Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 04-29-2019, 01:46 PM   #501
Magnet18's Avatar
Churubusco , Indiana
Everything including jack stands has arrived for the spring and ball joint swap except for the airbags, because when SDtrucksprings says "same day shipping, arrives in 3 days" they apparently mean "4 day shipping, arrives in 10 days", with the non-responsive customer service to match.
But the good news, I finally got the engine back in the 4runner and it fired right up! Never in a million years did I think it would go that smooth
Now that that's done, it'll get a steering rebuild, then I'll install the tow parts
Base plate: it's either the BX3715 or 3710... The years they list don't make sense and I worry they have their documentation crossed, toyota switched from SFA to IFS between 85 and 86, but they draw the line between 86 and 87.
Wiring kit: https://www.blueox.com/towing-accessories/bx8848/
And a separate 6 pin connector
I should be able to swap the brake pedal pusher over from the jeep and re-use everything else
Once I verify it tows well I'll sell the jeep, it's only a couple hundred pounds heavier than the jeep (and about 1500 pounds lighter than a new 4runner, if you were wondering)
Or more likely I'll sell the jeep anyway and tow the fit.
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 04-29-2019, 01:55 PM   #502
Magnet18's Avatar
Can't help but post some pics
ID:	339395   Click image for larger version
ID:	339397   Click image for larger version
Old 05-03-2019, 08:40 AM   #503
Magnet18's Avatar
The heater core needs to go from 3/8npt to 3/4 heater hose...
This is what I came up with, but it's dumb, there is definitely a better way
Old 05-03-2019, 09:48 AM   #504
2007 22' International CCD
Magnet18's 1983 310
Only issue with that setup is going from brass to steel could be a corrosion issue.
There are much worse examples...
rmkrum is online now   Reply With Quote
Old 05-04-2019, 05:04 PM   #505
Magnet18's Avatar
Got one side done, new ball joints and spring/airbag
Took about 6 hours, will do the other side tomorrow and see if I can cut that in half now that I know what I'm doing
ID:	339715   Click image for larger version
Old 05-05-2019, 12:43 PM   #506
1987 34.5' Airstream 345
northern IL , Illinois
Did you need the air bags with the bigger springs. I went with out when I changed to moog 6560S springs . The front end sits up high. One day I will find out if I should have put them in. It's a lot of bull work.
Hans 34.5 is offline   Reply With Quote
Old 05-05-2019, 07:48 PM   #507
Magnet18's Avatar
Not sure yet if I need them. I see various opinions. I saw a couple opinions that it handles better with them, and the springs will wear out slower. Really just opinions, but I didn't see anyone say it was *better* without so I figured I might as well put them in.
It is indeed hard work, I took the wheel off the passenger side and that's about as far as I got, yesterday was a good full body workout and I'm still wiped. Plus the weather was too good not to go enjoy.
Old 05-07-2019, 09:50 PM   #508
Magnet18's Avatar
Got the passenger side disassembled today after work
Hopefully tomorrow I can reassemble
Will start a post in the mechanical section about a steering centering setup I have that isn't compatible with the new ball joints
Old 05-09-2019, 05:57 AM   #509
Magnet18's Avatar
Finished up the install yesterday and got the motorhome dropped back down onto the tires
I didn't inflate the bags yet as I wanted to see what it would do without them
Ride height is unchanged from what it was before
Tonight I'll air up the bags and see what that does
Old 05-09-2019, 06:03 AM   #510
Magnet18's Avatar
While I was in there, I looked at the brake pads and noticed uneven wear
On both sides the outer pads were much more worn, with the drivers outer being about half the thickness of the passengers outer
Is this normal?
ID:	340220   Click image for larger version
Old 05-09-2019, 06:23 AM   #511
Kvsterling's Avatar
West Chester , Ohio
I did some brake work last year, caliper piston in rear were sticking but wear was even all around. So replaced both rear calipers, very inexpensive parts. I think it would be worth replacing your calipers with pads while you are in there. Hint: avoid Napa brake pads, heard they were garbage
Kvsterling is offline   Reply With Quote
Old 05-09-2019, 08:27 AM   #512
Magnet18's Avatar
Thanks for the info!
I ordered pads (not napa )
My calipers seem fine, borderline new even, I think I have receipts that show they are only 2ish years old. There are no pins on these, but the surfaces they slide on were very sticky and grimey, I'll clean them up and lubricate them.
-Rob
Old 05-10-2019, 01:22 PM   #513
Magnet18's Avatar
So I inflated the airbags yesterday, ride height looking better. Can't find a spec anywhere for what normal is.
Also going to order the new steer safe wheel brackets for $90 a piece. I was set to modify the existing ones but time is short so the wife encouraged me to just buy them so I don't work myself to death.
Need to get the new bump stops in, get this thing aligned, and get the new heater core in before next weekends trip, planning on putting a few hundred miles on it
-Rob
Old 05-10-2019, 01:31 PM   #514
Magnet18's Avatar
Pictures
ID:	340326   Click image for larger version
ID:	340328   Click image for larger version
Old 05-10-2019, 02:34 PM   #515
55 psi
1975 24' Argosy Motor Home
Old 05-10-2019, 02:57 PM   #516
Magnet18's Avatar
Originally Posted by bkahler View Post
55 psi
Sorry I wasn't clear!
Can't find a spec for what ride height is supposed to be
Thanks though
Old 05-10-2019, 03:32 PM   #517
KB6YAF's Avatar
2004 39' Land Yacht 390 XL 396
Shelton , Washington
Your 310
Congratulations on your 'new to you' 310. It sounds like you have one nice rig.
I am also a 1983 '310' owner.
Post photos on your progress.
....Russell
KB6YAF is offline   Reply With Quote
Old 05-10-2019, 05:05 PM   #518
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
....Russell
1 3/4 - 2 1/2 from new bump stop to upper control arm. With my supper steer springs, right at 2 1/2 with no air bags!
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (274,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 05-10-2019, 05:06 PM   #519
cmadmaxman's Avatar
I used the 5000 to 5300 springs.
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 05-10-2019, 05:10 PM   #520
cmadmaxman's Avatar
Trying to get used to the mobile app!
Spec from Supper steer: 1 3/4 - 2 1/2 from new bump stop to upper control arm. With my supper steer springs, right at 2 1/2 with no air bags!
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Radiator Hoses for 1983 310 Billy B General Motorhome Topics 7 06-06-2016 06:59 PM
1983 310 Engine Problem Rik Mechanics Corner - Engines, Transmission & More... 7 10-28-2005 10:30 PM
1983 310 guages Bfrank General Motorhome Topics 6 07-23-2002 06:01 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
