02-09-2020, 07:18 AM
#1881
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Originally Posted by bkahler
Nice....
Totally agree Brad
02-10-2020, 12:24 PM
#1882
_
, _
About 3.5 years ago when I put the MH in the storage lot for a couple years, along with not winterizing the plumbing, I left various items like shampoo, bug spray, sun screen, etc sitting under the bathroom sink.
Closed up in the summer I’m sure it gets to 125 degrees inside and these chemicals boiled over and ate up the plastic floor.
So finally I cleaned it up, sanded the plastic a bit and cut and put down a piece of aluminum. Finally got my toilet paper holder back!
I guess the lesson is if this stuff will eat up plastic maybe a good idea not to use it on the human body!
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
08-06-2020, 11:44 PM
#1883
_
, _
08-07-2020, 07:35 AM
#1884
Richmond
, Kentucky
Dean, I sense a trend here. Most of your posts include a sampling of wine......
Am I missing something
The hottest it's been here in central Kentucky this year that I've seen is 92 degrees. Overnight temps are in the low to mid 60s.
1975 24' Argosy Motor Home
08-07-2020, 08:43 AM
#1885
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
The heat doesn't appear to be a local trend...over 95 for the third day running in my part of the Uk, so we are officially in a 'heatwave'.
I have to say no wine is involved, but I have found one benefit of currently 'working from home', and that is a possibility of jumping in the pool during lunch-break to cool down!
08-07-2020, 10:40 PM
#1886
_
, _
It’s a trend! Here is tonight’s glamping bottle (compliments of my brother)...
08-24-2020, 10:21 PM
#1887
_
, _
We can't win for losing...
Ranch is under fire evacuation yet again. It's a "small" fire, only 33,000 acres (compared to multiple other fires in the state). It's about 8 miles south of the main compound and about 3 miles from the south "outback" property line. It's expanding more west at this time with northward progress slow. Pics are from better times at the south property line.
08-25-2020, 08:38 AM
#1888
Richmond
, Kentucky
Dean, one would have to think that eventually there will be nothing left to burn. Living here in Kentucky it's hard for me to fathom what conditions are like in your part of the country.
Good luck and take care.
08-27-2020, 07:58 AM
#1889
1982 31' Airstream 310
champaign
It’s getting to be every year it seems like, Colorado too. Take care Dean.
08-27-2020, 01:39 PM
#1890
_
, _
Actually some of the fires are not progressing at least on certain sides due to previous burn scars! Even at home, 250 miles south of the ranch, we are surrounded by fires, but at least today we can breath a bit...winds must have shifted last night.
08-27-2020, 01:41 PM
#1891
_
, _
Mike, I just saw a fire map of the western states, I'll include Colorado in that, and I'm shocked at the number of fires!
08-27-2020, 01:58 PM
#1892
_
, _
Need new curtains for salon windows
Well it looks like the north side of the fire has stalled due to weather, winds and dozer lines, so onto new projects...
I need to replace the large side blinds on both sides in the salon area. I don't know what to put there. The original blinds have been removed, they were shot. They were awesome, but I know there is nothing available like them. The sides of the blinds had sliding attachments which held them close to the curved wall.
I need some help with ideas!
08-27-2020, 03:39 PM
#1893
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
you mean the clips below?
I have an easy solution for you, well relatively easy if you are handy with wood or know someone.
Copy the system they started to use in the mid 80's to hold the blinds in place. You can use any kind of material, metal, flooring planks, hardwood.
The draw back is that you have to use rigid type of blinds, like I did in the 350 (2nd picture) or add a center slat like they did in the 4th picture.
The third picture shows it in my old 1987 345
The nice thing about this system is total privacy and darkness at night.
Edit: Looked at your picture again and all you would need is a piece wood or a metal rod hiding behind your curtain to hold the new blind back
AIR #13
08-27-2020, 09:18 PM
#1894
_
, _
Hey Peter, yup those are the clips. I still have the metal slides on the walls.
08-28-2020, 06:31 AM
#1895
Airstream Driver
1994 30' Excella
Austin
I once transferred the old clips to a new woven blind, worked well.
More pictures of someones "window boxes"
https://www.airforums.com/forums/f31...ml#post1996606
AIR #13
08-29-2020, 05:12 AM
#1896
1991 25' Airstream 250
Oxford
, Oxfordshire
Originally Posted by PeterH-Airstreamer
Peter - are those fabricated or the original factory Lambrequin Window Close outs which were used on the LE models? I have the factory close outs, but my blinds are pretty knackered and i'd like to upgrade them to blackout blinds which run in some kind of rail system within the close outs. The wooden ones rattle too much when driving down the road. I don't think i have any clips which might be why.. Looking for inspiration if you have any suggestions!
08-29-2020, 07:08 AM
#1897
Airstream Driver
1994 30' Excella
Austin
The clips were only used in the early Motorhome years (79-83) and I don't think they are any longer available.
As for Lambrequin Window close outs, I had to look the meaning up and it came back with: Lambrequin definition is - a scarf used to cover a knight's helmet.
Since thats not what we a dealing with, I assume you are talking about the window boxes used since 1985/86 and not only on LE models. They just made them a little fancier on the LE's with the golden mirror inserts.
When i replaced the old wooden blinds, I looked at many options. Looks, cost, functionality, quality, full blackout and noise were the factors.
Looks and cost: so many options and many way overpriced designer junk. Not going to spend $400 a window on some day/night stuff that will not last
Functionality, quality and full blackout: easy up and down, built to last and easy light control
Noise: Most quiet fabric covering were worthless junk. would be ruined by any moisture. Metal blinds were out because of noise, the wooden blinds I ended up using are very quiet for 2 reason, the type of slats used (privacy) and installing 1" foam on the inside of the wooden casing.
https://blinds.homedepot.com/Catalog...oductId=503439
I understand that is not everyones cup of tea, especially if you want to "modernize" your Airstream.
Then there all these options:
https://www.selectblinds.com/cellula...QaAhHvEALw_wcB
and the custom shades used in new Airstreams now (how boring!)
https://www.zarcor.com/rv_products/o...ades/index.php
AIR #13
08-29-2020, 09:10 PM
#1898
_
, _
Hey Peter, I think you just answered my question; fabric or wood. I have a wood blind on the rear bath window and I like it. Are your wood blinds 1" or 2"?
08-30-2020, 05:25 AM
#1899
Airstream Driver
1994 30' Excella
Austin
They are 2". Be aware of the Privacy selection on the HDepot weblink. Selection 2 Privacy slats require a "cased in" window, since the slats are just resting on the strings and are not attached. You may not want to use that system in your situation.
AIR #13
08-30-2020, 12:17 PM
#1900
Oxford
, Oxfordshire
Hi Peter,
Thanks for the useful info. In terms of the Lambrequin closeouts, it is a weird term. I always thought it was the Airstream term for the boxes you mention. The options file for my series of coaches has the following info:
$3,751 "LE". PACKAGE (FABRIC COVERED INTERIOR SKIN, RECESSED FLOURESCENT LIGHTING, SELECTIVE CORIAN TOPS, PLANKED OAK GALLEY FLOOR, INDOOR/OUTOOOR THERMOMETER; EXTERIOR . .
GRAPHICS, BEVELED. GLASS MIRRORS, LAMBREQUIN WINDOW CLOSEOUTS)
https://www.airstream.com/wp-content...e-list-465.pdf
The 250 options lists them too.The fabric covered skin is also referred to as Ozite.
