Old 09-14-2018, 06:25 PM   #1
1985 34.5' Airstream 345
Snoqualmie , Washington
Electrical Questions
Hi, I have a 1985, 345 MH that I am trying to solve some electrical problems on. I don't have 12v to the air comp., refer, seats, etc when the ign switch is in the run or acces. position. I have been using an airstream MH service manual dated 1987-1989, it shows a relay which power a bus bar with a bunch of circuit breakers that put power to these accessories so that they are powered by the alternator and eng. batt. when driving.
Question? Does my 1985 345 have this relay and circuit breakers?
If so where is it? If not where do these accessories draw power from when driving? Do the draw power thru the ign switch?
The manual I have is called: Owners-Service Manual, Motor Home 1987/1988
It was printed by Airstream and is a very complete service manual.
Is a similar manual available for 1985?
I will try to attach a copy of page H6 from the manual showing the set-up I am talking about.
Thanking you in advance, I am Sincerly, John
Snopack is offline   Reply With Quote
Old 09-15-2018, 05:56 AM   #2
Here are a couple of links to the 84 to 86 owners and service manuals for the 310, 325 and 345 models.
84-86 service manual
84-86 owners manual
1975 24' Argosy Motor Home
bkahler is online now   Reply With Quote
Old 09-15-2018, 06:51 AM   #3
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
It’s in the front hatch engine bay on mine. Look high up near driver wiper motor. Suggest you check the grounds on the solenoid or even replace it. Cheap fix and that would either solve it or rule that out.
Boom Sounds is offline   Reply With Quote
Old 09-15-2018, 06:54 AM   #4
Also, run the test procedure in the Surepower blue fin isolator. Procedure probably in manuals Brad posted. Straightforward test and will rule that in or out. Check your grounds. You should be able to follow the current from your batteries through to that 12v bar and solenoid
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 07:24 PM
Questions, Questions, Questions LowellN Repairing/Replacing Floor &/or Frame 5 10-28-2004 07:23 PM
Help! Bubble Electrical Questions 58BUBBLE Electrical - Systems, Generators, Batteries & Solar 3 08-27-2004 12:49 PM
IVOLT?electrical questions. Please help! chasgould Electrical - Systems, Generators, Batteries & Solar 4 12-04-2003 06:01 AM
Installing an Inteli-power & other electrical questions Towster Electrical - Systems, Generators, Batteries & Solar 7 08-07-2003 05:04 PM
