Old 08-07-2019, 05:39 AM   #1
Kvsterling's Avatar
West Chester , Ohio
Dashboard woes
Iím in a 1984 motorhome doing a diy renovation. Having pretty good luck figuring out fixes for the electrical systems, but this dashboard wiring is a real head-scratcher sometimes. Mostly PO frustration as several half-a$*fixes that have failed
What is this module floating around in my wiring mess? As you can see most of the wires had been cutClick image for larger version
ID:	348747Click image for larger version
Kvsterling is offline   Reply With Quote
Old 08-07-2019, 06:08 AM   #2
1986 34.5' Airstream 345
Alliance , Ohio
It looks like the cruise control module.
mehes is offline   Reply With Quote
Old 08-07-2019, 06:12 AM   #3
Kevin245's Avatar
Ditto...
William C. Swinney
Old 08-07-2019, 07:09 AM   #4
Kvsterling's Avatar
West Chester , Ohio
Would the cut wires shown have gone to the speedometer?
Old 08-07-2019, 08:21 AM   #5
1988 32.5' Airstream 325
calgary , alberta
I believe its the wiper module
jhenry is offline   Reply With Quote
Old 08-07-2019, 01:50 PM   #6
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
It's the wiper module. Check my post here:
http://www.airforums.com/forums/f311...ual-87396.html
You can still get a replacement module direct from a supplier at a fraction of the cost of the Airstream option.
Boom Sounds is offline   Reply With Quote
Old 08-07-2019, 03:12 PM   #7
Kevin245's Avatar
Not that I know of. These units generally measure rotation of the driveshaft via a magnetic pickup, rather than actual MPH.
Wiper modules have centering and low speed input adjustments? I've seen these on cruise control modules (CCMs). Educate me, I've been wrong before.
William C. Swinney
Old 08-09-2019, 05:18 AM   #8
I recall that when I replaced my wiper module it was a similar looking plastic box under the dash. Make was ROSTRA Precision controls. Diagram attached. It is of course conceivable that they made and had a similar set up for cruise control. I cannot attest to that.
ID:	348927   Click image for larger version
Old 08-09-2019, 12:52 PM   #9
Kvsterling's Avatar
West Chester , Ohio
I would love to get my hands on the cruise control module wiring diagram to compare.
The PO has disconnected both systems. Rigged some toggle switches for wipers and washer, and no cruise control connections at all
Old 08-09-2019, 05:20 PM   #10
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Not sure if these will do you any good but you can search your model number and see what you find. I have an aftermarket Rostra cruise control unit in my 310TD.
http://www.rostra.com/manuals/250-1223-faq.pdf
http://www.rostra.com/support/
mayco is offline   Reply With Quote
Old 08-10-2019, 06:22 AM   #11
Kvsterling's Avatar
West Chester , Ohio
I think this is going to be a rabbit hole for me....I have done so many other dash projects that correct previous ďfixesĒ, new gauges, etc.
I will be full timing it in a couple years, planning to do tour of the National Parks. Think itís worth the cruise control repair? I have heard using CC in rv is generally a waste of gas but I use it regularly in my daily driver
Old 08-10-2019, 06:25 AM   #12
Kvsterling's Avatar
West Chester , Ohio
Oh, and pretty sure the brown box is the CC module. I have located the fluid level sensor module, and this is not part of my wiper system
Old 08-10-2019, 06:32 AM   #13
I like cruise control, frankly I'd far rather use it for long hauls.
In terms of the cruise control schematics. I thought they were usually included in the Airstream Coach manual, including the test procedures. If you don't have your coach manual, download it or a similar one from the same year from Airstream.com.
Nick
Old 08-10-2019, 11:42 AM   #14
mayco's Avatar
Ooooohhhhh ya, cruise control for me is a must. The fuel pedal on the diesel has a pretty stout return spring.
Old 08-12-2019, 05:25 PM   #15
Silver Dreams
stream3's Avatar
1988 34.5' Airstream 345
Columbus , OH
Hey Kyle-
My CC was out for a couple of months and I hated it. Got to have it for the long drives. The older I get the less cooperative my right leg has become. Did you get the reel installed?
1988 345LE "Rosie"
-Jerry
stream3 is offline   Reply With Quote
Old 08-13-2019, 04:48 AM   #16
Kvsterling's Avatar
West Chester , Ohio
The chassis manual I have does not show the cruise control module Iím looking at. Even more confused than when I started, think my service manual is for newer gen Chevy MH. I need to dig around more under the dash. Got into rewiring windshield wiper/pump and left CC alone for now.
Old 08-13-2019, 06:24 AM   #17
Kvsterling's Avatar
West Chester , Ohio
Did the original teleflex speedometer have an electric speed sensor lead to the cruise control module? When we bought this 1984 270, it already had aftermarket Autometer speedo/tach and no speed sensor lead. I have upgraded to Speedhut gps speedo/tach and wondering if I need to use an electric speed sender from transmission to cruise module?
Old 08-13-2019, 06:28 AM   #18
Kvsterling's Avatar
West Chester , Ohio
If Iím right, the bottom left connection ďspeed signalĒ is no longer part of my speedometer
Old 08-14-2019, 03:37 PM   #19
Hi,
I was referring to the Airstream manual, not the Chevvy Chassis Motorhome Manual. Check Airstream.com if you don't have this.
N
Old 08-15-2019, 06:14 AM   #20
Kvsterling's Avatar
West Chester , Ohio
I would benefit from the Airstream service manual! I went through airstream.com website. No luck...was an electronic version available at one time? I have the airstream owners manual, but not airstream service manual
Dashboard Repair of Vinyl Leather silvertent General Motorhome Topics 3 06-08-2006 06:06 PM
Dashboard Repair on Vinyl Upholstery silvertent Upholstery, Blinds, Walls & Interior Finishes 2 06-01-2006 11:53 AM
Dashboard Makeover Chaplain Kent Classic Motorhomes 32 03-30-2006 05:34 AM
To Paint or Not to Paint My Dashboard Chaplain Kent General Interior Topics 8 02-23-2006 07:41 AM
Instrumentation/Dashboard redo thenewkid64 Mechanics Corner - Engines, Transmission & More... 1 06-03-2002 09:02 AM
