Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 02-27-2017, 09:57 AM   #1
jkwoodrow
1987 34.5' Airstream 345
Springfield , Ohio
Low Coolant indicator
Despite my efforts to fix it, my Low Coolant light still comes on. I cleaned the tank and the two screws inside and out which provide connection terminals for the wires and a path for the fluid inside to short the wires that should keep the indicator happy. That didn't work. I then connected both wires to one terminal which should eliminate the problem, but it didn't.
I'm looking for suggestions about where to go from here!
John Woodrow is offline   Reply With Quote
Old 02-27-2017, 04:56 PM   #2
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Take the bulb out ! .....only kidding, I believe that those wires are ground wires....so you need to check where those wires go to. One may be shorted or ipen
bobmiller1 is offline   Reply With Quote
Old 02-28-2017, 08:14 AM   #3
jkwoodrow
Springfield , Ohio
Bob,
I was able to unearth a prior discussion on the forum about this issue via Google. Discussions talked about their being some type of voltage step down unit to power the gauges at 5 volts which apparently is failure prone and also apparently unavailable. I'll have to dig deeper into that. Your suggestion of removing the bulb might be the right answer.
Old 02-28-2017, 08:49 AM   #4
1989 34.5' Airstream 345
Ebro , Fla Panhandle
After many stops to check and find correct fluid levels, with the light coming on repetedly. And efforts to fix the problem.
I did pull the bulb from the dash.
Still have a working temp gauge that doesn't make me stop all the time.
Let us know if you are able to sort it out.
Cheers Richard
tevake is offline   Reply With Quote
Old 02-28-2017, 09:05 AM   #5
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
John - I think that is stock chevvy wiring or was it an Airstream add-on? If the former, there is a section on the electrical wiring diagram for bulb faults etc in the Chevy wiring diagram manual. I posted a link in the sticky (post 94). That might help you fault find. Good luck.
Boom Sounds is offline   Reply With Quote
Low Coolant Sensor guy99 General Motorhome Topics 27 10-14-2013 10:47 AM
Low Coolant warning light Robfike General Motorhome Topics 14 11-28-2010 05:30 PM
Low Coolant Sensor Mustangmatt Classic Motorhomes 5 07-13-2009 07:35 AM
How long should the Low Coolant light stay on. rdm Mechanics Corner - Engines, Transmission & More... 7 06-01-2004 09:04 PM
Help with Coolant Level winner Mechanics Corner - Engines, Transmission & More... 6 04-24-2002 04:47 AM
