Old 05-11-2020, 02:14 PM   #1
Kenneth
1987_345's Avatar
1987 34.5' Airstream 345
Waxahachie , Texas
Dead Tachometer
And so my gauge issues continue.... Does anybody know if aftermarket spark plug wires are incompatible with the tach pickup coil? It mostly reads "0", but sometimes bounces a little. I'm not even really sure when it stopped functioning or how to test it. Any ideas? Kenneth
1987_345 is offline   Reply With Quote
Old 05-11-2020, 03:49 PM   #2
richw46's Avatar
I'm In , Kentucky
Left field comment - On my outboard the tach quit. Repair shop said that is usually an indicator of voltage regulator failure. Replaced the voltage regulator and tach is back. I have no idea if this would translate to your application, but it's a thought.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
richw46 is offline   Reply With Quote
Old 05-11-2020, 05:05 PM   #3
1988 32.5' Airstream 325
calgary , alberta
Thumbs up tach
Ken I have a tach as well as the speedo. Jonathan
jhenry is offline   Reply With Quote
Old 05-11-2020, 06:26 PM   #4
Kenneth
1987_345's Avatar
Waxahachie , Texas
I hadn't thought of that Rich. Electronics is my weakness!!. I believe the voltage regulator on my coach is built in the alternator. I haven't had any issues there yet so I'm guessing that's not the problem. Were you able to notice any warning signs of your failure on your amp gauge?
Kenneth
Old 05-12-2020, 08:07 AM   #5
richw46's Avatar
I'm In , Kentucky
Kenneth
I don't have an amp gauge but my voltage was spiking at around 19 volts, another sign of a bad regulator. One of the wires on the regulator had a crispy connector. Again, this is an outboard motor.
If you want you can take your alternator to a parts shop like Advance Auto etc. and they can put it on a machine to test it.
I did find that on cars the tach gets its signal from the ECU (electronic control unit) or the ignition coil pack ground circuit. They said to check all the connections for corrosion. Maybe these images can help you.
-Rich
Rich & Yvonne
Old 05-12-2020, 10:13 AM   #6
Kenneth
1987_345's Avatar
Waxahachie , Texas
Thank-you so much Rich for the illustrations. That is most helpful
Old 06-01-2020, 08:41 AM   #7
Menomonee Falls , Wisconsin
Hey
When we bought coach 5420 miles on a. 85 325
In going through the electronics I noticed a wire coming off the tach along with the original wire
So I cut it no tach reconnected it tach works
Maybe in the wire harness from gage to distributor there's a break run a separate power lead from tach to distributor it might that simple DJ
davejay is offline   Reply With Quote
Old 06-13-2020, 01:40 PM   #8
Kenneth
1987_345's Avatar
Waxahachie , Texas
Still working on the tachometer issue. I have a question I hope someone can answer for me as I try to eliminate the possible causes of my problem. Does anyone know where the tach gets its signal from? Is it from the tach port on the distributor or is it that electrified looking ring that goes around the front left spark plug wire? Anybody?
Old 06-14-2020, 12:06 AM   #9
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I can't speak for the gas units but both of my diesels drive the tach from a terminal on the alternator. It was a simple add on connection when I had the last alternator built.
I also ran across a programable Teleflex tach. They had two versions, one ran off a low frequency of pulses and the other a much higher frequency. There was about a dozen dip switches on the back for set up. Good luck
Cheers, Dan
~ Margaret Thatcher ~
Smartstream is online now   Reply With Quote
Old 06-14-2020, 05:10 AM   #10
1986 34.5' Airstream 345
Londonderry , New Hampshire
The thing that clips around the spark plug wire is for the cruse control.
The tach is driven from the distributor.
Air345Fly is offline   Reply With Quote
Old 06-14-2020, 05:35 AM   #11
Hey
Your tach signal comes off the tach. The coil is built into the distributor. Maybe you got a problem within the dist. I haven t looked in a while but those contact leads that the tach connector plugs into at the dist are also connected to a wire. Maybe the one for the tach has broke loose. Worth a look. It may be that simple. Dj
Old 06-23-2020, 05:31 PM   #12
Kenneth
1987_345's Avatar
Waxahachie , Texas
Thanks Dan. Mine must be different. It doesn't have any dip switches
Old 06-23-2020, 05:32 PM   #13
Kenneth
1987_345's Avatar
Waxahachie , Texas
Thank-you Air345fly!!!!! That helps me alot
Old 06-23-2020, 05:34 PM   #14
Kenneth
1987_345's Avatar
Waxahachie , Texas
Originally Posted by davejay View Post
Hey
Thank-you Davejay. That's what I'm hoping for. Something simple!!
Tachometer is quirky kennytheecat Electrical - Systems, Generators, Batteries & Solar 1 04-20-2009 08:49 PM
Wandering tachometer Geophilist Mechanics Corner - Engines, Transmission & More... 21 10-25-2006 04:25 PM
Tachometer instability Howard Lefkowitz Classic Motorhomes 0 10-23-2006 12:48 PM
Tachometer failure!! ralley Mechanics Corner - Engines, Transmission & More... 5 02-24-2006 06:04 PM
Where is the tachometer connection? AccessMaster Mechanics Corner - Engines, Transmission & More... 13 06-29-2003 05:26 PM
