Old 11-06-2019, 08:43 PM   #1
Jenniflow's Avatar
1982 34' Limited
1986 34.5' Airstream 345
Sioux Falls , South Dakota
Send a message via Skype™ to Jenniflow
Do you have one of these switches?
Ours doesnít appear to operate anything. Itís also inadequately attached to the wall, but thatís probably beside the point.
Itís over the counter between the stove top and the sink.
Do you have one? What does it do?
Thanks!
Jenniflow
sent from my hipflask
Jenniflow is offline   Reply With Quote
Old 11-06-2019, 09:00 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Are you talking about the switch that looks like a regular light switch? Could be the load shed switch. Also, looks loose on the wall... cut off the AC power and get that fixed/ safe
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-06-2019, 09:58 PM   #3
Jenniflow's Avatar
1982 34' Limited
Hey CWF, yes, thatís the one I mean. Whatís a load shed switch?
Old 11-07-2019, 05:20 AM   #4
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 51
Attachment 355738
Thanks!
Jenniflow
Since it appears to be an original switch, I could be the front AC/Microwave selector switch. Typically they are labeled.
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 11-07-2019, 05:39 AM   #5
Alliance , Ohio
I believe it operates an outlet under the counter which was meant for an Instahot hot water dispenser.
mehes is offline   Reply With Quote
Old 11-07-2019, 06:26 AM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
A ďload shedĒ is a way to turn off electric power load when peak demand is needed. In an AS, on 30 AMP shore power, a convenient switch was installed, usually in upper cabinet, to turn off Appliances when you need to run a hairdryer, etc. then flip back on when done.
As above, may be the water heater near the sink... but for sure, get that safety issue fixed before you have a short then maybe fire.
Channing
WBCCI# 30676
Old 11-07-2019, 08:53 AM   #7
Jenniflow's Avatar
1982 34' Limited
Question Which switches do what over kitchen counter?
We have the big selector switch just above that in the cabinet for each a/cs, microwave, etc. so it seems odd that they would have an additional switch on the countertop for that a/c - microwave toggle.
I didn't know they also offered an instahot water heater!
But I do know they also offered a trash compactor.
And we did have the built-in blender that we never used. We just removed it. Apparently it wasn't obvious which switch, if any, was controlling it.
But then there's another DC switch below it that I thought Joe knew the use of and now I hear he doesn't. So the top one looks like an AC switch, the other looks like a DC switch.
Would one of the hot-water, blender, trash-compactor options be DC and the others AC?
Old 11-07-2019, 09:10 AM   #8
Vintage Only
1966 26' Overlander
1981 31' Excella Limited
1964 22' Safari
Ramona , California
I believe it may divert load either to the air conditioner or to some of the outlets (including one that typically powers a microwave in the "appliance garage"
1966 Overlander, 1981 Excella II, 1964 Safari (for sale)
kenfconnor is offline   Reply With Quote
Old 11-07-2019, 09:15 AM   #9
Vintage Only
1966 26' Overlander
1964 22' Safari
Ramona , California
Outlet located here. Switch above sink. One position sends the power to the air conditioner and turns off several outlets. Took me about a year to figure this out!Click image for larger version
Old 11-07-2019, 09:33 AM   #10
fwjumper's Avatar
1998 34' Limited
Lawrenceville , Georgia
What He Said
Instant Water Heater for coffee/tea, etc. Ours still works.
fwjumper is offline   Reply With Quote
Old 11-07-2019, 10:35 AM   #11
1987 34.5' Airstream 345
Auckland , New Zealand
Jen, pretty conclusive as above JFG and Mehes.
My top switch like yours but has its sticker still on it staying guff about Hot Water Ellement.
The double AC socket below that single switch seems to have an Earth Leakage isolator attatched to it in the wall, I guess because its in a wet area and it may thoe I havent followed the wires but may be conected to the outside double AC mid ship.
That dam light rocker switch is a trap for the unwary it isolates the passageway overhead light, as you prob know.
I dont know what that dark bottle is used for cant help you there:}
Rus
Voltair is offline   Reply With Quote
Old 11-07-2019, 01:06 PM   #12
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Lance is correct, instant hot water switch......that is ......10 minutes after you turn the switch on....,providing that you are either hooked to shore power or have the generator running.....I think I covered all the bases...Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 11-07-2019, 11:42 PM   #13
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Jeeps - you have answered something which has stumped me for over ten years. I have an electrical outlet under the sink and a blank switch just inside my entry door on the 250. I have never figured out the purpose of either. Killed two birds with one stone. Result.
Boom Sounds is offline   Reply With Quote
Have you seen one of these? Happycampers Integrity 5th Wheel (all Years) 15 09-16-2009 06:57 AM
Where do I find one of these light switches? wacnstac Electrical - Systems, Generators, Batteries & Solar 10 04-16-2006 10:23 AM
Have you Seen one of These? steelbird312 Our Community 3 01-16-2006 01:12 PM
Have you seen one of these? fabofabo Our Community 13 03-24-2005 01:10 PM
Have you ever seen one of these Dave Bowers On The Road... 7 01-11-2003 12:37 PM
