03-12-2020, 08:41 PM
#181
1982 31' Airstream 310
champaign
Lookin good!
03-13-2020, 11:59 AM
#182
"Alumi-holic"
Bartlett
, Tennessee
Connected Pex to the shower valve...
03-13-2020, 12:01 PM
#183
"Alumi-holic"
Bartlett
, Tennessee
03-13-2020, 12:05 PM
#184
"Alumi-holic"
Bartlett
, Tennessee
Laid out the vinyl plank pattern and pre-cut the pieces.
Will pickup the pieces and fill any holes in the sub flooring with Sikaflex.
If all goes well 🤣 ...Will glue down the vinyl planks in the morning.
03-14-2020, 01:45 PM
#185
"Alumi-holic"
Bartlett
, Tennessee
“...of the best laid plans of mice and men...”
I planned to glue down the vinyl planks today...”SWMBO” wanted me to hang pictures in the house.
And remove the old electrical switch to power the front air conditioner or old microwave.
And remove the old hood fan and part of the housing for the new upper cabinets.
[emoji46]
03-14-2020, 01:49 PM
#186
"Alumi-holic"
Bartlett
, Tennessee
03-14-2020, 01:50 PM
#187
"Alumi-holic"
Bartlett
, Tennessee
Repurposed some more aluminum from the old pantry...
03-16-2020, 06:07 PM
#188
"Alumi-holic"
Bartlett
, Tennessee
Added outlet for future coffee station...
03-16-2020, 06:10 PM
#189
"Alumi-holic"
Bartlett
, Tennessee
Picked up some 3/16” large flange rivets to install the the aluminum angle brackets for the new countertops next week
03-16-2020, 06:17 PM
#190
"Alumi-holic"
Bartlett
, Tennessee
03-16-2020, 07:54 PM
#191
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Originally Posted by cesalie2
Damn, Daniel, you get stuff done, don't ya. Looking great and keeps you occupied, away from all the so overwhelming stuff. Good therapy, carry on!!
AIR #13
03-17-2020, 07:31 AM
#192
"Alumi-holic"
Bartlett
, Tennessee
[emoji106]
03-17-2020, 03:53 PM
#193
"Alumi-holic"
Bartlett
, Tennessee
Made a morning run to pickup white electrical outlets (replacing all the beige ones) & Covers, 6/4 Wire and to watch the morning carnage at Sams (lines wrapped around the building) [emoji15]...
Today’s project is to rewire the generator feed to support 50 amp output to the new ATS.
Cole3444 provide a photo and diagram, Thank You!
I documented my existing wiring...
And rewickered the wiring IAW with the diagram from Cole3444.
Next up, procure a 30 amp breaker & 100 amp Panel and then run the 6/4 wiring to the ATS.
03-18-2020, 04:04 PM
#194
"Alumi-holic"
Bartlett
, Tennessee
Used some Pex Pipe as “fish tape” to run 6/4 SOOW from the generator control panel to to load center.
03-18-2020, 04:09 PM
#195
"Alumi-holic"
Bartlett
, Tennessee
Awaiting arrival of Progressive Automatic Transfer Switch...so off to the local electrical supply house for a 100 amp load Panel, breakers & ground bars.
Plan to install ATS and load Panel this weekend.
Looks like tomorrow I will be installing the replacement Suburban furnace...
03-19-2020, 05:50 PM
#196
champaign
I would have warned you but I didn’t know you were replacing the furnace. I would have recommended you do the furnace before the finish floor went down. It is sooooo tight getting that furnace out......top of furnace hits the cabinet cross bar. With less flooring it gives you just enough room to slide it out easy. Well here’s hoping it slides out easy for you. When I replaced mine it was an awful struggle. In hindsight I would have tried to just pull the innards out of the old one and slid the new innards in place. I “think” you could do that if it looks like you might damage your new floor getting the old one out. Dang it.
03-19-2020, 07:18 PM
#197
"Alumi-holic"
Bartlett
, Tennessee
Thankfully all cabinets were removed and new ones will be built in place.
03-19-2020, 07:21 PM
#198
"Alumi-holic"
Bartlett
, Tennessee
Set the new furnace, connected the inlet & outlet, connected 2 of the three ducting and connected the wiring.
Will hookup the propane tomorrow when I setup the new Tankless Water Heater,
03-20-2020, 02:05 PM
#199
champaign
Hahahahahahahaha.......never mind
03-20-2020, 03:59 PM
#200
"Alumi-holic"
Bartlett
, Tennessee
Late start today...had to fight the hordes at the local grocery store [emoji33]
Managed to set the tankless water heater, install the door adapter, rough-in the Pex plumbing, hookup 12 volt & ground.
Will remove the door and paint it aluminum...
Hope to tackle the propane lines tomorrow.
