Old 11-15-2011, 12:09 AM   #1
dadstoy's Avatar
_ , _
Dash and/or gauge replacement
Interesting discovery! When I turn on the running or headlights, the ammeter really drops. I discovered that if the rheostat for the dash lights is off, then no dramatic drop on the ammeter. The dash lights don't light up very well either and are almost impossible to see at night.
Has anyone replaced their dash and or gauges? Has anyone repaired their dash/gauges?
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
dadstoy is offline   Reply With Quote
Old 11-15-2011, 12:30 AM   #2
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
I suppose I can answer "yes" to that.
And by the way, I really enjoyed the photos of your recent trip, especially seeing two generations behind the wheel. There must have been a lot of emotions running through your head along the way.
Charly.
streamquest is offline   Reply With Quote
Old 11-15-2011, 07:42 AM   #3
Maniacal Engineer
barts's Avatar
Lopez Island , Washington
Offhand I'd guess that this is a shunt type ammeter (e.g. wires to ammeter are small) and the ground line connection to the dash is poor.
- Bart
Bart Smaalders
Lopez Island, WA
https://tinpickle.blogspot.com
barts is offline   Reply With Quote
Old 11-15-2011, 10:39 PM   #4
dadstoy's Avatar
_ , _
Charly.
What brand of gauges did you use?
Old 11-15-2011, 10:40 PM   #5
dadstoy's Avatar
_ , _
- Bart
I bet you are correct about the bad ground.
Old 11-15-2011, 11:39 PM   #6
1936 20' Clipper
1947 22' Liner
Curtis Wright
The gauges I used are made by "Marshall". I believe they're located out on the West Coast.
Old 11-16-2011, 08:02 PM   #7
alfalsetto's Avatar
1982 31' Airstream 310
Longview , Washington
Hay if you good people out there find some good cheap gauges out there. Place till me I have to replace mine
alfalsetto is offline   Reply With Quote
Old 11-16-2011, 08:31 PM   #8
dadstoy's Avatar
_ , _
Yup, gauges can get expensive and the cheap ones look cheap!
Old 11-16-2011, 08:46 PM   #9
alfalsetto's Avatar
Looks like I have to go big time. Looks like about $1,000.00 for all the gauges for my new dash!!
Old 11-16-2011, 10:03 PM   #10
dadstoy's Avatar
_ , _
Which ones are u looking at?
Old 11-16-2011, 11:48 PM   #11
Maniacal Engineer
barts's Avatar
I've put a couple of the Autometer stepper gages in the truck; wide sweep and very nicely built. Available in limited sweep as well for less money.
- Bart
Bart Smaalders
Lopez Island, WA
Old 11-16-2011, 11:54 PM   #12
dadstoy's Avatar
_ , _
- Bart
Hi Bart,
Do you remember which model of Auto Meter you used? Also do you know what is stepper motor gauges?
Dean
Old 11-17-2011, 12:03 PM   #13
alfalsetto's Avatar
I'm putting in a mew dash and all my gages going bad. The old ones look bad in the new dash
Old 11-17-2011, 12:21 PM   #14
dadstoy's Avatar
_ , _
Post some photos. I would love to see what you are doing!
Old 11-17-2011, 03:41 PM   #15
alfalsetto's Avatar
I have the dash apart, But I have more job to do. #1 make a table, #2 new door for my gen. #3 new rubber around my windows , thin by dash, ( just getting things in line for the dash
Old 11-17-2011, 05:18 PM   #16
Mike Leary's Avatar
1984 31' Airstream310
Ajo , Arizona
The wiring under the dash on our coaches is, to say the least, atrocious. I'm very carefull when pulling the dash for fear of doing more damage. Most of my gauges have been replaced with Isspro, but the grounding problem is a factory screw-up.
ISSPRO.com Your home for quality Gauges, Tachometers, Speedometers, and more!
Old 11-17-2011, 08:49 PM   #17
alfalsetto's Avatar
I see your going with the best gauges. All the gauges I put in trucks & bus in 50 years thay have been the beat!!
Old 11-17-2011, 11:24 PM   #18
Maniacal Engineer
barts's Avatar
Originally Posted by dadstoy View Post
Hi Bart,
Dean
Auto Meter (AutoMeter) Gauges from egauges.com
I used the GS series since they matched the truck's gage colors..
Bart Smaalders
Lopez Island, WA
Old 11-18-2011, 09:18 AM   #19
1988 32.5' Airstream 325
calgary , alberta
Good Morning , snow and -16 c so cold and windy, time to get some projects done! How do you fix the ground problem of the dash? Run another ground and where to attach it? Also would this cause wipers to Quit? Thanks Jonathan
jhenry is offline   Reply With Quote
Old 11-18-2011, 11:32 PM   #20
Maniacal Engineer
barts's Avatar
I've not worked on an Airstream dash, but... the ground connection is going to come from the cases of the light bulbs... typical color is green, but someone may have gotten creative.
Get a DVM and go exploring. A wiring schematic will help a lot; being methodical and deductive will make sorting this out straightforward if a little tedious.
- Bart
Bart Smaalders
Lopez Island, WA
Replacement issues wander'n Refrigerators 0 10-11-2011 06:25 PM
Land Yacht Dash Air DonaldW Land Yacht/Legacy Motorhomes 25 07-21-2011 07:48 PM
Replacement Fabric nynick52 Awnings 10 07-21-2011 06:01 PM
Dash exchange shepherd57 Argosy Motorhomes 3 07-18-2011 03:20 PM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 01:22 PM
