Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 08-08-2018, 06:04 AM   #241
Magnet18's Avatar
Churubusco , Indiana
Slow n steady
Magnet18 is offline   Reply With Quote
Old 08-08-2018, 04:59 PM   #242
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Take your time with the plywood spacing under the shower base. Use a hole saw to make the hole for the drain and stand in it before you finalize the install. Also a good time to seal up any holes to the underneath while youíre there.
bobmiller1 is offline   Reply With Quote
Old 08-09-2018, 06:15 AM   #243
Magnet18's Avatar
Thanks Bob, will do
I think part of the reason this one cracked was because it wasn't lined up from the factory
Got the floor prepped yesterday:
Pull all the staples and carpet remnants
Use the spackle stuff
Sand the spackle stuff
Paint with latex sealer
Today i should be able to lay down the vinyl tiles, or get started at least
Old 08-09-2018, 01:53 PM   #244
bobmiller1's Avatar
Yes....apparently the factory has had a problem with lining things up for quite a while...itís even apparent on the new cabinets that they manufacture. But then again, what do I know....I only sell screwdrivers. Regards, Bob
Old 08-09-2018, 04:51 PM   #245
1986 34.5' Airstream 345
Alliance , Ohio
I thought you sold wrenches too!
mehes is offline   Reply With Quote
Old 08-09-2018, 08:55 PM   #246
Magnet18's Avatar
Going down pretty well (used a chalk line, see our previous conversation about things being lined up, was a good idea, the couch is crooked )
I definitely think I got the early 80s look I was going for!
Old 08-11-2018, 10:52 AM   #247
Magnet18's Avatar
Got the floor down!
Still need to trim it
ID:	319581   Click image for larger version
Old 08-11-2018, 11:51 AM   #248
bobmiller1's Avatar
Great idea on the shoe holder on the door.....mind if I copy that ???? Is your couch crooked to the floor ???
Old 08-11-2018, 01:46 PM   #249
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Bob sells wrenches but talk
about a Sodomi charge wow😲😲😝
shepherd57 is offline   Reply With Quote
Old 08-12-2018, 07:47 AM   #250
Magnet18's Avatar
Go for it, we copied it from someone else, LOL
Baseboard on the couch was not parallel to the centerline of the airstream
Old 08-12-2018, 08:33 AM   #251
bobmiller1's Avatar
LOL, Regards, Bob
Old 08-12-2018, 08:44 AM   #252
Magnet18's Avatar
Spent the rest of yesterday cleaning up and installing the post holders for the little tables, and fighting plumbing
Replaced the runs to the shower
Got a detla cartridge holder/cartridge combo... Got home and oops, it was just a cartridge holder, went to home Depot with the part number, employee tries telling me I need to call delta and there's no way he can help me because there's sooooooo many cartridge options... 30seconds on google with the part number tells me it fits 13/14/1300/1400/1700 series cartridges
Grab one of those... It's supposed to control temp and flor rate... It only controls temp, flow is always on!
The first univetsal trim kit I got was actually moen, so I went back for a delta one... It doesn't fit either...
Plumbing...
1983 Airstream 310 Class A Motorhome
-Rob
Old 08-13-2018, 06:12 AM   #253
Magnet18's Avatar
Fixed another factory flaw...
The top shelf in the pantry, it was sagging
Turns out, of the 4 holes supposed to have rivets in them, there was only ONE rivet in the corner... Good job airstream
Old 08-13-2018, 07:51 AM   #254
My first thought was road vibration caused the rivets to fall out but after looking closer it doesn't appear there was ever anything in those holes. I guess I shouldn't be to surprised
1975 24' Argosy Motor Home
Old 08-13-2018, 09:33 AM   #255
Magnet18's Avatar
That was my thought as well, but there were no holes
The one in the corner you see is my replacement, that one had fallen out, causing the back corner to sag
Old 08-13-2018, 01:46 PM   #256
Magnet18's Avatar
Found the way back in the recesses under the cabinets... Anybody recognize it?
Old 08-13-2018, 02:30 PM   #257
bobmiller1's Avatar
Stove control knob cover ??
Old 08-13-2018, 03:00 PM   #258
Magnet18's Avatar
Could be, I tried seeing if it fit on either the microwave or stove and it didn't seem to...
definitely an original knob or cover of some sort.
-Rob
Old 08-13-2018, 04:30 PM   #259
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
I think it's the top cover of the filtered water faucet. Is your filtered water faucet still in place?
mayco is offline   Reply With Quote
Old 08-13-2018, 04:41 PM   #260
Magnet18's Avatar
It's been replaced, so that would make sense.
Does anyone want it? If not, it's trash to me I guess
-Rob
Radiator Hoses for 1983 310 Billy B General Motorhome Topics 7 06-06-2016 06:59 PM
1983 310 Engine Problem Rik Mechanics Corner - Engines, Transmission & More... 7 10-28-2005 10:30 PM
1983 310 guages Bfrank General Motorhome Topics 6 07-23-2002 06:01 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
