Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 05-10-2020, 06:29 PM   #321
"Alumi-holic"
cesalie2's Avatar
1982 31' Airstream 310
Dearman Avenue , Tennessee
Attached mirror to medicine cabinet...
cesalie2 is offline   Reply With Quote
Old 05-10-2020, 06:31 PM   #322
"Alumi-holic"
cesalie2's Avatar
Started stripping vinyl wallpaper off bathroom sink cabinet...
Old 05-11-2020, 04:18 PM   #323
"Alumi-holic"
cesalie2's Avatar
DW wanted a vintage door knob for the WC door...
Old 05-11-2020, 04:19 PM   #324
"Alumi-holic"
cesalie2's Avatar
WC cabinet stripped of vinyl covering
Old 05-11-2020, 04:20 PM   #325
"Alumi-holic"
cesalie2's Avatar
Working on WC under sink door...
Old 05-14-2020, 07:04 PM   #326
"Alumi-holic"
cesalie2's Avatar
Spent the day in the bathroom...fixing odds and ends...
Ran wiring for LED Ceiling Light
Have to scrounge up some aluminum for around the exhaust fan
Added hardware to the cabinet door
Added supports to the cabinet in preparation for the new quartz countertop and porcelain sink in 2 weeks
Prepped the original commode plastic surround for white paint
Finally starting to see the light at the end of the tunnel (of phase 1).
Old 05-21-2020, 10:12 PM   #327
"Alumi-holic"
cesalie2's Avatar
Two more cabinets arrived today...
Built base for refrigerator above the converter and Inverter
Started install of new 12 volt fuse box
Old 05-26-2020, 07:21 AM   #328
"Alumi-holic"
cesalie2's Avatar
Added Vinyl Planks to refrigerator base
Getting upper cabinet into position...
Screwed into wall cleat and added Large Flange rivets to upper
Old 05-26-2020, 12:01 PM   #329
Originally Posted by cesalie2 View Post
While visiting Natchez the weather was cold and rainy, one night the temp was down to 28 degrees. And of course the furnace conked out. Fortunately we had electric heaters and were able to enjoy our visit.
Upon our return I disconnected the wiring and LPG line and pulled the unit for troubleshooting. Things went downhill from there...water heater was leaking and the subfloor around it was rotted,
Wife suggested that I had the furnace out, go ahead and pull the water heater, and the sink, faucet, and countertop, and the stove and the cabinets...Notice a trend here?
Yep, she wants to redo the interior of the coach.
While I’m removing fixtures, etc...she ordered an induction cooktop, convection microwave, quartz countertops for the kitchen, bathroom and the back shelf in the bedroom?
Yesterday with everything out she suggested I remove the PO laminate floor. I guess we’re getting an LVT floor.
Found some soft spots and rot...pulled up the plywood subfloor in the living and kitchen area.
So a simple furnace repair...(haven’t troubleshoot yet...) has turned into a big project
Guess I’ll have to add new Pex Plumbing to the list as well.
Did I mention we have a trip to Louisiana planned for mid-April?
My “honey-do list” has definitely grown...
Attachment 362119Attachment 362120Attachment 362121Attachment 362122
I have to admit, when you mentioned mid April the rest of us were wondering "of what year". However your steady perseverance on making decisions and then getting the work done is truly impressive. While you obviously didn't make your April date the fact that you are this close already to being done is something I would have lost a lot of money on had I bet against you!
I'm enjoying watching this rebuild
1975 24' Argosy Motor Home
Old 05-26-2020, 05:11 PM   #330
"Alumi-holic"
cesalie2's Avatar
It’s been an adventure!
Numerous delays due to late part deliveries and Shelter in Place rules. Still pressing forward.
Old 05-26-2020, 05:18 PM   #331
"Alumi-holic"
cesalie2's Avatar
Moved refrigerator to the new location
Positioned upper cabinet to check fitment
Have to cover the black pipe before I secure the upper cabinet
Old 05-26-2020, 05:21 PM   #332
"Alumi-holic"
cesalie2's Avatar
Added angle bracket behind drawer cabinet to help support quartz countertop
Old 05-28-2020, 03:07 PM   #333
"Alumi-holic"
cesalie2's Avatar
Installed hardwired rear camera...
Old 05-28-2020, 03:12 PM   #334
"Alumi-holic"
cesalie2's Avatar
Trouble in generator-land
Unable to start since March, put on back-burner as I was juggling many projects
Spent the day troubleshooting...
Cranks slowly and compression stroke pushes air-fuel charge back thru carb.
Thinking I may have to pull the generator from the compartment and tear it down...
Old 05-30-2020, 01:16 PM   #335
"Alumi-holic"
cesalie2's Avatar
Countertops did not show up yesterday
So, installed 12 volt power port
And...painted commode surround to complement the cabinet doors & drawer
Old 06-01-2020, 03:05 PM   #336
"Alumi-holic"
cesalie2's Avatar
Getting ready to pull the generator...
Ground cable disconnected
Positive Cables disconnected at coach engine starter
Gen Power Cable disconnected from solenoid
Fuel pump wiring disconnected
Generator controls wiring plug removed
Generator Output Wires removed and capped
Fuel line blocked
Removed muffler
Removed pipe from exhaust
Removed 3 retaining bolts and nuts from chassis pan
Removed 1 bolt from underneath
Placed some boards under genny to clear the cooling shroud
Setup furniture mover with extra 2x12’s to slide the generator on
Waiting for buddy to arrive to help slide the generator
Old 06-01-2020, 03:07 PM   #337
"Alumi-holic"
cesalie2's Avatar
Old 06-02-2020, 06:27 AM   #338
I recognize that furniture dolly
I have a slew of them around my shop, very handy.
Old 06-02-2020, 05:08 PM   #339
"Alumi-holic"
cesalie2's Avatar
a lifesaver!
Old 06-02-2020, 05:12 PM   #340
"Alumi-holic"
cesalie2's Avatar
Kitchen countertop going in...Click image for larger version
No Heat Deja VU 2017 - All the Glycol on the concrete OSIN 2016 - Current Classic (all lengths) 18 05-25-2017 09:05 AM
Déjà vu, Rallys, Memories and "to Have Fun" Revisited PeeWee WBCCI Forum 0 09-06-2008 12:25 AM
A 19' CCD for me...4th times a charm! soldiermedic General Repair Forum 73 09-06-2007 03:37 PM
2 times the charm! codybear Tires 17 06-21-2007 10:16 PM
Deja vou. Astrodokk Forum Admin, News and Member Account Info 2 11-09-2006 10:01 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
