12-01-2019, 08:54 PM
#101
"Alumi-holic"
1982 31' Airstream 310
Bartlett
, Tennessee
12-02-2019, 05:50 AM
#102
1984 27' Airstream 270
West Chester
, Ohio
Originally Posted by cesalie2
Did you install the 3rd dump valve near the combined outlet?
Yep, going to replace the dump cap with this
12-02-2019, 08:34 AM
#103
"Alumi-holic"
Bartlett
, Tennessee
Nice!
12-14-2019, 06:57 AM
#104
"Alumi-holic"
Bartlett
, Tennessee
Fan Clutch failing...
Seems the fan clutch stays locked up, the roar of the radiator fan is constant.
Ordered a Spal 16” electric fan, Derale thermostatic control, Cole Hersee continuous duty solenoid and SeaDog Resettable Fuse.
Some of the parts arrived yesterday so let’s take that sucker out...
Installed fan, thermostatic control and fuse...awaiting solenoid.
Merry Christmas!
12-14-2019, 07:30 AM
#105
West Chester
, Ohio
How many Amps does your alternator put out? I am curious what the draw is with the electric fan. My alternator belt squeals like a SOB whenever load is increased (like when trying to start generator when engine is running). Belt tension seems good
12-14-2019, 08:59 AM
#106
"Alumi-holic"
Bartlett
, Tennessee
Kyle,
Re Alternator output, Not sure, have to check...
Wanted to solve fan clutch issue, OEM cost was equivalent to electric fan, control, solenoid and resettable fuse.
12-15-2019, 01:58 PM
#107
"Alumi-holic"
Bartlett
, Tennessee
Cole Hersee Continuous Duty Solenoid arrived in the mail.
Installed, wired up and fired up. Adjusted the thermostatic control to come on about 190 degrees. Initial startup in driveway, all appears to be working.
Will take the coach out for a test drive tomorrow...
12-15-2019, 04:34 PM
#108
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
dont mean to worry you, but you may want to check your isolator connections. The wire on the right, which should go to either the coach or motor battery looks awful small. Center is typically the feed from the alternator.
AIR #13
12-15-2019, 06:42 PM
#109
"Alumi-holic"
Bartlett
, Tennessee
Peter,
Thank you for the “heads up”!
Daniel
01-28-2020, 08:12 AM
#110
"Alumi-holic"
Bartlett
, Tennessee
Have chased my issue with intermittent “misfires” under load.
Checked many of the obvious components since last August, but could not identify the culprit...until now.
On our trip to JAX, tach started intermittently reading 4000 rpm at 60 mph. Replaced the HEI Ignition Module...travelled additional 1000 miles and no misfires!
So happy!
02-03-2020, 09:29 AM
#111
"Alumi-holic"
Bartlett
, Tennessee
Inspired by Dave’s (Ontheroadagain) recent Gearvendor install, ordered unit and awaiting arrival. [emoji4]
02-04-2020, 10:00 AM
#112
Richmond
, Kentucky
1975 24' Argosy Motor Home
02-11-2020, 02:40 PM
#113
"Alumi-holic"
Bartlett
, Tennessee
Whew!
Gearvendors overdrive arrived late last week and install completed. Replaced all the u-joints and center bearings as well.
Test drive at 60 mph, rpm about 2400.
Looking forward to a longer drive as we will visit Natchez for a week.
02-11-2020, 03:02 PM
#114
Airstream Driver
1994 30' Excella
Austin
congrats!!
AIR #13
02-11-2020, 05:52 PM
#115
Tulsa
, Oklahoma
You'll love it. Mine got even smoother after I got the driveline angles corrected. Mine were off. Learned WAY more than I imagined, working with 3 driveshafts!
02-11-2020, 06:31 PM
#116
"Alumi-holic"
Bartlett
, Tennessee
Dave,
What symptoms did you experience with the angles being “off”?
02-12-2020, 07:43 AM
#117
Tulsa
, Oklahoma
It was a slight rumble under a load around 50 - 55 MPH. It was hard to feel it from the drivers seat but I could hear it. Always had it, didn't get it till everything was right for it to show up. Thought it was just the road conditions sometimes until I installed the Gear-Vendors and they talked about driveline angles/vibrations. I bought a digital protractor and found out the u-joint operating angles were not canceling each other out like they should. Finally found some help here to fix it.
https://www.gmcmi.com/wp-content/uploads/2014/05/P30-Chassis-Manual.pdf
Go down to appendix 4. 4-2 is 3 piece drivelines. A lot of stuff there along with the GV install instructions about drivelines.
02-12-2020, 11:01 AM
#118
"Alumi-holic"
Bartlett
, Tennessee
Thank you sir!
02-13-2020, 02:41 PM
#119
"Alumi-holic"
Bartlett
, Tennessee
Dan,
Thank you for the link...useful information.
Operating angles, working angle, inclinometer, carpenter square, shaft cancellation theory, phasing...oh my brain hurts!
Although all looked good on paper, felt a vibration manifesting as a “slight bounce”.
As I replaced all u-joints, both center support bearings and had the driveshaft balanced...what else remains?
“Slap forehead”, the transmission mount is probably original from 1982. Quick run to the parts store, the new mount is 1” taller. An hour under the coach to install the mount...next test drive showed a marked improvement.
More to come...
02-21-2020, 01:54 PM
#120
"Alumi-holic"
Bartlett
, Tennessee
