08-20-2019, 03:35 AM
#601
Churubusco
, Indiana
Storm cell rolled through while we were out grocery shopping Sunday night, lots of down limbs everywhere
Came home to find that guy, obviously not big enough to do major damage, but definitely enough to break something or puncture the aluminum skin if it fell out of the sky and landed wrong
Still haven't climbed up on top to inspect but everything seems a-ok
1983 Airstream 310 Class A Motorhome
-Rob
08-20-2019, 11:39 AM
#602
1982 31' Airstream 310
champaign
A couple years ago we were headed for Denver, we were going to stay in the driveway of some very nice folks (fellow Airstream owners). We ended up running a day behind schedule......by choice, we decided to make an extra stop on the way. Anyway, if we would have arrived on the originally planned date, a cottonwood tree would have landed on the 310. The whole tree came down right in the driveway we were scheduled to be at. WHEW!
08-20-2019, 08:10 PM
#603
Churubusco
, Indiana
Wow, talk about making your hair stand up!
08-28-2019, 06:24 PM
#604
Churubusco
, Indiana
Hehehehehehe
-Rob
08-28-2019, 07:00 PM
#605
1991 35' Airstream 350
Columbia
, Tennessee
Sweet!
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
08-28-2019, 07:13 PM
#606
"Alumi-holic"
Bartlett
, Tennessee
Wow!
08-28-2019, 07:57 PM
#607
1989 34.5' Airstream 345
Ebro
, Fla Panhandle
Nice jewelry! Where did you find them?
Cheers Richard
08-29-2019, 04:56 AM
#608
Churubusco
, Indiana
Speedhut.com
I've been waffling on pulling the trigger for over a year, a busted radiator hose clamp a few weeks ago finally convinced me that I should just pony up and get some good gauges
-Rob
08-30-2019, 05:15 AM
#609
1984 27' Airstream 270
West Chester
, Ohio
That’s great, I think you will be very happy with them. I also got some speedhut gauges in the airstream about a month ago. Just gps speedo, tach, and a clock. I’m very happy with the look, install was very straight forward, and readings accurate. I think having the built in compass and altimeter in the speedo is what sold me. You are about to find out what all those wires behind the dash do[emoji6]
Attachment 1
08-30-2019, 06:38 AM
#610
Churubusco
, Indiana
Attachment 1Attachment 350828
Thanks, yours look great!
As for the wires... not looking forward to it!
-Rob
08-31-2019, 05:23 PM
#611
_
, _
Wow! I love your new gauges!
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
08-31-2019, 10:52 PM
#612
Churubusco
, Indiana
Thanks!
-Rob
09-01-2019, 04:43 PM
#613
Henniker
, New Hampshire
Very nice!
1982 310 motorhome 502
Henniker New Hampshire
09-01-2019, 09:05 PM
#614
Churubusco
, Indiana
Wrapped up another class yesterday, got productive today
Finally finished the heat shield!
Dear woodworkers... Where should I get 1/8 or 1/4" flexible plywood, and is there a certain type that's best for matching the ~3" radius bend in the hearth?
Building a cabinet around the washer, attempting to kerf cut 1/4" plywood wasn't working
-Rob
09-01-2019, 10:30 PM
#615
1982 28' Airstream 280
Port Angeles
Look for some Bruynzeel or Baltic Birch. It's spendy but pretty flexible in the 1/8" thickness.
Cheers, Dan
~ Margaret Thatcher ~
09-02-2019, 11:46 AM
#616
1979 24' Airstream Excella 24
Tipp City
, Ohio
3" is a pretty tight radius. You will probably need to built a bending jig to form it around. Slow and steady is the key. Steam helps alot. If you don't have a good method to create steam you might try laying a soaking wet bath towel on the wood for several hours. Often to get it soft enough to bend you water stain the wood. So after you get the shape you want you have to glue a veneer on top of it.
09-02-2019, 04:51 PM
#617
Churubusco
, Indiana
Thanks both!
I know there are some flexible products but I might have to end up ordering something
Speaking of veneering, the front part of the cabinet got done today!
Re-used the original closet door and the storage door, the vinyl decal from Amazon is a darn good match, we'll see if/how it holds up
-Rob
09-02-2019, 05:48 PM
#618
champaign
Rob, what is it exactly that you're trying to wrap with wood? I couldn't understand it from the picture....duh.....
Since I'm not sure of the look you're going for I'll just throw out an idea for tight radius, TAMBOUR. You can get it in various sizes and finishes, the smaller width slats can make a very tight radius. I've worked with it several times on the job and it's not bad to work with.
Pretty readily available, if not at a lumber yard there are multiple suppliers online.
Mike
09-03-2019, 06:54 AM
#619
Churubusco
, Indiana
Thanks Mike, tambour hadn't crossed my mind!
So what I'm trying to make is a curve on this corner here
I can also probably use metal since it gets veneered
I'll be trying an specialty store after work if I can, Lowes and Menards didn't have any 1/8" ply
-Rob
09-03-2019, 07:59 AM
#620
champaign
I see now. If tambour doesn't suit your needs, you could kerf out a section of 1/4" thick plywood. Just kerfing out enough to make the bend, and running your kerf "with" the grain of the exposed veneer of the ply. I would do it on a table saw and set the blade at 1/8" high. I think you can buy kerfed plywood but I couldn't find it on a quick search. I know I used it on a job years ago...very floppy and bendable.
Mike
