RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-19-2020, 01:48 AM   #1
1994 36' Classic 36
Henderson , Nevada
Does anyone else have 90’s classic motorhomes?
Silver Bell’s maiden voyage was very eventful. I will post more later. While dry camping I tried to microwave breakfast while making coffee. Pop. Fuse blew somewhere. Tried the panel above the bed. Not energized. The gfi wouldn’t test. The genny is running perfect and the next day shore power 30A everything worked. In the trunk there are two boxes with switches or auto switches or something like that. Could that be damaged?
1994 classic 36’ Vegas
ID:	381247   Click image for larger version
ID:	381249   Click image for larger version
Patatat is offline   Reply With Quote
Old 10-20-2020, 10:35 AM   #2
1994 36' Classic 36
Henderson , Nevada
My wife and I were blessed by getting our ‘94 Classic 36’ at auction. Only 51,000 miles. The Silver Bell. My awesome wife remodeled the interior and I got it running, new tires, new radiator, and got the generator going again. I love the classics but I don’t see many like mine from the 90’s.
ID:	381309   Click image for larger version
ID:	381311   Click image for larger version
ID:	381313   Click image for larger version
ID:	381315   Click image for larger version
ID:	381317   Click image for larger version
ID:	381319   Click image for larger version
Old 10-20-2020, 01:01 PM   #3
Magnet18's Avatar
Churubusco , Indiana
There are a few 90s classic owners on here for sure. Those are nice units, with the factory fuel injection and 4 speed.
I love the interior you went with, it looks like my parents 78 GMC palm beach!
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 10-20-2020, 02:16 PM   #4
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Welcome to the insanity.....I mean forum. You have a great unit.....not sure about the green interior though, I’m one of the few remaining purists. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 10-20-2020, 03:36 PM   #5
1995 36' Classic 36
Ludington , Michigan
We like our 95 360 so much we bought a 94. A true manifestation of Einstein’s alleged definition of insanity.
Kota is offline   Reply With Quote
Old 10-20-2020, 04:29 PM   #6
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 51
In 1993 Airstream redesigned the Classic Motorhome for the first time since it started with the Argosy models in the 70's. Long overdue improvements to the windows may have let to the redesign of the nose. Mechanically a much desired diesel pusher was added to the gasoline powered line up that lasted until 1996.
In the early 90's Airstream added the factory fuel injection and started to offer the 4l80e 4 speed transmission first as an option and then standard equipment.
As I mentioned to you that I had more info on your electrical system, I want to follow up on that since you started your own thread.
The 90's models have three transfer switches that control how the 110v system operates.
The power from the generator takes over via the first transfer switch. Its the boss, regardless of being plugged in or not. Since it is 30/20 amp it will let you run both of your AC's at the same time. A selector switch should let you choose between front AC and Micro wave. As you found out, you always have to vigilant of what you use in the kitchen at the same time.
The second transfer switch only kicks in , if the generator is not running but you plugged into a 30 amp shore line. 30 amp will only let you run 1 AC at a time or just the Microwave, very limited. Thats why some of us converted to 50 amp shore power or added an additional 30 amp for the rear AC
The third transfer switch in the 90's classics only gets activated with no shore power and no generator, but with the built-in 12v to 110V inverter turned on. It will power only 1 outlet in the Kitchen for small appliance use, but will not power the Microwave or AC
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 10-21-2020, 08:00 AM   #7
1986 34.5' Airstream 345
Alliance , Ohio
Check for a tripped breaker on the generator itself.
mehes is offline   Reply With Quote
Does anyone else have personalized plates on their Airstream? mybmwk1200lt Airstream Lifestyle 103 09-19-2019 07:13 AM
Does anyone else hate camp fires? Wayne&Sam On The Road... 573 05-02-2014 07:43 PM
Does anyone else own a 1959 Ambassador? Andrew Selking 1959 - 1965 Ambassador 24 10-31-2012 11:51 PM
Does anyone else Own a 2010 Int'l?? THEPILL 2006 - 2010 International 36 08-28-2010 12:40 AM
Does anyone else suck heads? azflycaster Stella's Kitchen 45 08-18-2008 07:07 AM
