Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 05-10-2019, 08:57 PM   #521
Magnet18's Avatar
Churubusco , Indiana
Originally Posted by cmadmaxman View Post
Trying to get used to the mobile app!
Spec from Supper steer: 1 3/4 - 2 1/2 from new bump stop to upper control arm. With my supper steer springs, right at 2 1/2 with no air bags!
Thank you!!
I'll crawl under and measure mine
Also, are there any good tricks to get the new bump stops in?
Magnet18 is offline   Reply With Quote
Old 05-10-2019, 09:09 PM   #522
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
They are a pain! Soap up the bump stop and slot. I used a small screw driver to help get the ears in. Need to blunt the end so you don't year the rubber. I did mine on the bench, and still fought it! Supersteer have some that bolt in but when I had it apart, they were out of stock.
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (274,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 05-10-2019, 09:11 PM   #523
cmadmaxman's Avatar
Tear the rubber
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 05-11-2019, 06:33 AM   #524
Magnet18's Avatar
Thanks!
I'll give the soap a try. I was hoping there was some magic trick, I spent 20 minutes under there with a screw driver and got nowhere, hardest part of the job
1983 Airstream 310 Class A Motorhome
-Rob
Old 05-11-2019, 06:35 AM   #525
Magnet18's Avatar
Originally Posted by KB6YAF View Post
Congratulations on your 'new to you' 310. It sounds like you have one nice rig.
I am also a 1983 '310' owner.
Post photos on your progress.
....Russell
Thanks!
Looks like you might have landed on the first page of my thread, note that there are about 500 posts here, with about a years worth of pictures
Yours is a sharp looking 310 as well!
-Rob
Old 05-11-2019, 11:05 PM   #526
cmadmaxman's Avatar
Hey Rob, looks like SS has the lower stops in stock again. Here is the part number and description. $22.00 ea.
SS18118 LOWER CONTROL ARM REBOUND BUMPER
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 05-12-2019, 04:26 AM   #527
mayco's Avatar
champaign , Illinois
Hey Rob, when you get to the point of getting it aligned, there is a top notch shop not too far away from you called Burke Spring in Tilton Il down by Danville. I know it's a bit of a drive for you but it may be well worth it. From what Ive been told, these older P30s are a real pain to get a correct alignment. The guys at Burke really take their time to get it right. The owner is a Motorhome owner and knows what he's doing. Just had mine done before this trip. They are also very reasonable on their pricing. I think they charged me $165 said and done. The previous shop I used did a horrible job, they supposedly specialized in large trucks, and charged $245. No hesitation in recommending Burke Spring, Google them up and see what you think. Real nice shop and easy to work with.
Mike
mayco is offline   Reply With Quote
Old 05-12-2019, 06:16 AM   #528
Magnet18's Avatar
Mike
Thanks a lot for the recommended Mike!
I really appreciate it, there's a local shop with a great owner that's right near my work, I was going to call first, but I'll definitely keep your recommendation in mind!
Old 05-14-2019, 01:17 AM   #529
Magnet18's Avatar
Friday afternoon we're driving down to southern Indiana, first big road test
I'm looking around and can't find the temp gauge sender, anyone know where it is on these rigs?
Steer safe brackets on the way, may or may not get here in time. First time I've ever had to order anything via telephone, but they were friendly
Alignment appointment for Friday
Today I got the heater core and motor reinstalled, and got the headlights replaced with these
https://www.amazon.com/dp/B079L55PX7...p_mob_ap_share
The heater core and motor were both good fits, and they work great now. Unfortunately I have to clean up the existing plumbing, a too-small pipe bent in a rough U with double hose clamps, I have no idea how they got that to seal the first time
More info on the headlights coming in a future post
ID:	340707   Click image for larger version
ID:	340709   Click image for larger version
ID:	340711   Click image for larger version
Old 05-14-2019, 09:50 AM   #530
dadstoy's Avatar
1982 28' Airstream 280
_ , _
My temp sender is on the side of the drivers side cylinder head. Donít get a cheap crap one from Autozone, etc. or you will be doing the job again.
dadstoy is offline   Reply With Quote
Old 05-14-2019, 10:40 AM   #531
Magnet18's Avatar
Thanks!
Is it this thing?
Old 05-14-2019, 10:53 AM   #532
Originally Posted by Magnet18 View Post
Thanks!
Is it this thing?
That's it.
Check to see if you have a sensor on the other head. If there is one there and it's not used you might try connecting to it to see if it works. Just a thought....
1975 24' Argosy Motor Home
Old 05-14-2019, 11:01 AM   #533
Magnet18's Avatar
Originally Posted by bkahler View Post
That's it.
Thanks, will check!
Maybe the problem is that it's painted over with just a spade connector shoved over the painted surface
Old 05-14-2019, 11:06 AM   #534
Magnet18's Avatar
If you're having trouble with the Amazon link for headlights, they're BICYACO model number 5823959790 part number XJX-1257
-Rob
Old 05-14-2019, 11:14 AM   #535
Magnet18's Avatar
It took me a few minutes to noodle through how to install the headlights, maybe I can save someone else some time.
For the top headlights, looking into the airstream connector, right is ground, bottom is high beam, left is low beam.
The adapters on top need wired as shown in the first picture. I thought they were kinda flimsy and took up space, so I used a small pointy thing to swap the pin positions around as shown in the second picture.
The bottom are used only for high beam, so I used the adapter and pulled out the unused low beam wire
ID:	340725   Click image for larger version
Old 05-14-2019, 11:21 AM   #536
Magnet18's Avatar
Lets try that link again, my phone was struggling
Normally $160 for all 4 but I got a "used" returned set for $90
-Rob
Old 05-15-2019, 10:54 PM   #537
Magnet18's Avatar
So I'm right at about 1-1/2 on the driver's side and 1-3/4 on the passenger side... Hmm...
Sitting on not necessarily perfectly level gravel and I need to double check the airbag pressure
Other than the springs and front end weight, is there anything else to look at?
Old 05-16-2019, 07:33 AM   #538
Magnet18's Avatar
Meant to attach these
ID:	340861   Click image for larger version
Old 05-18-2019, 04:59 PM   #539
Magnet18's Avatar
So Friday I got it aligned and drove about 175 miles to brown county state park
Camping in southern Indiana with some family this weekend
Pleased to report it handles great and rides better than ever, according to the wife it's a night and day difference!
ID:	341054   Click image for larger version
Old 05-18-2019, 06:36 PM   #540
dadstoy's Avatar
_ , _
Did you get a chance to use your new head lights?
Radiator Hoses for 1983 310 Billy B General Motorhome Topics 7 06-06-2016 06:59 PM
1983 310 Engine Problem Rik Mechanics Corner - Engines, Transmission & More... 7 10-28-2005 10:30 PM
1983 310 guages Bfrank General Motorhome Topics 6 07-23-2002 06:01 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
