Old 01-18-2019, 04:13 PM   #1
SpiceStream's Avatar
1984 31' Airstream310
Sullivan , Wisconsin
Far back window latch on 310
Does anyone have a good picture of how the flat window latch works on the farthest back window in the bedroom on a 1984 310? Mine is screwed shut, I unscrewed it and I think there must be a piece missing, something cylindrical to lock into the red latch Bar? also, is there normally a screen on that window? how does that work?
Thank you,
Curt
SpiceStream is offline   Reply With Quote
Old 01-18-2019, 05:04 PM   #2
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
The latch is the same as your bathroom window latch; two on each corner of the window; flip inside hands towards you to release tension on the lock, then rotate until flat bar is out of the groove in the window frame.
As far as the screen goes; yes I have a screen with five or so inches of the screen retainer moulding hanging down. In case of fire, pull screen retainer moulding out and screen will fall out to allow you to go out the window.
Too cold to go outside and take pictures.
Cheers
Sidekick Tony
Old 01-21-2019, 08:58 AM   #3
Tony,
Interesting, I think I am missing a bunch of hardware, I was thinking it would be great if this window worked like the bathroom, but the extend of my hardware is a red bar that connects to nothing, and two rusty screws.
Add it to the list.
Thank you,
Curt
Old 01-21-2019, 11:39 AM   #4
1987 34.5' Airstream 345
northern IL , Illinois
Are you talking about the emergency exit the red bar is at the bottom of the glass.
Hans 34.5 is offline   Reply With Quote
Old 01-21-2019, 12:18 PM   #5
Yes, that is the window I am referring to.
Old 01-21-2019, 12:48 PM   #6
Waipio Rim's Avatar
Honokaa , Hawaii
Our ‘84 just has the red bar. I wouldn’t want to have to mess with extra latches if I had to get out.
Waipio Rim is offline   Reply With Quote
Old 01-22-2019, 10:24 AM   #7
That must be the system I have, no latches, but the red bar does not engage with anything on the window, without the screws holding it shut from the outside it just flops around like a mackerel.
Curt
Old 01-22-2019, 12:07 PM   #8
Waipio Rim's Avatar
Honokaa , Hawaii
On ours the red bar latches onto something in the window frame. Pull it (in, I think) hard, and the window is open. Can’t go look now, the coach is far away. Good thing you are looking at it, screwed shut from the outside sounds like a bad idea. On our last trip my wife and I had a safety drill to make sure that we both were able to open that window.
Old 01-22-2019, 12:50 PM   #9
sraab928's Avatar
1991 35' Airstream 350
Merritt Island , Florida
Curt
Ill take a picture of mine later today - its on a 350 but sounds like the same style.
Scott
sraab928 is offline   Reply With Quote
Old 01-22-2019, 01:52 PM   #10
sraab928's Avatar
Here you go. Hope this helps
ID:	332179   Click image for larger version
ID:	332181   Click image for larger version
Scott
Old 01-22-2019, 01:52 PM   #11
sraab928's Avatar
One more
Scott
Convert vintage door latch to modern double rotary latch & strike? Mixter Doors & Locks 5 02-19-2017 09:12 AM
1982 turbo diesel 310 :: 2013 Airstream turbo diesel 310 mayco Airstream Registry Discussions 1 07-28-2015 11:58 AM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 09:52 AM
Far, far, away.... Terry C. Tullier Our Community 19 07-26-2005 09:42 PM
