Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 07-23-2018, 06:26 AM   #201
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Originally Posted by Magnet18 View Post
Thanks, let me know if you find the motor. I'm pretty sure this one only died when it was left on while I was working on the wiring and the batteries got too low, when there wasn't enough juice to spin it but still enough to melt a winding. Probably how a lot of originals died.
You've got 2 fantastic/maxair sized fans in your 310? Was that standard? I just have one in the kitchen area, would love to install a second.
Or did you install a maxair in the shower/bathroom? Because that is also something that sounds like an upgrade
Ya it must have been an option to order the second fan, it's in the rear bedroom area. It's nice having one blowing in and one out. Ill look for that motor today.
mayco is offline   Reply With Quote
Old 07-23-2018, 05:35 PM   #202
mayco's Avatar
I found that motor for the exhaust fan, with the blade.
Old 07-23-2018, 09:02 PM   #203
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
If you want a second fan in the bedroom area, it can be done......carefully; and I can't stress enough the carefully part. Two 120volt lines run through that area and there is a big bundle of 12 volt lines on the passenger side (looking towards the front of the coach) of your cut. HOWEVER, the good news is Airstream pre wired 12 volt for the additional fan when building these coaches, even if only one fan was chosen.
Since I'm playing catch up with Mayco all the time, it was only a matter of time that I'd risk cutting the outside skin open in order to put a fan in like Mike's. I'm very glad I did it. Use a Fein saw and only cut into the skin to the depth of the aluminum, or you'll cut some wires.
Post 1417
http://www.airforums.com/forums/f311...75428-102.html
Cheers
Sidekick Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 07-24-2018, 06:52 AM   #204
Magnet18's Avatar
Churubusco , Indiana
PM sent
Magnet18 is offline   Reply With Quote
Old 07-24-2018, 06:58 AM   #205
Magnet18's Avatar
Post 1417
Cheers
Sidekick Tony
Looks like a worthwhile upgrade, maybe when I get around to solar and am spending a bunch of time on the roof anyway!
1983 Airstream 310 Class A Motorhome
-Rob
Old 07-24-2018, 03:20 PM   #206
mayco's Avatar
Here are a few pics of that motor. You're welcome to it. You will eventually want a multi speed reversible fan in your rig, I guarantee it. But if this will get you by until you get around to that then have at it. They are pretty tough little motors.
ID:	317934Click image for larger version
ID:	317935Click image for larger version
Old 07-24-2018, 11:07 PM   #207
Magnet18's Avatar
Thanks!
I really appreciate it, but are we talking the same fan?
That looks like one of the original big ones, I'm looking for the little guys with the squirrel cage type that go in the bathroom and shower, I'm not sure that one will fit
-Rob
Old 07-25-2018, 01:45 AM   #208
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
Thanks!
The fan in the picture above is definitely a full size vent fan. You may have to buy the complete unit as shown in one of the replies above. I dont know if the motor can easily be swapped in one of those.
When the motor in mine went bad, I bought the entire unit, figuring I would just swap the motor, but I ended up on scraping vulkem and using the entire new unit.
Do not take life too seriously.
You will never get out of it alive.
WayneG is offline   Reply With Quote
Old 07-25-2018, 07:15 AM   #209
mayco's Avatar
Thanks!
The one I have is out of the bigger vent but I think they use the same motor. Don't know for sure though. Ya I spaced out that you were doing the small ones.
Old 07-25-2018, 09:40 AM   #210
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
I think the fan are looking for is made by Vent Line I think they are available through Trailer supply.com . I got 2 for my coach from them
shepherd57 is offline   Reply With Quote
Old 07-27-2018, 01:23 PM   #211
Magnet18's Avatar
Started a Polishing thread!
http://www.airforums.com/forums/f441...ml#post2134825
... Starting to think I have too many irons in the fire...
Nah
Old 07-30-2018, 12:35 AM   #212
Magnet18's Avatar
Crap
I'm assuming shower pans aren't readily available...
