12-29-2017, 10:25 AM
1986 34.5' Airstream 345
Londonderry
, New Hampshire
It's cold, the anti-freeze is frozen!
It is 7 degrees F here in New Hampshire and the antifreeze is frozen!
It was below 0 over night.
Pete.
12-29-2017, 10:34 AM
Mantua
, Ohio
Wow! Did not know that could happen!
12-29-2017, 10:35 AM
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
I'd say that is sufficient evidence to move south, but that's just me.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
12-29-2017, 10:42 AM
1988 Argosy 32
Lomita
Change your ZIP CODE Quick, its 78 in so cal ?.
12-29-2017, 11:11 AM
Oswego
Is it a brick, or shush? My understanding is it doesn't freeze solid till the stated temp.
-Rich-
12-29-2017, 11:27 AM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
The tires are the best way to heat an Airstream.
Key West 78 right now, with 68 for a low this week.......
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
12-29-2017, 11:33 AM
Tampa
It's cold here too!
I'm thinking of putting on a sweatshirt when going outside.
12-29-2017, 11:34 AM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
Attachment 301584
Pete.
I'd contact the company and if you do, post what they respond with. I can't read the bottle, but does it say where it's manufactured? If China I am not surprised at all as I used to use Chinese manufactured products "to our specs" when I was GM at a company and we had to have engineers to check every shipment as they change the specs often to what they want to make.
Bud
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
12-29-2017, 12:44 PM
Reads a lot
Titusville
Well dang! Hope you didn’t put any of that into your car/truck/motorhome/etc. On a more serious note: thank you for reminding all of us to double check where and when the anti-freeze made. Always buy the best you can afford is what my dad used to say but nowadays spending more money on stuff doesn’t always mean it’s the best.
Lauri
She Believed She Could so She Did.
12-29-2017, 01:17 PM
Londonderry
, New Hampshire
It is like a block of solid with some liquid. I think that it would
be OK to protect piping and tanks from splitting. But it would not work
if you wanted anything to flow like in an engine cooling system.
Pete.
12-29-2017, 01:21 PM
1984 27' Airstream 270
Scotia
, New York
With the wonderful NE weather I think I will do a test.
I have 1/2 a jug of Super Tech brand RV antifreeze that is claimed to be made in the USA and the jug says it is good to -50F
Last night it was -3 and I expect similar tonight.
We will see!
12-29-2017, 01:30 PM
Sag Harbor
, New York
Pete.
What does the label say? This says safe to -50F:
https://www.amazon.com/Winter-eez-Ma.../dp/B001G2PDRG
Yes the stuff turns to slush at first.
12-29-2017, 01:52 PM
Lakes Region
, New Hampshire
Clearly you are in the southern part of the state, it didn't get above 4° where I am.
12-29-2017, 02:07 PM
1994 34' Excella
Warren
, Manitoba
You folks are in the warm belt. It is -13F right now with a wind chill of -37F. Tonight is will be -24F and wind chill of -43F. We are in "southern" Manitoba!!!
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
12-29-2017, 02:10 PM
Airstream - Other
Bosque Farms
, New Mexico
The question is not whether it freezes. It's whether it expands when frozen.
Lynn
ACI Big Red Number 21043
12-29-2017, 02:18 PM
Scotia
, New York
Lynn
To test that, one would need a full jug, and maybe top it off to the cap with more AF.
Then take something like masking tape that does not stretch and wrap it around the jug. then do the freeze test and see if the tape or jug splits
12-29-2017, 02:32 PM
Airstream - Other
Bosque Farms
, New Mexico
Yep, or just set a brand new one outside with sealed lid overnight to see what happens.
When we had the RV park in Angel Fire (ski area), we saw that pretty commonly. Folks would bring the stuff and be amazed. (Those same people were under the impression that just adding some to their black/gray tanks was going to make a difference. It didn't. The tanks usually survived, but the exposed pipes still froze solid, often with damage.)
Lynn
12-31-2017, 12:52 PM
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
It's designed to freeze but not expand.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
12-31-2017, 02:58 PM
Dazed and Confused
Hillsburgh
, Ontario
Yeah, it's a wee bit chilly outside right now.
The Mistress is in deep hibernation with my making sure her batteries are in +50% mode.
I use automotive coolant straight in the toilet and -45 windshield fluid in the traps.
Cheers
Tony
01-01-2018, 07:02 AM
Scotia
, New York
It was -5 last night and my 1/2 jug of -50 RV AF is frozen solid.
So I would say that if it is frozen solid at -5 then -50 on the label is false advertising!
I cant tell if there is any swelling of the jug.
Even if it does not expand, frozen solid AF will give you problems with operating valves or the water pump. I bet if you tried to flex a plastic water line, you may crack it?
