Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 12-01-2019, 09:54 PM   #101
"Alumi-holic"
cesalie2's Avatar
1982 31' Airstream 310
Dearman Avenue , Tennessee
DW wanted a Pull Out Storage Drawer installed in the pantry...luckily Costco had one on sale...it fit too!
ID:	357134Click image for larger version
ID:	357135Click image for larger version
cesalie2 is offline   Reply With Quote
Old 12-02-2019, 06:50 AM   #102
Kvsterling's Avatar
West Chester , Ohio
Originally Posted by cesalie2 View Post
Did you install the 3rd dump valve near the combined outlet?
Yep, going to replace the dump cap with this
Kvsterling is offline   Reply With Quote
Old 12-02-2019, 09:34 AM   #103
"Alumi-holic"
cesalie2's Avatar
Nice!
Old 12-14-2019, 07:57 AM   #104
"Alumi-holic"
cesalie2's Avatar
Fan Clutch failing...
Seems the fan clutch stays locked up, the roar of the radiator fan is constant.
Ordered a Spal 16” electric fan, Derale thermostatic control, Cole Hersee continuous duty solenoid and SeaDog Resettable Fuse.
Some of the parts arrived yesterday so let’s take that sucker out...
Installed fan, thermostatic control and fuse...awaiting solenoid.
ID:	357630Click image for larger version
ID:	357631Click image for larger version
Merry Christmas!
Old 12-14-2019, 08:30 AM   #105
Kvsterling's Avatar
West Chester , Ohio
How many Amps does your alternator put out? I am curious what the draw is with the electric fan. My alternator belt squeals like a SOB whenever load is increased (like when trying to start generator when engine is running). Belt tension seems good
Old 12-14-2019, 09:59 AM   #106
"Alumi-holic"
cesalie2's Avatar
Kyle,
Re Alternator output, Not sure, have to check...
Wanted to solve fan clutch issue, OEM cost was equivalent to electric fan, control, solenoid and resettable fuse.
Old 12-15-2019, 02:58 PM   #107
"Alumi-holic"
cesalie2's Avatar
Cole Hersee Continuous Duty Solenoid arrived in the mail.
Installed, wired up and fired up. Adjusted the thermostatic control to come on about 190 degrees. Initial startup in driveway, all appears to be working.
Will take the coach out for a test drive tomorrow...Click image for larger version
Old 12-15-2019, 05:34 PM   #108
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
dont mean to worry you, but you may want to check your isolator connections. The wire on the right, which should go to either the coach or motor battery looks awful small. Center is typically the feed from the alternator.
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 12-15-2019, 07:42 PM   #109
"Alumi-holic"
cesalie2's Avatar
Peter,
Thank you for the “heads up”!
Daniel
Old 01-28-2020, 09:12 AM   #110
"Alumi-holic"
cesalie2's Avatar
Have chased my issue with intermittent “misfires” under load.
Checked many of the obvious components since last August, but could not identify the culprit...until now.
On our trip to JAX, tach started intermittently reading 4000 rpm at 60 mph. Replaced the HEI Ignition Module...travelled additional 1000 miles and no misfires!
So happy!
Old 02-03-2020, 10:29 AM   #111
"Alumi-holic"
cesalie2's Avatar
Inspired by Dave’s (Ontheroadagain) recent Gearvendor install, ordered unit and awaiting arrival.
Old 02-04-2020, 11:00 AM   #112
1975 24' Argosy Motor Home
Old 02-11-2020, 03:40 PM   #113
"Alumi-holic"
cesalie2's Avatar
Whew!
Gearvendors overdrive arrived late last week and install completed. Replaced all the u-joints and center bearings as well.
Test drive at 60 mph, rpm about 2400.
Looking forward to a longer drive as we will visit Natchez for a week.
ID:	360944Click image for larger version
ID:	360945Click image for larger version
ID:	360946Click image for larger version
Old 02-11-2020, 04:02 PM   #114
Airstream Driver
1994 30' Excella
Images: 49
congrats!!
AIR #13
Old 02-11-2020, 06:52 PM   #115
Tulsa , Oklahoma
You'll love it. Mine got even smoother after I got the driveline angles corrected. Mine were off. Learned WAY more than I imagined, working with 3 driveshafts!
ontheroadagn is offline   Reply With Quote
Old 02-11-2020, 07:31 PM   #116
"Alumi-holic"
cesalie2's Avatar
Dave,
What symptoms did you experience with the angles being “off”?
Old 02-12-2020, 08:43 AM   #117
Tulsa , Oklahoma
It was a slight rumble under a load around 50 - 55 MPH. It was hard to feel it from the drivers seat but I could hear it. Always had it, didn't get it till everything was right for it to show up. Thought it was just the road conditions sometimes until I installed the Gear-Vendors and they talked about driveline angles/vibrations. I bought a digital protractor and found out the u-joint operating angles were not canceling each other out like they should. Finally found some help here to fix it.
https://www.gmcmi.com/wp-content/uploads/2014/05/P30-Chassis-Manual.pdf
Go down to appendix 4. 4-2 is 3 piece drivelines. A lot of stuff there along with the GV install instructions about drivelines.
Old 02-12-2020, 12:01 PM   #118
"Alumi-holic"
cesalie2's Avatar
Thank you sir!
Old 02-13-2020, 03:41 PM   #119
"Alumi-holic"
cesalie2's Avatar
Dan,
Thank you for the link...useful information.
Operating angles, working angle, inclinometer, carpenter square, shaft cancellation theory, phasing...oh my brain hurts!
Although all looked good on paper, felt a vibration manifesting as a “slight bounce”.
As I replaced all u-joints, both center support bearings and had the driveshaft balanced...what else remains?
“Slap forehead”, the transmission mount is probably original from 1982. Quick run to the parts store, the new mount is 1” taller. An hour under the coach to install the mount...next test drive showed a marked improvement.
More to come...
Old 02-21-2020, 02:54 PM   #120
"Alumi-holic"
cesalie2's Avatar
Nice drive up from the Gulf Coast to Natchez!
Small get together of 25 Wanderlodge coaches and our Airstream 310.
Our hosts arranged mansion & winery tours, Tech Sessions for the guys and shopping for the gals...And the food...Yum-O!
During this rally, three 12K Watt Power Tech generator rear bearings were changed...pretty impressive.
ID:	361515Click image for larger version
ID:	361516Click image for larger version
ID:	361517Click image for larger version
ID:	361518Click image for larger version
ID:	361519Click image for larger version
ID:	361520Click image for larger version
ID:	361521Click image for larger version
No Heat Deja VU 2017 - All the Glycol on the concrete OSIN 2016 - Current Classic (all lengths) 18 05-25-2017 09:05 AM
Déjà vu, Rallys, Memories and "to Have Fun" Revisited PeeWee WBCCI Forum 0 09-06-2008 12:25 AM
A 19' CCD for me...4th times a charm! soldiermedic General Repair Forum 73 09-06-2007 03:37 PM
2 times the charm! codybear Tires 17 06-21-2007 10:16 PM
Deja vou. Astrodokk Forum Admin, News and Member Account Info 2 11-09-2006 10:01 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
