Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 12-11-2018, 11:00 PM   #401
Magnet18's Avatar
Churubusco , Indiana
Originally Posted by mayco View Post
Are you semi-permanently parked on your own property? Is there a sewer line within 100'?
Might be easier to install a proper pvc run of sewer pipe with a cleanout for your waste valves than going through the time/effort/expense of your mod. If you've got a friend with a backhoe, no big deal. Just a thought. Pretty radical mod to nix the black tank. But, it's your coach......I would have more tendency to completely change the waste handling system if I was doing a total gut and rehab. But...once again..it's your coach to do what you want.
Not my property, no sewer within 100', the sewer that is on this property is uphill.
and long term yes, semi permanent no, will only be here a couple more months max.
What I'm really doing here is turning the rig into what I want it to be, which is something that is
1. Full time
2. 4 season
3. Capable of boondocking/going off grid for a couple weeks at a time.
Also, I had to do a major overhaul anyway, the toilet didn't seal at all, and the dump valve was leaking progressively worse. Between those two I was most of the way here anyway, so might as well make the upgrade!
Magnet18 is offline   Reply With Quote
Old 12-12-2018, 02:52 AM   #402
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
The vent line going to the roof is used by the black & gray tanks, so you should keep the line, but you can probably trim it back to a convenient location. I would still leave a EZ way to reconnect it at some time in the future.
You may want to insulate under the floor where the black tank was, that should cut down on unfriendly breezes when you are "sitting and reading"
Do not take life too seriously.
You will never get out of it alive.
WayneG is offline   Reply With Quote
Old 12-12-2018, 07:16 AM   #403
Magnet18's Avatar
One page further wayne, the 310 has a separate vent for each tank.
If I keep it, which I probably will, I need to figure out a good way to cap it on the roof so it doesn't fill with rain
Old 12-12-2018, 01:50 PM   #404
Magnet18's Avatar
Actually, if I put in a small second grey tank underneath, I think I can hook the vent back up and it'll be perfect for draining the washer dryer. I think, still learning the plumbing.
1983 Airstream 310 Class A Motorhome
-Rob
Old 12-16-2018, 08:58 PM   #405
Magnet18's Avatar
This came in last week. I think I have a plan, just need to execute. We'll see if it goes in this week, or after Christmas. Pulled a couple really late nights installing the head, trying not to work myself to death
Old 12-17-2018, 01:46 AM   #406
WayneG's Avatar
Scotia , New York
Maybe you need to tow a small Bambi for all your gear, or has anyone tried to put a slideout in a classic MH yet?
Old 12-17-2018, 05:31 AM   #407
Magnet18's Avatar
If I ever find a junker slideout model...
This was part of the woodstove install plan from the beginning. It'll fit perfectly right here.
I've decided not to replace the black tank. It's polyethylene, which means cutting it and gluing it together is a non-starter, nothing glues polyethylene, and I don't feel like trying. All the standard black tanks I find are only 5 or 6 gallons, not worth the effort.
The black tank was 200lbs when full, which happens to be equal to the combined weight of the washer and the woodstove. So it'll drive about like having a full black tank, which, when the grey tank was empty, wasn't much of a problem. Or like having a large human passenger use the restroom while driving, also not really a problem.
This should be the last of my "gear" additions for quite some time. Next up is solar/lithium/generator, and that'll be a few months down the road.
Old 12-20-2018, 11:08 AM   #408
Magnet18's Avatar
Bookmarking this here just for my future reference
https://www.czarfloors.com/item_deta...xoCOcsQAvD_BwE
-Rob
Old 12-20-2018, 05:35 PM   #409
Magnet18's Avatar
Tin cieling tiles showed up!
I think it looks quite good, and more importantly, the wife thinks it looks quite good
I also think that will look era appropriate, anybody who lived through 1983 want to chime in?
-Rob
Old 12-20-2018, 06:05 PM   #410
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
UG, UG, UG; Rob you're killing me. The 80's weren't the heyday of good taste or quality you know; Google, 1982 Corvette, or even 1983 Corvette for an even better example; or 2.5l Iron duke engine.
