Old 03-06-2020, 01:59 PM   #161
"Alumi-holic"
cesalie2's Avatar
1982 31' Airstream 310
Dearman Avenue , Tennessee
Advice needed...
Upgrade to 50 Amp Power Box and Automatic Transfer Switch?
Or add another 30 Amp Power Box?
Either way will have to change the Oman Generator 20 Amp Circuit Breaker. And change the output wiring for this circuit from 12/2 to 8/2?
For those that made the change...what are steps & photos if you have them.
Daniel
cesalie2 is offline   Reply With Quote
Old 03-06-2020, 03:58 PM   #162
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Originally Posted by cesalie2 View Post
Not much accomplished as I spent the morning looking for “odds and ends” to finish some tasks.
Ran new conduit and installed outlets for the new induction cooktop and Convection Oven/Microwave.Attachment 362718Attachment 362719Attachment 362720
Nice clean work, Daniel! I personally would never use a metal electrical wall box in an Airstream, but I am sure you did a very safe install.
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 03-07-2020, 08:26 AM   #163
"Alumi-holic"
cesalie2's Avatar
Old 03-07-2020, 06:49 PM   #164
"Alumi-holic"
cesalie2's Avatar
Still awaiting arrival of many shipped items...switched gears and put down a peel-n-stick roofing membrane for metal roof houses.
Before:
After:
Hopefully start laying pressure treated plywood tomorrow
Old 03-08-2020, 08:33 AM   #165
cmadmaxman's Avatar
1991 35' Airstream 350
Columbia , Tennessee
Images: 40
Go with the 50 amp, auto or manual, you will want both air units on a hot summer day in direct sun! You can always go down to 30 amp if that's all there is!
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (276,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 03-08-2020, 08:52 AM   #166
"Alumi-holic"
cesalie2's Avatar
Thank you for the recommendation.
I know how to install the 50 amp transfer switch and power box. Trying to figure out how to change the Onan Generator 20 amp Circuit Breaker to 30 amp (goal is to have two 30 amp CB) and needed changes at M1-M4 in order to end up with four wires, 2 hot ( black & red), white neutral and green ground all going to the new 50 amp Transfer Switch.
Old 03-08-2020, 08:02 PM   #167
"Alumi-holic"
cesalie2's Avatar
Quiet day...
Installed outlet covers
And overflow drain for fresh water fill
Will install water pump sediment trap tomorrow...
Old 03-10-2020, 06:09 PM   #168
"Alumi-holic"
cesalie2's Avatar
Yesterday was chock full of doctor appointments until 5 PM..only managed to install the water pump sediment trap..
Old 03-10-2020, 06:12 PM   #169
"Alumi-holic"
cesalie2's Avatar
Subfloor installation today...whew!Click image for larger version
ID:	363025Click image for larger version
ID:	363026Click image for larger version
Old 03-10-2020, 06:24 PM   #170
Airstream Driver
1994 30' Excella
Images: 49
That's a full day of hard work, looking good. Did the screws work out for you?
AIR #13
Old 03-10-2020, 06:52 PM   #171
"Alumi-holic"
cesalie2's Avatar
Awesome Peter!
Had to buy extra drill bits.
Old 03-11-2020, 10:18 AM   #172
"Alumi-holic"
cesalie2's Avatar
Sub flooring completed
And layed in the battery compartment door.
Old 03-11-2020, 10:19 AM   #173
"Alumi-holic"
cesalie2's Avatar
Off to pickup LVT glue down flooring...
Old 03-11-2020, 11:18 AM   #174
mayco's Avatar
champaign , Illinois
Looking very good cesalie. You’re really busting tail getting a lot done.!
Looking at the top picture of your sub flooring it looks like you could use quite a few more screws. Not trying to critique your work here, just trying to help you avoid squeaks and buckles down the road. I’m a retired carpenter and some things just stand out to me. Your screw pattern should be 1 every 6” along the framing rails. Maybe it’s just not showing up in the picture or you planned on adding more screws before you start the finish flooring?
But from the picture it looks like you could use quite a few more screws. One every six inches along the framing is pretty standard for sub floor installation. It’s going to be subjected to a good deal more stress than a fixed structure and the 1 per 6” is the standard for homes.
Seriously not picking at your work, it’s looking good!
Mike
mayco is offline   Reply With Quote
Old 03-11-2020, 05:46 PM   #175
"Alumi-holic"
cesalie2's Avatar
Mike,
Thanks for the advice. Will add more screws!
Also need to dab Sikaflex in all the drill hole “misses”
Old 03-12-2020, 12:33 PM   #176
"Alumi-holic"
cesalie2's Avatar
Per Mayco’s advice added about a hundred additional screws to secure the subfloor to the framing.
Thanks Mike!
Feels much firmer
Old 03-12-2020, 12:35 PM   #177
"Alumi-holic"
cesalie2's Avatar
Hooked up the converter and roughed in the Inverter...Click image for larger version
Off to the store for more plumbing parts...
Old 03-12-2020, 12:46 PM   #178
"Alumi-holic"
cesalie2's Avatar
Plan is to build a box for the refrigerator to stand on...where the old pantry area was...
Small area underneath the frig will house the converter and Inverter. Like the original setup, the front of the box will contain the 12 volt fuse panel.
The old frig area will have a 24” cabinet with 3 drawers. Countertop will be dear wife’s “coffee station”.
Upper cabinet above coffee station will be food storage.
At least this is today’s plan...
Dear wife pacing up and down the coach living room with a tape measure, never a good sign
Old 03-12-2020, 01:01 PM   #179
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
LOL.....I’de fix the lock on the door ! Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 03-12-2020, 04:23 PM   #180
"Alumi-holic"
cesalie2's Avatar
🤣🤣🤣 good one Bob!
No Heat Deja VU 2017 - All the Glycol on the concrete OSIN 2016 - Current Classic (all lengths) 18 05-25-2017 08:05 AM
Déjà vu, Rallys, Memories and "to Have Fun" Revisited PeeWee WBCCI Forum 0 09-05-2008 11:25 PM
A 19' CCD for me...4th times a charm! soldiermedic General Repair Forum 73 09-06-2007 02:37 PM
2 times the charm! codybear Tires 17 06-21-2007 09:16 PM
Deja vou. Astrodokk Forum Admin, News and Member Account Info 2 11-09-2006 09:01 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
