Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 08-28-2019, 12:55 AM   #41
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Glad to see you made it home. I too am impressed that you handled the pitfalls in stride and maintained a positive attitude. I hope you have many happy future camping trips in your new-old moho.
Cheers, Dan
~ Margaret Thatcher ~
Old 08-28-2019, 07:11 PM   #42
"Alumi-holic"
cesalie2's Avatar
1982 31' Airstream 310
Bartlett , Tennessee
Turns out the power steering gearbox is leaking fluid. Have to decide if I want to change the seals or just replace the gearbox...it’s original ...[emoji848]
cesalie2 is offline   Reply With Quote
Old 08-29-2019, 03:41 AM   #43
Replace it. I don't know that they sell them for the P-30 but check out Red-Head for replacements. They are the best on the market.
1975 24' Argosy Motor Home
Old 08-30-2019, 07:31 AM   #44
"Alumi-holic"
cesalie2's Avatar
Good advice, thank you.
Attempting to remove the steering gearbox...tight confines.
What is the recommendation to remove the front bumper in order to access the 2 lower gearbox retaining bolts?
Old 09-02-2019, 08:30 PM   #45
"Alumi-holic"
cesalie2's Avatar
Deja-Vu...or 3rd times the Charm Redux!
Slowly getting to the attaching bolts, hydraulic lines and steering coupler to remove the power steering gearbox. Had to remove the grill, windshield washer tank, etc...
Down to the last retaining bolt and it’s a booger...
https://photos.app.goo.gl/gNqrJy1dkXgiUF4u6
Old 09-03-2019, 01:22 PM   #46
"Alumi-holic"
cesalie2's Avatar
Finally!Click image for larger version
Old 09-10-2019, 02:48 PM   #47
Kvsterling's Avatar
1984 27' Airstream 270
West Chester , Ohio
The real bugger for me was removing that pitman arm...thank you autozone tool loaner program[emoji6]
Kvsterling is offline   Reply With Quote
Old 09-10-2019, 04:16 PM   #48
"Alumi-holic"
cesalie2's Avatar
I used O’reilleys pitman tool to remove the arm!
Old 09-10-2019, 04:34 PM   #49
"Alumi-holic"
cesalie2's Avatar
While awaiting delivery of the replacement power steering gearbox, installed an auxiliary fuel pump...
https://photos.app.goo.gl/JHsi63nruagSSKkB7
Old 09-18-2019, 07:45 AM   #50
"Alumi-holic"
cesalie2's Avatar
Power Steering Gearbox arrived and installed!
https://photos.app.goo.gl/7NY9EkmELvpCbJQV6
Old 09-18-2019, 07:48 AM   #51
"Alumi-holic"
cesalie2's Avatar
While attempting to bleed the air from the power steering system, noticed brake fluid dripping from a fitting on the passenger side...what the?
Old 09-18-2019, 09:25 AM   #52
Does the line per chance go to a cooler of some sort?
Old 09-18-2019, 02:43 PM   #53
"Alumi-holic"
cesalie2's Avatar
Brad, goes to rear brakes [emoji15]
Old 09-18-2019, 02:45 PM   #54
"Alumi-holic"
cesalie2's Avatar
Purchased two 60” brake lines and fittings, spent most of the day getting the old lines out...and installing the new...
Old 09-18-2019, 03:40 PM   #55
Oops! I read the comment where you talked about bleeding the power steering and missed the word "brake" when you talked about the line going to the passenger side
Was the brake line rusted or cracked?
Old 09-18-2019, 08:19 PM   #56
"Alumi-holic"
cesalie2's Avatar
Rusted and leaking at the flare.
Old 09-19-2019, 11:46 AM   #57
"Alumi-holic"
cesalie2's Avatar
Crawled underneath Penny to bleed the brake lines and noticed fuel leaking from the hose attached filter on the frame rail...so happy it happened here at home and not on the road. [emoji3]
Old 09-19-2019, 11:51 AM   #58
"Alumi-holic"
cesalie2's Avatar
With the fuel leak repaired, on to the brake bleeding...ran 2 quarts of fluid thru all the lines.
While cleaning up I noticed a small puddle of fluid about a foot inboard of the drivers front wheel. Crawled underneath and searched for the source...never saw this before...
Where the master cylinder attached to the hydro boost...some drips from the weep hole...
This can’t be good [emoji15]
Old 09-19-2019, 04:46 PM   #59
Kvsterling's Avatar
West Chester , Ohio
Oh man, this is the second leak I had...Steering gear box and brake master cylinder! I was nervous it would be the hydroboost, but replaced master cylinder and that drip went away. Easy to find part at NAPA, and better brake pedal feel(still pretty poor braking)
I don’t run into the leaking lines
Old 09-19-2019, 09:27 PM   #60
"Alumi-holic"
cesalie2's Avatar
Checked with Napa, they recommend I remove the Hydroboost and Master Cylinder. Replace both as a kit.
No Heat Deja VU 2017 - All the Glycol on the concrete OSIN 2016 - Current Classic (all lengths) 18 05-25-2017 08:05 AM
Déjà vu, Rallys, Memories and "to Have Fun" Revisited PeeWee WBCCI Forum 0 09-05-2008 11:25 PM
A 19' CCD for me...4th times a charm! soldiermedic General Repair Forum 73 09-06-2007 02:37 PM
2 times the charm! codybear Tires 17 06-21-2007 09:16 PM
Deja vou. Astrodokk Forum Admin, News and Member Account Info 2 11-09-2006 09:01 AM
