12-30-2021, 11:03 AM
1989 34.5' Airstream 345
Kingsland
Fuel Issue
Im out on another trip/adventure in the Silver Slug! And this time the MH seems to be living up to its name. I drove for almost 6 hours yesterday and the further I got the more difficult it was to go up hills! It was clearly a fuel delivery issue as pushing on the gas pedal would cause the engine to hesitate and lose power. One hill was so steep we were going 30mph when we crossed it.
At this point Im planning to replace fuel filters followed by pumps (I have an aux pump back by the tank). Not sure what else the trouble might be, but I figured it wouldnt hurt to ask here.
thanks,
Aaron
12-30-2021, 12:12 PM
2007 27' Safari FB SE
NW Oregon in a nice spot
, Oregon
If the fuel filters don't do it check the pick up screen on the fuel pump. I had a similar experience on an older tow vehicle and the filter change did the trick. Mechanic who saved me said they see it all the time on vehicles that don't get driven much, then do a lot when traveling and it stirs up any "stuff" on the bottom of the tanks. Good luck.
12-30-2021, 12:32 PM
Houstatlantavegas
, Malebolgia
Let's keep guessing....check the exhaust, do it sound rite, do it hiss a fit, the cat converter, or just a plain old muffler may be coming apart and choking things up a bit.
“It’s the American Dream, but you have to be asleep to believe it.”
George Carlin
12-31-2021, 06:44 AM
Kingsland
Will check the screen.
Good point on the exhaust. Although for most of the drive I had turned on my aux fuel pump. At one point I had decided it wasnt helping and turned it off. The slug immediately started lugging so I turned it back on. Ill still check for something fishy there though.
thanks,
Aaron
12-31-2021, 08:22 AM
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
The slug is getting to an age that the tank starts to rust and debris blocks the filters. Expect to drop the tank and inspect if you see any debris in the lines.
12-31-2021, 10:24 AM
1984 31' Airstream310
Honokaa
, Hawaii
Don't rule out an ignition issuel. Your HEI distributor is a nice piece of engineering and it contains most of your ignition system. But, it's probably original. We had very similar symptoms from a failing ignition coil.
12-31-2021, 11:49 AM
1986 25' Sovereign
Allegan
, Michigan
Also check the fuel tank evaporative emission system. They can be somewhat complicated but should not allow too much vacuum in the tank; it will act like a poorly performing fuel pump. I had a mid 80's vehicle with an intermittent problem that a couple of shops (including a dealer) could not diagnose. I finally caught it on a back road when the car died - no fuel in the carb. I uncapped the gas tank and a big whoosh of air went in. Car ran fine with a loose cap on the tank.
Good luck,
Whit nash
01-03-2022, 06:15 AM
Kingsland
Well, the mystery will remain.
I pulled the fuel filters and they breathed just fine. I had a local mechanic drop by and he suggested taking it for a spin to let him see the symptom first hand. And of course it ran fine.
I also made it home without issue yesterday. 5+ hours and the only issue is the run-on when I try and shut it off.
thanks,
Aaron
01-03-2022, 06:36 AM
Oswego
thanks,
Aaron
Is this an HEI distributor engine?
-Rich-
01-03-2022, 07:31 AM
2014 19' International
2014 Interstate Ext. Coach
Cedar Rapids
, Iowa
First bet is your cat is plugged. Second distributor issue. Sometimes worn plug wires will cause this issue but it’s usually a plugged catalytic converter.
01-03-2022, 07:46 AM
Oswego
Reason I asked, I had an 85 Chevy van. I had the exact same symptoms as you, but eventually resulted in very intermittent stalling. I SWORE it felt like fuel. It was rust on the reluctor wheel down on the bottom of the distributor. No missing, just low power sometimes, like starving for fuel.
Take a flashlight , remove the cap and look way down deep, below the flyweight plate and if it is coated with fur, replace distributor.
