Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 03-26-2020, 07:40 PM   #221
"Alumi-holic"
cesalie2's Avatar
1982 31' Airstream 310
Dearman Avenue , Tennessee
Odds & Ends today...
Painted Water Heater door silver
Repurposed aluminum angle iron from the old pantry for the refrigerator support stand
Stripped more vinyl wallpaper from the hallway and WC
cesalie2 is offline   Reply With Quote
Old 03-26-2020, 07:45 PM   #222
"Alumi-holic"
cesalie2's Avatar
New Generator 30 amp CB arrived in the mail today.
Coach has sat since our return from Natchez, after installing new generator circuit breakers attempted to start...no joy.
Gen spun too slow too start...another project for the list.
Old 03-27-2020, 05:20 PM   #223
"Alumi-holic"
cesalie2's Avatar
DW wanted the bathroom vinyl wallpaper removed next...
Removed Medicine Cabinet
Side Lights
Toothbrush and cup holders
Towel Ring, Towel Bar, Rollup Shade, Valance
Removed the plastic wall behind the toilet and plastic ceiling
And exposes the aluminum wall underneath and the gaping hole for the electrical...
Old 03-27-2020, 05:23 PM   #224
"Alumi-holic"
cesalie2's Avatar
Back to the aluminum scrap pile to repurpose the old pantry walls...
Will strip the vinyl wallpaper from the entire bathroom tomorrow,
Old 03-27-2020, 05:30 PM   #225
"Alumi-holic"
cesalie2's Avatar
Taking breaks every hour and stripping more wallpaper...
Old 03-28-2020, 06:16 PM   #226
"Alumi-holic"
cesalie2's Avatar
Airstream original aluminum crack on the wall behind the toilet
Added a little more aluminum to cover the crack
Old 03-28-2020, 06:18 PM   #227
"Alumi-holic"
cesalie2's Avatar
And a little more vinyl wallpaper removed...
Taking a break tomorrow
Old 03-29-2020, 04:06 PM   #228
"Alumi-holic"
cesalie2's Avatar
Repurposed much of the aluminum
The large piece on the left will serve as the base for the refrigerator stand.
And I have two pieces to spare
Old 03-29-2020, 04:18 PM   #229
mayco's Avatar
champaign , Illinois
So are you using any chemical stripper or anything else to remove that vinyl? It looks like it’s just peeling off
mayco is offline   Reply With Quote
Old 03-29-2020, 07:41 PM   #230
"Alumi-holic"
cesalie2's Avatar
Mike,
We bought this tool over 30 years ago...called the Silent Stripper...
http://www.silentpaintremover.com/sp...rared_heat.htm
Does an amazing job!
Old 03-30-2020, 04:14 PM   #231
"Alumi-holic"
cesalie2's Avatar
Todays “shi$$y” job...
New cabinets are stuck in New Orleans, Quartz Countertop Fabricator has closed for the crisis..
So let’s tackle the “shi$$y” job...replace the Thetford Valves, Adapters and find the Gray Tank Leak...
Black Tank Adapter cracked and leaking
Remove 4 Rusted Screws from each Thetford Valve
Wiggle the double sanitary T and work the valves out (had to use pliers to yank out the seals to give a little more wiggle room).
To drop the Gray Tank...
Loosen & Remove the hose clamp around the drain flange
Attachment 1
Loosen the hose clamp at the top of the tank for the shower drain pipe
Loosen the hose clamp for tank vent
Attachment 1
Remove the 4 (1/2 “ ) nuts & washers supporting the right side of the tank
Drill out 12 each, 3:16” rivets & 2 each, 1:8” rivets securing the lower curved panel
Gently pull the panel outward to provide access to the 4 (1/2” nuts & washers) on the left side of the tank.
Disconnect the tank monitoring g sensor wiring at the harness in the kitchen.
Gently work the tank out
Old 03-30-2020, 04:17 PM   #232
"Alumi-holic"
cesalie2's Avatar
Gray Tank Crack near the top
Flange Crack...pretty bad
Old 03-30-2020, 04:20 PM   #233
"Alumi-holic"
cesalie2's Avatar
Guess I will explore replacing the gray tank due to its age (38 years) and the location of the flange crack.
Old 03-30-2020, 07:58 PM   #234
mayco's Avatar
Originally Posted by cesalie2 View Post
mike,
we bought this tool over 30 years ago...called the silent stripper...
does an amazing job!
cooooooool!
Old 04-01-2020, 08:30 AM   #235
"Alumi-holic"
cesalie2's Avatar
Sealed Furnace Exhaust
Old 04-01-2020, 08:32 AM   #236
"Alumi-holic"
cesalie2's Avatar
A little vinyl wallpaper stripping in the WC
Old 04-01-2020, 08:34 AM   #237
"Alumi-holic"
cesalie2's Avatar
Drilled out about a hundred rivet remnants on the street side of the LR & Kitchen.
Old 04-01-2020, 09:34 AM   #238
Attachment 364541
Trying to keep the mud daubers out?
1975 24' Argosy Motor Home
Old 04-01-2020, 11:26 AM   #239
"Alumi-holic"
cesalie2's Avatar
Old 04-02-2020, 06:01 PM   #240
"Alumi-holic"
cesalie2's Avatar
Awaiting parts to complete several projects.
In the meantime...
Crimped Water Heater Pex piping
Drilled out the remaining rivet remnants on the curb side of the LR & Kitchen
More vinyl wallpaper removal from the WC
No Heat Deja VU 2017 - All the Glycol on the concrete OSIN 2016 - Current Classic (all lengths) 18 05-25-2017 09:05 AM
Déjà vu, Rallys, Memories and "to Have Fun" Revisited PeeWee WBCCI Forum 0 09-06-2008 12:25 AM
A 19' CCD for me...4th times a charm! soldiermedic General Repair Forum 73 09-06-2007 03:37 PM
2 times the charm! codybear Tires 17 06-21-2007 10:16 PM
Deja vou. Astrodokk Forum Admin, News and Member Account Info 2 11-09-2006 10:01 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
