Old 04-22-2020, 12:22 PM   #1
Tucson , Arizona
External Roof Refinish/Platicoating
Greetings Folks,
Iím beginning to pre-pare for the next project on the Magic Bus.
The exterior roof, including down to about the double black stripes on the top of the sides of the bus are needing attention. Our Bus is NOT a polished finish, and we would like to keep it the original external finish.
My Objective:
1) Use some form of plastic cote(Iíve been told to use Henry 100% silicone Tropi-cool roof coating) to cover the top of the Bus. Weíve been told it can reduce internal temps (in Tucson that's IMPORTANT!).
2) Refinish JUST THE TOP Edges of the exterior where the clear coat is messed up.
(See Pics of the roof).
The steps I THINK I need to take are:
1) Plastic-cote
a. Wash Bus thoroughly
b. ??? re-seal around the vents etc with some form of sealant (Dicor?).
c. Cover VERY top rectangle panels of the Bus with Henry Tropi-cool.
THOUGHTS? Is this the correct approach or am I missing something?
2) Refinishing the roof edges
a. Strip the current clear coating from JUST the top of the bus, from the tops of the windows and UP using Citrus stripper. (Is there a better product to use?)
b. Wash/Clean residual from area stripped.
c. Walbernize: apply the solution in a back and forth motion (not circular).
Again, Any THOUGHTS on what I'm planning on doing?
Will these steps achieve my goal of having a cooler/plastic coated, lovely refinished external roof?
Thanks All !
Todd
Co-Pilot, Magic Bus
ID:	366310   Click image for larger version
ID:	366312   Click image for larger version
Toddnazus is offline   Reply With Quote
Old 04-22-2020, 12:52 PM   #2
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Todd, last summer I cleaned and coated the aluminum roof on our sunroom with a silicone roof coating. The stuff is amazing, dries quickly and provides a monolithic coat. I cleaned it first with a roof cleaner then applied two coats of the silicone with a double-wide roller. I got all the materials at the local Menardís.
ID:	366321   Click image for larger version
2019 27í Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Exterior Refinish Help Steve Cherry Cleaning, Stripping & Polishing 5 04-27-2020 10:03 AM
External Antennae - Best Roof Placement Location dhroberts Computers, Internet & Satellite 14 03-23-2018 05:23 PM
Cabinet refinish recommendations bighowdytex Cabinets, Counter Tops & Furnishings 6 02-12-2008 01:37 PM
Interior Refinish/repairs? jayeh1 Upholstery, Blinds, Walls & Interior Finishes 26 07-09-2005 11:36 AM
Bath Molded Plastic Refinish ClassicRides General Interior Topics 8 10-20-2004 11:56 AM