Bob replaced his, was that a custom job?
Wondering if tig welding an aluminum replacement would be the easiest
Old 07-30-2018, 04:23 AM   #213
WayneG's Avatar
Scotia , New York
Depending on if it can be accessed from below or removed without destroying it, if there is a way to add filler to the bottom, it may look like new again.
I would bet that removing it will destroy the assembly.
The roof of my shower has long cracks in the curved section and other than to drill stop holes, I am leaving it alone until Home Depot sells one that fits like the OEM shower!
Maybe some sort of surface repair will keep it going?
Old 07-30-2018, 05:30 AM   #214
Crap
You are correct, shower pans are not available. If I remember right Bob had his custom made which is about the only option available that I know of.
If you're still looking for a fan/motor I found the ones I removed from the 345. You can have one if you're interested.
1975 24' Argosy Motor Home
Old 07-30-2018, 07:59 AM   #215
Magnet18's Avatar
Brad, fan would be awesome, I'll trade you for the door lock plate, shoot me a picture and your address when you get a chance
I might call a couple of places up in Elkhart to get an idea of what it would cost, but if a tig welder is cheaper, i have a sheet metal brake and a new shop press calling my name...
Old 07-30-2018, 08:09 AM   #216
Magnet18's Avatar
Some backstory on the shower as a warning to others
At some point yesterday the bathroom sink was accidentally left dripping, and the grey tank was already pretty full. Pretty sure that's why the shower was almost full of water when I got home. I had always suspected the shower had a slow weep/leak, and that the floor under it would need replaced, but i think all that weight cracked it open right there. Carpet in the kitchen/bathroom is still damp feeling this morning, despite getting as much out with towels as possible and having a fan on it last night.
This might expedite my new floor plans
This afternoon I'll do my best to seal it up with trempro635 and see if we can limp it along a couple weeks
On the bright side, at least I don't have a gmc palm beach with a single tank and much lower shower threshold.. that mess would have been significantly worse
Old 07-30-2018, 11:44 AM   #217
If I'm not mistaken the shower pan is made from ABS plastic. Assuming it is you can repair the crack with a slurry made from MEK and ABS pellets. It may not be pretty but it should be effective.
Repairing would be the same process used to repair the front and rear banana wraps.
Definitely worth trying.
Oh yeah, underneath your shower pan is most likely a sheet of particle board so you can just about bet on the fact that the particle board is now swollen
Old 07-30-2018, 12:15 PM   #218
Magnet18's Avatar
Yea, i could tell when I bought the motorhome whatever was under there had sagged and needed replaced. Surprised it's just particle board though, not OSB or plywood??
I totally blanked on trying ABS/MEK, thanks for the reminder!
Old 07-30-2018, 10:18 PM   #219
Magnet18's Avatar
Went to move today and noticed the exhaust was way louder on the passenger side... Fixed that
Also front AC now only works on low settings, probably either the selector switch or the start capacitor, will dig in further, need to climb up and unclog the drain anyway
Also think I'm gonna replace the jeep with a Honda fit
Old 08-01-2018, 12:03 AM   #220
Magnet18's Avatar
Got the shower pan out
http://www.airforums.com/forums/f311...al-185030.html
You'll notice there's an overflow pipe outside the shower in the pantry... This is dumb. So very very dumb.
Come on airstream. Should we have an overflow valve that dumps water outside? Nah, let's dump in in the compartment the 120to12v converter sits in, in the kitchen.
Seriously. Dumbest thing I've seen yet.
I need to fix this.
Radiator Hoses for 1983 310 Billy B General Motorhome Topics 7 06-06-2016 06:59 PM
1983 310 Engine Problem Rik Mechanics Corner - Engines, Transmission & More... 7 10-28-2005 10:30 PM
1983 310 guages Bfrank General Motorhome Topics 6 07-23-2002 06:01 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
