Old 04-03-2020, 05:52 PM   #241
"Alumi-holic"
cesalie2's Avatar
1982 31' Airstream 310
Bartlett , Tennessee
Removed unused wiring, secured propane manifold, installed covers on the new ATS & Load Panel, installed plywood on the twin bed and used jabsco stripper on the LR walls to remove some of the hundreds of small bits of vinyl wallpaper.
cesalie2 is offline   Reply With Quote
Old 04-03-2020, 05:55 PM   #242
"Alumi-holic"
cesalie2's Avatar
“Run Daniel, Run”...
DW debating if she wants the bedroom vinyl wallpaper removed next...
[emoji15][emoji15][emoji15]
Old 04-04-2020, 06:08 PM   #243
"Alumi-holic"
cesalie2's Avatar
Today DW shared her plan for new interior lighting.
She placed blue painters tape where she wanted the LED ceiling lights.
Spent the day figuring out how to layout the wiring to work around the frame and ribs.
Did manage to install several lights...
Old 04-05-2020, 06:54 AM   #244
Are you one of those people that sleeps about 2 hours a night?!
Amazing work
1975 24' Argosy Motor Home
Old 04-05-2020, 09:51 AM   #245
"Alumi-holic"
cesalie2's Avatar
Brad,
4 hours
Thank you for the compliment, I’ve admired your handiwork for years...means a lot coming from you!
Old 04-05-2020, 04:04 PM   #246
"Alumi-holic"
cesalie2's Avatar
First row completed.
Old 04-06-2020, 06:15 PM   #247
"Alumi-holic"
cesalie2's Avatar
Spent most of the day gathering parts to complete some open projects...
Started stripping vinyl wallpaper from the door.
Old 04-08-2020, 05:14 PM   #248
"Alumi-holic"
cesalie2's Avatar
Contacted several holding tank distributors to purchase a new gray tank...no response as yet due to Shelter in Place rules...
So I purchased a plastic welding kit and decided to give it a try.
Here is the crack:
And a little plastic welding...
Have never “welded” plastic before...will sand and smooth tomorrow.
Old 04-08-2020, 05:20 PM   #249
"Alumi-holic"
cesalie2's Avatar
Say it isn’t so!
[emoji35]
SWMBO has decided she doesn’t like the LED Recessed lights I have been installing...
So, out they come!
And here are the newly “approved” lights
Started drilling holes on the passenger ceiling.
Old 04-08-2020, 05:23 PM   #250
"Alumi-holic"
cesalie2's Avatar
And a little more wallpaper stripping...
Old 04-08-2020, 08:17 PM   #251
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Originally Posted by cesalie2 View Post
Say it isn’t so!
[emoji35]
So, out they come!
Attachment 365224
Attachment 365225
Attachment 365226
Attachment 365227
Now thats funny, Daniel! I would have respectfully declined to change those lights...
After all, those holes you cut for the new and approved version are quite a commitment of permanency But don't listen to my rambling thoughts
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 04-09-2020, 12:16 PM   #252
"Alumi-holic"
cesalie2's Avatar
lol
Old 04-09-2020, 04:30 PM   #253
"Alumi-holic"
cesalie2's Avatar
LED Ceiling Light project completed...
High:
Low:
Old 04-09-2020, 04:35 PM   #254
"Alumi-holic"
cesalie2's Avatar
A little more work on the Gray Tank...plastic welding
A few more layers, some sanding & smoothing and I think I can fill the tank for testing [emoji4]
Old 04-09-2020, 07:17 PM   #255
"Alumi-holic"
cesalie2's Avatar
Waited until evening...
Low:
High:
Old 04-09-2020, 08:16 PM   #256
dadstoy's Avatar
_ , _
Sweet!
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
dadstoy is offline   Reply With Quote
Old 04-10-2020, 05:01 PM   #257
"Alumi-holic"
cesalie2's Avatar
Spent the day catching up on yard work...
Popped into the coach to check supplies and found a hint from Dear Wife...
Yep, have to strip the vinyl wallpaper from the bedroom and install 4 LED Recessed Lights.
Old 04-10-2020, 05:04 PM   #258
"Alumi-holic"
cesalie2's Avatar
Spent a little time swapping out the Almond Outlets for White...
You know that means...
Now I have to swap out all the Almond Light Switches to White.
Old 04-14-2020, 08:52 AM   #259
"Alumi-holic"
cesalie2's Avatar
Awaiting more parts to arrive 🤫 little progress.
Meanwhile, tested my first efforts at plastic welding...yes I suck...abysmal failure
Started searching the web for a suitable replacement...
Due to the uniqueness of our coaches dimensions a direct replacement has not been found as yet. A creative solution may be in order...why am I not surprised?
[emoji848]🤫[emoji15]
Old 04-15-2020, 05:24 AM   #260
Kvsterling's Avatar
1984 27' Airstream 270
West Chester , Ohio
Same thing happened to me with the plastic welding. Don’t give up yet!
The plastic of the tank is also a thermoplastic that can be melted with the welding iron. Go back over it and try to get the new black material to mix with the tank layer. Can also use the metal mesh for added strength in the repair area. It all sealed well for me on my second go
Kvsterling is offline   Reply With Quote
No Heat Deja VU 2017 - All the Glycol on the concrete OSIN 2016 - Current Classic (all lengths) 18 05-25-2017 08:05 AM
Déjà vu, Rallys, Memories and "to Have Fun" Revisited PeeWee WBCCI Forum 0 09-05-2008 11:25 PM
A 19' CCD for me...4th times a charm! soldiermedic General Repair Forum 73 09-06-2007 02:37 PM
2 times the charm! codybear Tires 17 06-21-2007 09:16 PM
Deja vou. Astrodokk Forum Admin, News and Member Account Info 2 11-09-2006 09:01 AM