-Rich-
01-04-2022, 08:39 AM
Richmond
, Kentucky
No catalytic converters on the motorhomes.....
1975 24' Argosy Motor Home
01-04-2022, 04:16 PM
1991 35' Airstream 350
Columbia
, Tennessee
Yep, not until 1991, then it was a cat behind the muffler.
Sent from my SM-G950U1 using Airstream Forums mobile app
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (276,000 and still going  )
01-14-2022, 06:46 AM
1984 32.5' Airstream 325
Gainesville
interesting...
I have been having intermittent stalling on mine for a year or so with no one being able to figure it out.
I was led down the path of fuel problems, but as my (very experienced) father-in-law used to say... 95% of fuel problems are electric  The fuel filter when we got her (the one mid rig) was on back to front...(yeesh), but have not dropped the tank yet... apparently a screen or filter in there as well.
The idea that rust' in the distributor would cause failure makes sense - just have to figure out how to replace it (if needed) without screwing up the timing.
Since replacing the old and cracked spark plug leads, plugs and running 2.5 bottles of Seafoam though her, she fires up without pushing the gas peddle... first crank.. every time. I really hope it's the distributor (84 454) - a relatively cheap repair.
Thanks -
Pete
01-14-2022, 07:03 AM
Columbia
, Tennessee
When the summit distributor weighs fell apart, I installed this HEI Fast distributor. Has been trouble free so far. I'm sure the price has gone up quite a bit, but don't go cheap, not worth it!
AIR Member 12654
1991 350LE "Zephyr"
01-15-2022, 03:42 PM
Kingsland
FINALLY got out there and pulled the distributor. It IS an HEI distributor, but nothing looked suspicious with the cap off. I didnt take the rotor off though. It cant hurt to just replace it though.
The above is not currently in stock.
Jegs seem like a decent replacement?
https://www.jegs.com/i/JEGS/555/40042/10002/-1
Ill probably replace sparkers and wires at the same time. What is the recommended plug at this point?
thanks,
Aaron
01-15-2022, 04:02 PM
1982 28' Airstream 280
_
, _
Rockauto.com
Distributor - Cardone 841845 $96.79 no core charge NEW unit, in stock
I replaced mine last October with this unit from RockAuto. Works well. Same part # is used in your '89.
I use regular plugs, whatever I can get. I don't waste money on RACE CAR plugs for an engine that doesn't turn over 4000 RPMs and is expected to burn oil.
thanks,
Aaron
01-18-2022, 05:55 AM
Richmond
, Kentucky
Originally Posted by dadstoy
....I use regular plugs, whatever I can get. I don't waste money on RACE CAR plugs for an engine that doesn't turn over 4000 RPMs and is expected to burn oil.
Built in Mosquito control feature comes with coach at no additional charge
01-22-2022, 01:18 PM
Kingsland
Distributor arrived in the last couple days. Ill get that installed tomorrow and see if I run into the issue again.
Just need to plan another trip now to test it!
Aaron
01-23-2022, 06:18 PM
Gainesville
Moving forward as well
Well, Im moving in the same direction.
After multiple (3) doses of Seafoam and getting better compression each time, I then replaced the spark plugs and leads. Progressively sounding at the end of that process.
After reading the notes here I also decided to change out the distributor. I brought it without looking too closely at the old one but after pulling it out noticed a reasonable amount of surface oxidation under the rotor and further down on the shaft. Hopefully the images show that. I'd be interested to hear if it's a similar level of 'fluff or fur' as noted by others.
Anyway the good news was the 1. she started right up (as in I didn't screw up the timing in the process) and 2. both my wife and son immediately said she sounded a LOT smoother running. I also did but thought I might have been wanting improvement so bad I might have been imagining it
So far so good. just need to order new air bags before a trial run. Hopefully there's plenty of Information in the forums to guide that process.
Cheers all -
Pete
thanks,
Aaron
