Old 08-23-2022, 03:03 PM   #1
1987 32.5' Airstream 325
Windsor , Ontario
Dead bolt lock will not engage
The dead bolt lock on my 1987 325 MH has decided to stop engaging all the way. So now I cannot lock my rig.
It still engages via the dashboard switch but does not come all the way out. Same as using the key.
Has anybody else come across this, repaired? My key guy could not help as he said the Sclage lock is turning, something inside is stopping the dead bolt.
Pic shows how far it will engage before stopping.
Thanks in advance,
Chris
realpank is offline   Reply With Quote
Old 08-23-2022, 05:39 PM   #2
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
The electric motor that brings the deadbolt in and out is a Ford power door lock actuator. I have replaced both in the 89, 325LE and the 89, 370LE. It is located in between the wall, you have to drill the rivets out from the interior wall, sometimes remove the cabinet as well. There should be some pictures on either of my threads doing the job. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 08-23-2022, 07:56 PM   #3
Windsor , Ontario
Thanks Bob,
The first thing I tried was the dashboard switch and it did work but not all the way. Is this what you experienced and fixed. Donít really care if I can close remotely . Just need to be able to lock the rig.
Is the failure of the remote lock what is causing this?
Thanks for your response.
Chris
Old 08-24-2022, 06:03 AM   #4
Here is a writeup I did for dead bolt access on an 86 345.
Hopefully it will help.
1975 24' Argosy Motor Home
Old 08-24-2022, 08:18 AM   #5
Windsor , Ontario
Thank Bkahler,
Excellent tutorial and pictures. What makes this group so invaluable. Sound like I need to replace that spring steel one I get this apart. Now to decide if I can do this!
Old 08-25-2022, 08:59 AM   #6
Windsor , Ontario
I have apart and have replaced the broken strip in the bolt mechanism. I reckon I can get a nut and dolt set to put that back together.
Question is what do you use to reattach the bolt mechanism to the door jamb? I drilled out the rivets and would use a nut/bold combo but the rivet portions are still on the bracket(they still locate the bracket nicely)
Do I need to remove all of the rivet and start fresh with bolt/nut. I thought I could drill the centre of the rivets out and use as a guide for a self-tap screw or bot/nut set?
Old 08-25-2022, 10:23 AM   #7
Can you post some pictures? I can't quite follow what you're trying to describe.
Old 08-26-2022, 08:31 AM   #8
Windsor , Ontario
This is one of two rivet studs that are still on the bolt mechanism box, are these to be removed to reinstall?
Old 08-26-2022, 09:16 AM   #9
Yes, remove them and replace with small bolts or rivets.
Old 08-26-2022, 11:39 AM   #10
Windsor , Ontario
Old 08-26-2022, 09:08 PM   #11
Windsor , Ontario
Do you know of a source for the wire capacitor that is located within the metal handle thatís located on the interior wall. The wire broke when I was taking it apart
Old 08-27-2022, 07:54 AM   #12
I believe you're referring to the mercury switch. The switch is used to turn on the indicator light on the dash indicating whether the door is latched or not. You might try searching online for mercury switches and see if you can find something that matches.
Good luck!
Old 08-27-2022, 08:41 AM   #13
Windsor , Ontario
Do you have a source for the Mercury switch that is located within the steel toggle handle that opens and closes the bolt from the inside. Wire broke on mine.
Old 08-28-2022, 10:03 PM   #14
dadstoy's Avatar
_ , _
I recently purchased from an ebay vendor. Search for
Durakool A1-002 Tilt Switch
dadstoy is offline   Reply With Quote
Old 09-15-2022, 08:15 AM   #15
Windsor , Ontario
Dead bolt will not engage
What did you use as a spring steel source for the lock set. I have made a piece from a clamp but find it too tight?
Old 09-19-2022, 05:38 PM   #16
Pallet banding. It worked but in the long run I ended up finding a new replacement lock assembly. The original one was just to beat up inside to work smoothly.
Old 09-20-2022, 12:16 PM   #17
Windsor , Ontario
Dead bolt
Any idea where you found that?
Brake Contoller will not engage trailer brakes Sammy99 Brakes & Brake Controllers 10 10-28-2018 10:41 AM
Dead bolt lock not locking 3dawgnight Doors & Locks 8 06-02-2016 08:08 AM
Starter will not engage, vehicle battery good rel Sprinter and B-van Forum 1 01-12-2016 05:35 AM
A.c. Not cooling, I don't hear compressor engage when I turn up or down. Summer's com jimin pa All Argosy Trailers 2 05-07-2015 02:54 PM
dead dead bolt Jim from SB Doors & Locks 3 09-09-2012 11:32 AM
