Old 05-29-2020, 11:46 AM   #1
1990 35' Airstream 350
London , California
Hydraulic levelling issue
Hi all , I am new here and based in the UK . I have a 1990 350 LE classsic Motorhomes . I have a leak from the hydraulic levelling system. It’s the small piston that pushes the leg into its down position. The leak is coming from the area of the bolt on the end . Upon removal the casing is cracked Does anyone know where I can get this replacement part even if it’s a used one of do you think it could be repaired ? I am really struggling . Also does someone know where the fluid top up is located ? The hydraulic pipes all go back to a behind a box which is on the arch behind the passenger front wheel . But it seems to me that you have to take the front wheel off to get to it and remove the casing . Surely the top up isn’t hidden in there ? The fluid leaking out is red like transmission or power steering fluid . There is a big cylinder tank infront of the radiator but I had always assumed this was power steering fluid . Could it also supply the levelling system aswell ? Any help appreciated
UKman is offline   Reply With Quote
Old 05-29-2020, 06:03 PM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Can you give us some info on the brand of your system? I have manuals for some of the older systems but I don't think the jacks have changed much. Pictures also help. The pump and reservoir can be mounted in different places. My 345 is in the left front wheel well and fun to add oil but I have done it without removing the wheel.
Cheers, Dan
~ Margaret Thatcher ~
Old 05-30-2020, 04:58 AM   #3
London , California
Hi , thanks so much for replying . I think I have found the actuator I need . I am not sure but think all my levelling is hwh . I think the heh part I need is rap4079 . However they quote a lead time of 5 weeks then posting to Uk on top . Any ideas who might stock it ?But still struggling on location of my top up tank and what to put in it . The fluid coming out is red line transmission or steering fluid ? Have attached pics
ID:	368920   Click image for larger version
ID:	368922   Click image for larger version
Old 05-30-2020, 11:41 AM   #4
Here is a list of their jack parts. https://www.hwhcorp.com/ml11428-24.pdf
That part number is for a 9000 lb. jack which is a bit of overkill but my 345 has 6 jacks so who knows.
This outfit carries a lot of HWH parts. http://rvleveling.com/index.html or this one http://www.nwrvsupply.com/category/158.html
Good luck
Cheers, Dan
Old 05-31-2020, 05:58 AM   #5
Airstream Driver
PeterH-Airstreamer's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 51
Originally Posted by UKman View Post
Hi all , I am new here and based in the UK . I have a 1990 350 LE classsic Motorhomes . I have a leak from the hydraulic levelling system. Itís the small piston that pushes the leg into its down position. The leak is coming from the area of the bolt on the end . Upon removal the casing is cracked Does anyone know where I can get this replacement part even if itís a used one of do you think it could be repaired ? I am really struggling . Also does someone know where the fluid top up is located ? The hydraulic pipes all go back to a behind a box which is on the arch behind the passenger front wheel . But it seems to me that you have to take the front wheel off to get to it and remove the casing . Surely the top up isnít hidden in there ? The fluid leaking out is red like transmission or power steering fluid . There is a big cylinder tank infront of the radiator but I had always assumed this was power steering fluid . Could it also supply the levelling system aswell ? Any help appreciated
No, the power steering system is separate from the leveling system
Step 1
Retract all four jacks fully.
Step 2
Locate the hydraulic power unit including the pump and reservoir tank. on the 350, the pump will be located behind the axle of the front drivers wheel and accessible from beneath the vehicle. Its protected by a plastic box screwed down with self tapping screws. The reservoir is a long tank with a chrome breather cap on top containing an integrated dipstick.
Step 3
Wipe off any dirt from around the breather cap. Unscrew the breather cap and remove it from the reservoir, then wipe the dipstick clean and reinsert into the tank. Remove the dipstick again and read the oil level. Proper oil level should appear in the range between the two scribed lines on the dipstick.
Step 4
Add HWH Specialty hydraulic oil or Dexron-style automatic transmission fluid to the reservoir if necessary. Bring the oil level up to approximately 1 inch below the top of the reservoir.
Re-install the breather cap.
1992 350LE Classic Motorhome
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 05-31-2020, 12:17 PM   #6
London , California
Thank you that is a great help . Really appreciate it
Old 05-31-2020, 12:30 PM   #7
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Welcome to the forum.
You may want to reach out to BoomSounds (Nick) who is also in the UK and is fighting his HWH system since a front wheel blow-out on his 250. Could be an opportunity to share info.
As for me, an Argosy level system is basic, if your bed is sloping downhill, sleep the other way around. If this doesn't work move the motorhome!
martin300662 is offline   Reply With Quote
Old 05-31-2020, 02:55 PM   #8
Airstream Driver
1994 30' Excella
Images: 51
I am the one to thank you, since your inquiry made me look closer and take the cover off. My tank was 1 1/2 (one and half) quarts low .
Since i do not see any leaks, I suspect that somebody in the past replaced one of levelers that may have been leaking for some time. And you know how the story goes, it was a long day that day and the system worked again, so no reason also pull the tire and the pump/tank cover to check the fluid....if they knew where the tank was located.
AIR #13
Old 06-01-2020, 05:01 AM   #9
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Hi - I have a 1991 250 with the same set up. In fact, I think I have the HWH manual. Let me dig it out and upload it. Whereabouts are you based?
Boom Sounds is offline   Reply With Quote
350LE levelling hydraulics issue UKman General Repair Forum 0 05-28-2020 06:58 AM
Conquering GM's Auto Levelling System Pat Cassity Tow Vehicles 16 02-13-2015 11:42 AM
Air levelling valves and Shocks shepherd57 Classic Motorhomes 4 04-10-2013 06:34 PM
Spring Bars too tight? And Automatic Levelling Suspension Question lbrownah Hitches, Couplers & Balls 5 04-30-2010 05:22 PM
Land Yacht Air Levelling Mod porourke Jacks, Stabilizers, Lifting and Leveling 1 07-05-2009 10:21 AM
