hey.....itís been a month since we have heard from you......did you burn your motor home or sell it ??? Any progress on the transmission/gear vendors repair ??? For a guy that used to post 3 to 4 times a day makes me wonder if youíre pulling a Mark Faucet (Tap) on us. Listen.....in all seriousness if you think you might not be able to make it to the get-together in October, you have one of the good sites ( number ) 6, I believe, I have a buddy that wants to come. Send me a private msg. and let me know so I can get him in your spot. Hope to hear from you soon, take care, Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 06-04-2021, 10:25 AM   #1467
kidjedi's Avatar
1972 25' Tradewind
1975 24' Argosy 24
Denver , Colorado
Man... he goes home for a month while his rig is getting repaired and you're already trying to snipe his spot?!
BeahmStream.com
Old 06-04-2021, 02:11 PM   #1468
Magnet18's Avatar
Cool your jets Bob, I actually just got off the phone with the shop. New transmission in hand and goes in next week, old transmission is out and I finally have a picture of the carnage. Shaft inside the trans snapped clean in half.
Old 06-04-2021, 02:32 PM   #1469
Magnet18's Avatar
But... I'll tell you what. We all know real estate prices are through the ceiling right now but I'll cut you a deal. Cover the cost of this transmission replacement, and the spot is yours for the week
Old 06-04-2021, 02:54 PM   #1470
Airstream Driver
1994 30' Excella
Images: 49
So what you are saying is that it shifted just fine, it just lost its connection to the engine Trans fluid should still be super clean. I trust they will put a keen eye on the flexplate?
AIR #13
Old 06-04-2021, 02:59 PM   #1471
Airstream Driver
1994 30' Excella
Images: 49
Bob, there is no good or bad spot. #6 doesn't mean anything, since we are the once creating our layout. We just have the service post to go by. And first come, first stake your spot, with regards to others. I sent you a pm with what your buddy should do.
AIR #13
Old 06-04-2021, 03:35 PM   #1472
Magnet18's Avatar
That is something that doesn't add up, unless I'm not aware of how the plumbing works, they said the fluid was full of metal. So I do wonder if something internally failed like a gear and the shock of whatever that was is what snapped the shaft.
Old 06-04-2021, 09:41 PM   #1473
Magnet18's Avatar
Well the flex plate is apparently perfect, and I have a new torque converter going in anyway, so I suppose it doesn't matter
1983 Airstream 310 Class A Motorhome
-Rob
Old 06-05-2021, 06:34 AM   #1474
Airstream Driver
1994 30' Excella
Images: 49
Don't save a buck on the torque converter. They can range from a couple hundred bucks to over 1k. Heavy duty towing from the experts is what you should use. Expensive yes, worth it? most likely
http://www.hughesperformance.com/hd-street-strip/
AIR #13
Old 06-05-2021, 07:44 AM   #1475
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Something in the transmission had to lock up to twist the input shaft! The stock engines don't really have the torque to twist that shaft unless something went really wrong in the transmission.
I put the Hughes XTM in the 310 when I overhauled the 475, great converter!
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (274,000 and still going )
cmadmaxman is online now   Reply With Quote
Old 06-05-2021, 08:55 AM   #1476
cmadmaxman's Avatar
Taking out the stator spline as well!
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 06-05-2021, 09:31 AM   #1477
Magnet18's Avatar
I agree 100% on something locking up internally!
And I'll check what the converter is, should be a stock replacement
-Rob
Old 06-06-2021, 08:39 AM   #1478
Twisting the nose off the input shaft like that would most likely bend the TC stator and mangle the vanes, sending shrapnel thruout the system.
I hope the GV is ok.
Old 06-07-2021, 06:11 PM   #1479
Magnet18's Avatar
Gv seems to be ok
The new torque converter is a proper heavy duty towing rated unit... The only thing about it is they built it with a 3 bolt mount instead of 6 bolt mount because the 6s are apparently impossible to get ahold of... Still will carry a 3 year unlimited mile warranty through the O'Reilly network...
3000lbs shear strength per brand new grade 8 bolt... Not thrilled but I guess I'll live with it. I've seen plenty of failures where the weaker 3 bolt torque converter gave out but none where the bolts sheared off, and the automotive industry carries a safety factor of well above 2 anyway, in theory.... Guess we'll find out in a few thousand miles
-Rob
Old 06-07-2021, 06:45 PM   #1480
Airstream Driver
1994 30' Excella
Images: 49
Gv seems to be ok
The new torque converter is a proper heavy duty towing rated unit... The only thing about it is they built it with a 3 bolt mount instead of 6 bolt mount because the 6s are apparently impossible to get ahold of... ...
the torque converter is NOT part of the trans built. It gets installed just prior to installing the transmission, 3 or 6 bolt. Plenty of 6 bolts all over, someone is feeding you BS.
AIR #13
Radiator Hoses for 1983 310 Billy B General Motorhome Topics 7 06-06-2016 06:59 PM
1983 310 Engine Problem Rik Mechanics Corner - Engines, Transmission & More... 7 10-28-2005 10:30 PM
1983 310 guages Bfrank General Motorhome Topics 6 07-23-2002 06:01 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