The flooring in the link below is Luxury Vinyl Plank (LVP) flooring. This is what I should have used in my 310, but will use in the Argosy and Minuet. It is impervious to moisture, extremely scuff and scratch resistant; can be laid down (just glue the perimeter), or glue the whole floor. To replace a piece that somehow gets damaged, just use a heat gun to loosen glue, lift out plank and replace with new piece.
Scroll up in the link for samples....
This stuff is beautiful......
http://xlflooring.ca/products/flexiplank/
Cheers
Sidekick Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 12-20-2018, 08:27 PM   #411
Magnet18's Avatar
Cheers
Sidekick Tony
It occurs to me that I've never really covered my other projects on here.
Attached, Joni's '78 mustang, my '86 4runner, and my 80s (technically '90) mustang
I would also be quite happy to find myself with a Toyota mr2 turbo, or a lotus esperit type 82
Out of no intentional motive, I've ended up with quite the collection of 80s project
Back on topic, I've gotten myself rather attached to the parquet thing, but Joni couldn't care less, so given how few options there are, I'll probably cave and install a regular type floor in the spring. Most I don't want it to look out of place, the same reason Bob exclusively uses polished brass fittings.
I see that LVT highly recommend by yourself and elsewhere, so I'll see about ordering a few samples and stick them in front of the furnace vents as a torture test to see how they hold up. That's where my current stickers tiles are rolling over and dying. (Highest thermal cycling, from forty to one hundred something degrees when the furnace kicks on)
ID:	330070   Click image for larger version
Old 12-20-2018, 08:30 PM   #412
Magnet18's Avatar
And the Iron duke!!
Yea, there's a reason Jonis 78 has a totally rebuilt engine
-Rob
Old 12-20-2018, 08:33 PM   #413
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Hmmm.....polished brass, even the soap/shampoo dispenser in the shower.....thatís whatís taking the washer/dryer install so long.....finding a 4Ē polished brass tub spout to drain the washer......jeezzzzzz.......Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 12-20-2018, 09:15 PM   #414
Magnet18's Avatar
So whoever's taking a shower at the end of the wash cycle gets a nice surprise
-Rob
Old 12-20-2018, 09:18 PM   #415
Magnet18's Avatar
I'm an idiot, forgot to attach the picture
Old 12-21-2018, 07:53 AM   #416
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I am a recent convert but now big fan of LVT. We just had 1500sqft of Amtico honey oak parquet installed at home.....I just pity to poor two guys who spent 6 days on their hands and knees laying it!
martin300662 is offline   Reply With Quote
Old 12-25-2018, 12:26 PM   #417
Magnet18's Avatar
Merry Christmas everybody!
I ordered some LVT samples, will evaluate, thanks Martin and Tony
-Rob
Old 01-07-2019, 01:46 PM   #418
Magnet18's Avatar
Quick and dirty minor upgrade to the broken barrel chair
Not sure I like it being on wheels, but the wife does
Also, happy belated new year everyone!
Old 01-07-2019, 02:02 PM   #419
WayneG's Avatar
Scotia , New York
When my knee went bad, I pulled one of the dinette bench seats and did this:
It was a life saver, for a easy place to sit just inside the door. I saved all the parts for the next owner, but I liked the office chair, and probably would have kept it like that, all I needed was a little filler for the missing carpet
Old 01-07-2019, 02:59 PM   #420
Magnet18's Avatar
Looks like a good solution to me!
I've never been fond of dinettes, i find they get uncomfortable quickly and they take up a lot of space. And, as you said, they're hard to get in and out of.
Wife and I both think the barrel chairs are really comfortable, and like the original look, so I transplanted the hardware. I guess it's fairly standardized, which was a nice surprise
Radiator Hoses for 1983 310 Billy B General Motorhome Topics 7 06-06-2016 06:59 PM
1983 310 Engine Problem Rik Mechanics Corner - Engines, Transmission & More... 7 10-28-2005 10:30 PM
1983 310 guages Bfrank General Motorhome Topics 6 07-23-2002 06:01 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
