Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 05-04-2021, 08:58 PM   #1
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Looking for correct spark plug wires for 454
Hi all, Iíve been searching for the correct spark plug wires.
They have long section of hard rubber protector on the plug end. The part that attaches to the distributor has a 90 degree terminal with a protrusion on the top of that terminal That engages a ring that clips into the top of the distributor and secures the wires into the distributor.
Iím looking for the correct parts number for these spark plug wires.
Ive got a couple of pics to help you see what Iím hunting.
tevake is offline   Reply With Quote
Old 05-04-2021, 09:09 PM   #2
ITSNO60's Avatar
Tucson , AZ
Any hot rod shop will have those.....Jegs has many options https://www.jegs.com/webapp/wcs/stor...ark+plug+wires
Brian
ITSNO60 is offline   Reply With Quote
Old 05-04-2021, 09:16 PM   #3
Thanks, Iíve all ready checked at the local parts place. And ordered a set for 454 from ac daleco. Not the right part.
Here is the top of the distributor for a look.
Old 05-04-2021, 09:20 PM   #4
Thanks Brian, those on the link you sent look like they may work.
Iíll have to see if there is a Jegs nearby.
Old 05-05-2021, 07:45 AM   #5
ITSNO60's Avatar
Tucson , AZ
I don't think Jegs or Summit Racing have actual brick & Mortar stores, don't you have a speed shop or hot rod shop near you? Also check with a marine place if you have one, 454's were popular in speed boats. Or just order from Jegs and return if not what you want. I am familiar with the way they clip on to the distributor cap with the flat cover, had a few big blocks in my day, the ones in the pic from Jegs sure look like the ones.
Brian
Old 05-05-2021, 11:29 AM   #6
Yep no Jegs stores around here. So it looks like mail ordering is in store .
I'm reluctant to keep ordering unknown parts by the look of them.
Anyone else know of the correct parts number for these wires.
Cheers Richard
Old 05-05-2021, 11:37 AM   #7
1982 31' Airstream 310
Henniker , New Hampshire
I have Bosch 09603 wires on my 502. I bought mine from Amazon.com Should be the same as your 454.
1982 310 motorhome 502
Henniker New Hampshire
chiefair is offline   Reply With Quote
Old 05-05-2021, 12:07 PM   #8
amxpress's Avatar
2021 22' Bambi
Clayton , North Carolina
Try rockauto.com
They offer Premium and often performance quality spark plug wires from various manufacturers.
amxpress is offline   Reply With Quote
Old 05-05-2021, 02:06 PM   #9
Icy
2010 22' Sport
Sarnia , Ontario
I'm a retire GM mechanic and electronics was my specialty. I would go to a GM dealer and talk to the oldest parts man in the parts department. He should be able to find the proper wires. You should also think about a new cap and rotor.
Pete
Icy is offline   Reply With Quote
Old 07-06-2021, 06:00 AM   #10
Roby466's Avatar
1988 34.5' Airstream 345
Halifax , Nova Scotia
I got all from Napa. Their home brand for wires, cap, and rotor. I went to AC Delco plugs.
Roby466 is offline   Reply With Quote
Old 07-12-2021, 09:45 PM   #11
345bill's Avatar
Las Vegas , Nevada
These are the ones for my 1990 345LE according to our local parts store. They are obviously different than the ones in your picture but I'm sure the ring will still snap on the top of the distributor cap.
ACD part # is 9618V
GM # is 88862383
Hope this helps. Click image for larger version
Name:	AC DELCO IGN WIRES.jpg
345bill is offline   Reply With Quote
Weird question, what causes wires to spark when connected to 12v? cgseanp Electrical - Systems, Generators, Batteries & Solar 2 06-29-2018 01:32 PM
454 Spark Plug suggestion? Keyair Mechanics Corner - Engines, Transmission & More... 15 12-08-2017 02:30 PM
Ford spark plug problem? AnnieD Tow Vehicles 10 12-24-2009 10:28 PM
1975 Argosy MH 454 proper spark plug gap? cejohnsonjr Mechanics Corner - Engines, Transmission & More... 2 04-21-2006 11:17 PM
Burning Spark Plug Wires geodude1958 Mechanics Corner - Engines, Transmission & More... 10 07-10-2005 08:58 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
