02-21-2021, 10:09 PM
#1281
Churubusco
, Indiana
Made it to alamogordo, NM! Incident free .. almost
Yesterday was a perfect travel day. Got a late start out of Peter's, cruised across fredericksburg through hill country, and to I10 stopping just shy of Van Horn. 400 miles in total, gained 2500ft of elevation, average 6.8mpg, all systems behaved great. With everything balanced it was smoothly gliding down the road perfectly happy at 70mph. Pulled over at a roadside pull through park for $20, had a couple drinks at their bar, couldn't have had a better travel day.
Today was pretty good all things considered, just some minor stuff. For being half as far it took twice as long.
1. Ran a load of laundry first thing in the morning forgetting the tanks weren't open to drain. Doh. So the bathroom floor is up until that dries, no biggie.
2. Tried traveling with a full fresh tank thinking we would boondock tonight. Combined with the 30mph headwind... Gave up on that real fast and dumped it after a couple miles
3. Fiiiiiiiinally found propane in van horn, the whole stinking state was sold out.
4. Got past VanHorn and one lone person tried to flag us down. He was also all smiles and thumbs up, very confusing. Couldn't make out why, checked the mirrors and the wife ran around all the windows making sure everything looked ok. slowed down to 60 and exited as soon as possible... To find the license plate gone. Go figure. Wasted a couple hours running up and down 20 miles of I10 & frontage road, just in case... Found 2 other license plates, but not ours. Oh well, a call to the BMV this week and a campground booked in alamogordo since we're now getting in after sundown.
Then the rest of the way to alamogordo was an easy cruise.
I do have a couple new things to address though
1. Looks like I'm leaking a bit of oil past the hubcaps, more on the passenger side. May need to pull the hubcap and re-do the RTV I'm thinking. Used OE seals and careful when putting them in, that's the side I replaced the 5 hubcap bolts on after the rtv was done, so hopefully that's all the problem is.
2. I don't think the propane regulator is supposed to have brown goo there
02-22-2021, 05:59 AM
#1282
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Glad is going well for you! Remember to be higher on the side you pull the cap or else you will loose more gear oil and dont have a clean surface for the sealer to adhere to.
AIR #13
02-22-2021, 07:01 AM
#1283
Churubusco
, Indiana
Thanks Peter!
02-22-2021, 08:36 AM
#1284
1982 31' Airstream 310
Columbia
, Tennessee
Magnet18's 1983 310
And the axle in place!
Chris & Brenda
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (272,000 and still going  )
02-22-2021, 09:16 AM
#1285
Columbia
, Tennessee
Not good with this app! Anyway:
Try cleaning up everything with acetone, if there is not a gasket, I made one out of cork gasket material. I use copper coat spray on both sides of the gasket, let it dry 30 minutes +, and install. Make sure cap is not warped.
Don't over torque, just holding gear grease back an keeping the axle in place. Also if 5/16-24 bolts don't have lock washers, put some on.
Be safe!
Chris & Brenda
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
02-22-2021, 09:27 AM
#1286
Churubusco
, Indiana
Be safe!
Thanks Chris!
I'll dig up my service manual to make sure I get the torque right.
02-22-2021, 09:35 AM
#1287
Columbia
, Tennessee
If you want to make sure that the bolts don't back out, like all good Harley owners, put a little blue loctite on em!
Chris & Brenda
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
02-23-2021, 10:23 AM
#1288
Churubusco
, Indiana
Noted, definitely will do!
So I was looking at the motorhome gearing up to do the hubcap seals this afternoon. Noticed telltale oil specks further forward than the wheels, and a drop on the dust shield in front of the parking brake. Trying to determine how concerned I should be. The parking drum is fine so it's not the output of the gear vendors. The oil pan is also dry so not the front anywhere. I snugged up my valve covers at Peter's because I noticed they were leaking a bit, may be leaking from there.
I figure it must be the valve covers or rear main... Can't imagine why the rear main would be acting up.
02-23-2021, 10:29 AM
#1289
Churubusco
, Indiana
1983 Airstream 310 Class A Motorhome
-Rob
02-23-2021, 10:50 AM
#1290
Airstream Driver
1994 30' Excella
Austin
Did you replace the rear oil seal when you pulled the yoke?
02-23-2021, 11:23 AM
#1291
Churubusco
, Indiana
On the gear vendor no, didn't seem to need it
I had had that drum off and back on a handful of times and never missed a drop
02-23-2021, 11:58 AM
#1292
Churubusco
, Indiana
The body of the gear vendors itself is wet with oil, so I'm thinking it must be in front of the output seal.
-Rob
02-23-2021, 12:23 PM
#1293
Airstream Driver
1994 30' Excella
Austin
There should be 2 rear trans seals. 1 for the trans and 1 for the GVO. Does the GVO use gear oil or trans fluid? The fluid type should narrow it down.
02-24-2021, 07:35 AM
#1294
Churubusco
, Indiana
Re-sealed the hubcap yesterday afternoon, wasn't confident in my ability to cut a cork gasket sitting at a picnic table so i used RTV green for gear oil, same stuff I used for the diff cover. We'll see how it holds.
Also crawled around looking at/for oil drips. Everything looked to be motor oil with the exception of one lonesome drop of transmission fluid on the transmission pan.
I think the drips on the spark plug wires are a giveaway it's just the valve covers.
02-24-2021, 07:44 AM
#1295
Churubusco
, Indiana
Didn't remember offhand, looked it up, the gear vendors uses GM#12346190, gear oil. Doesn't smell so I'm confident it's not the gear vendors, which is a relief since that's probably both most sensitive to getting low and also the only thing without a dipstick
02-24-2021, 09:40 AM
#1296
Richmond
, Kentucky
I hate leaky valve covers!
I don't know why it's so hard to keep one from leaking but it is. I've had minimal luck keeping them from leaking
02-24-2021, 09:47 AM
#1297
Churubusco
, Indiana
Glad to know I'm not the only one!!
I never noticed the leaky valve cover until this trip. Could very well just be that I simply never noticed. Will check that they're all snug before hitting the road.
Just realized this is the side with the PVC check valve, so ill check that too, but I would think any excess pressure would vent back out the breather on the other side, right?
02-24-2021, 09:54 AM
#1298
Richmond
, Kentucky
Excess pressure will find any avenue of escape that it can. If the rubber seal in the valve cover that the PCV valve pushes into is hard then oil will weep right past it.
02-24-2021, 11:19 AM
#1299
Churubusco
, Indiana
I just meant that the breather would be much lower resistance than pushing out the valve cover gasket. Not sure how restrictive the flow of air between the two valve covers is.
Or just as likely when I noticed the small weep and snugged them up I inadvertently overtightened and turned it into a big weep.
I think I've fought valve cover leaks on almost every vehicle I've owned. The best solution is probably covers that aren't thin stamped steel, maybe when I get back to the home shop I'll swap them.
02-24-2021, 11:40 AM
#1300
Richmond
, Kentucky
It's been my experience that if there is enough pressure inside the engine block it will find any avenue of escape. On my Triumph TR4, even with an fully functional crankcase breather system oil would find it's way out any place it could. I found lots of bolts on the engine block that had oil weeping by through the threads.
I think you're on the right track looking at different valve covers. Good cast aluminum valve covers that are machined properly should go along way towards stopping the leaks. Let me know when you find a good set
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
kidjedi
