Old 11-25-2017, 09:49 PM   #1
1987 34.5' Airstream 345
northern IL , Illinois
Fuel pump gas feed line
Hello
I'm in need of this gas feed line. Can't find one anyone have a good idea on a replacement. It's 1/2''
Maybe some push lock hose -08
Hans 34.5 is offline   Reply With Quote
Old 11-25-2017, 10:12 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Fuel line is special hose material suitable for handling fuel. Fortunately, it is a standard item stocked by auto parts stores. They can cut you a piece to legnth.
  1. Take that one off.
  2. Take it to an auto parts store (NAPA, Auto Zone, O'Reilly, etc...)
  3. Tell them it's fuel line and it needs to be replaced.
By taking in the old one, they will be able to make sure that they are getting you the correct diameter and length. You may also want to get new clamps. If yours are ok you can reuse them, just be sure and check.
Vaughan
Old 11-26-2017, 09:15 AM   #3
It would be nice to find the stock molded hose that it is.
Tight bend in this spot.
Old 11-26-2017, 09:20 AM   #4
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
While you are at it, do the small return line also.
Be prepared for some cuts, scrapes, and cuss words while getting it back together!
WayneG is offline   Reply With Quote
Old 11-26-2017, 09:58 AM   #5
I started with the fuel tank and worked my way to the front and all the rubber hose was junk. Yes I will be replacing it all.
Your taking a big chance NOT doing it in this big and old of a MO.
I do not want to be on the side of the road because of a fuel line or a fire from old fuel lines.
Old 11-26-2017, 10:04 AM   #6
WayneG's Avatar
Scotia , New York
If you do the whole system, there should be some short sections of rubber where they spliced the steel lines along the frame. My splices were just before the rear wheels, of course in a knuckle buster location!
Old 11-26-2017, 10:05 AM   #7
Push-Lock Hose Specifications
Product
Number
Inner
Diameter
Outer
Diameter
Maximum
Working Pressure
Minimum
Burst Pressure
Minimum
Bend Radius
3384-04
1/4"
0.50"
250 psi
1,000 psi
3"
3384-06
3/8"
0.62"
250 psi
1,000 psi
3"
3384-08
1/2"
0.75"
250 psi
1,000 psi
5"
3384-10
5/8"
0.91"
250 psi
1,000 psi
6"
3384-12
3/4"
1.03"
250 psi
1,000 psi
7"
Old 11-26-2017, 10:13 AM   #8
Yes it was a pain that's all done. I had the fuel tank out more pain. You would think it should have been one steel line from front to back. I think they thought the MO would be long gone to scrap in 10 years.
Old 11-26-2017, 10:21 AM   #9
Good job Hans.
Yes, its a PITA, but has to be done.
One area that most miss is the joint that is ABOVE the tag axle....
On my '84, there was one, and as I tried to remove the rubber line from the the electric pump to the rear hard line, the hard line pulled out of that joint! I could not see it nor reinstall it, so I ran a new hardline to the next joint and deleted that section....
Let me see if i can find some pics.
Old 11-26-2017, 10:30 AM   #10
Page #107, Post #1489 in my thread.
If the pics are not showing for you, install the PhotoBucket unblock extension on Chrome or Firefox, or I will post them here for you.
Old 11-26-2017, 10:37 AM   #11
Good job Hans.
And it goes from 3/8 to 1/2 in that spot molded line again. I made up some brass fitting to do that. 3/8 should be fine from front to back with the kicker pump pushing fuel up to the engine.
Old 06-29-2019, 05:37 AM   #12
1986 34.5' Airstream 345
Londonderry , New Hampshire
Did you ever find the correct replacement hose?
That is the hose that I need to replace. I have done
everything else, just need that one.
Air345Fly is offline   Reply With Quote
Old 06-29-2019, 11:35 PM   #13
No I never found one. I think I used push lock hose.
Gas feed to fridge Relentless LP Gas, Piping, Tanks & Regulators 5 05-01-2012 09:08 AM
Fuel Line & Fuel Tank crazeevw Mechanics Corner - Engines, Transmission & More... 4 12-02-2011 07:38 PM
Need pictures of gas line for Magic Chief oven gas connection dghaas General Repair Forum 1 01-30-2009 09:04 PM
12 volt feed line dead - HELP! 3Ms75Argosy Electrical - Systems, Generators, Batteries & Solar 18 08-01-2005 09:57 AM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
