11-11-2019, 02:07 PM
#81
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Originally Posted by bkahler
No one ever responded to this post about 3D printed tracks when I posted it back on September 25th so I just assumed no one was interested. I currently have enough printed to do about 10 windows. I can print more it's just not a fast process.
Brad, I missed that post and would be very interested pending visual and ownership of my new toy. I will post on that thread as well.
AIR #13
11-11-2019, 02:31 PM
#82
"Alumi-holic"
1982 31' Airstream 310
Bartlett
, Tennessee
Interested, will buy any you can spare!
[emoji3]
11-11-2019, 04:44 PM
#83
champaign
I'm still pondering that leak around the gray tank. Does anyone know where the influent fitting is on that tank, top or side?
Did it stop or is it still leaking? Does it leak regardless of the fluid level in the tank? You can open the doors on your sink base and get a peak at the floor at the rear of the furnace for any signs of water, same thing on the base cabinet under the oven next to the bathroom wall. Just seems like an odd thing for the tank to leak up high unless it's at the fitting. But still, I wouldn't think it would leak there unless you had an awfully full tank. Do you notice it more when the shower is running or when you dump a sink full of water? Thinking out loud here.
11-12-2019, 06:33 AM
#84
"Alumi-holic"
Bartlett
, Tennessee
Mayco
“I'm still pondering that leak around the gray tank.
A: I couldn’t see anything from below.
A: I drained the tanks before departing Thibodaux, LA...no leak since Sunday (gray tank is approx 1/4 per original tank monitor)
A: Not leaking currently. When I noticed the leak Saturday night, the gray tank monitor read 3/4...who knows how full it really was...
A: at the time I noticed the leak, opened the cabinet under the sink and using wife’s big makeup mirror lit up the whole area and did not see any signs of moisture. Checked under the stove as well, no signs of moisture.
A: we use a small plastic basin (about a gallon) for soap water when doing dishes...dumped several basins down the sink...no leaks. Inspected water lines and drain pipes under sink as well, no signs of leaking. Will check when shower is running today.
Thinking out loud here.”
11-12-2019, 06:50 AM
#85
"Alumi-holic"
Bartlett
, Tennessee
I think I may have a crack at the top of the tank...something like this example from Youtube...
11-12-2019, 06:51 AM
#86
"Alumi-holic"
Bartlett
, Tennessee
Upon return home next week, will start investigating...
Not looking forward to this “stinky” job [emoji13]
11-12-2019, 12:32 PM
#87
Richmond
, Kentucky
Yuk.....
1975 24' Argosy Motor Home
11-13-2019, 09:47 AM
#88
"Alumi-holic"
Bartlett
, Tennessee
Side project...installed 1500 watt Pure Sine Wave Inverter for the household refrigerator while traveling down the road.
11-13-2019, 02:13 PM
#89
Airstream Driver
1994 30' Excella
Austin
brilliant, did you have to run a fat supply wire ?
AIR #13
11-14-2019, 03:43 PM
#90
"Alumi-holic"
Bartlett
, Tennessee
2 gauge
11-14-2019, 04:04 PM
#91
champaign
That’s a really smart idea, never seen that done with the household/120v fridge dedication.
11-14-2019, 05:00 PM
#92
Airstream Driver
1994 30' Excella
Austin
2 gauge
running directly to the batteries, I assume. Depending on the size of your fridge, it could use 400-600 watts continously, with short peaks of triple that. Will your alternator and the wiring from the alt to the batteries be able to keep up? Just curious, I am sure you ran your numbers?
AIR #13
11-15-2019, 12:57 PM
#93
"Alumi-holic"
Bartlett
, Tennessee
Hope so...
2 GC Batteries (215 AH)
In our shakedown cruise battery voltage dropped to 12.3 volts after several hours.
11-25-2019, 07:37 PM
#94
"Alumi-holic"
Bartlett
, Tennessee
I’m an Idiot?
We’re home from our trip to Louisiana...added quite a few small “to do” items to the list and started working on some of them...
Good news: what I thought was a leak from the top of the gray tank turned out to be the disconnected P Trap under the bathroom sink...over time it unscrewed itself and was leaking.
Bad news: where the gray tank connects to the Thetford Sewer Valve is cracked.. Am thinking of using Keyair’s MEK & ABS slurry to effect a repair.
Okay, back to the “I’m an Idiot” story...went out to the coach to run the generator, work the AC units and test the carb and timing adjustments I made yesterday...opened up the exterior door, primed the generator and hit the start switch. The generator ran as long as I held down the start switch, once I released the switch the generator shut off. Started troubleshooting...
Oil level good
Grounded oil pressure switch, started generator, no joy
Checked relays, resistor, No joy
Had to go for a long walk with DW and the pooches and had a sudden thought, no it couldn’t be, could it?
Came back to the coach and sure enough the inside Generator Start Switch was stuck in the Stop position! Moved the switch to the center position, went outside and pressed the Start Switch...the generator started and ran perfectly.
Oh my!
11-26-2019, 06:33 AM
#95
Richmond
, Kentucky
Sounds like it might be time to replace a switch!
It's always nice when it turns out to be something simple
11-26-2019, 06:50 AM
#96
1984 27' Airstream 270
West Chester
, Ohio
Would be great if a new switch fixes the symptom. I believe I have an extra gen switch, PM me if interested.
11-27-2019, 07:19 AM
#97
"Alumi-holic"
Bartlett
, Tennessee
Crawled under the coach to measure the gray tank.....labeling indicates 22 gallons. 22 gal, What were they thinking!
Hmmm have to think on this for a while...have an opportunity to replace with a much bigger gray tank
Tank dimensions:
W24” x L46” x H9”.
To make room for the dump valves and shared connections with the black tank, AS sourced a tank with a section moulded to accommodate the plumbing.
Mounded area dimensions:
W13” x L16” x H6”
a
Additional research needed...
11-27-2019, 07:22 AM
#98
"Alumi-holic"
Bartlett
, Tennessee
Moulded not “Mounded
11-27-2019, 08:09 AM
#99
West Chester
, Ohio
By my calculations, your grey tank is about 6 cubic feet or a little over 40 gal. I looked into a single larger grey tank as well, but opted to install a 3rd dump valve to essentially combine the black/grey to increase capacity
11-30-2019, 02:44 PM
#100
"Alumi-holic"
Bartlett
, Tennessee
Did you install the 3rd dump valve near the combined outlet?
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
