I was able to repair the circuit board for the inside/outside temperature gauge. And now at least the inside temp is working. However, the outside just reads -1.
Does anyone know where that sensor lives?
I found the inside sensor. Its hanging just near/behind the ice maker.
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
The sensor was indeed where yall mentioned. However, the sensor checked out and I had to move back to the board for further troubleshooting. Tracked the problem down to a bad diode. Now I got back to fully operational!
The photos I have are not that good. The first shows the back of the board. The second is of the transistor that burned out. I replaced that transistor along with 1 or 2 of the diodes that I found were not functioning. However, I dont recall which ones were failing.
