Old 01-11-2015, 06:10 PM   #1361
dadstoy's Avatar
_ , _
Originally Posted by blmitch5 View Post
Now Drive that beast to ARKANSAS!
4200 miles round trip equates to about $1500 in fuel...oh my! LOL. I would like to some day. My mother was born there.
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
dadstoy is offline   Reply With Quote
Old 01-11-2015, 06:30 PM   #1362
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Or with gas prices dropping and a shorter distance, you could join the classic Moho gathering in April in Colorado.
Still in the planning stages, check the classic get together thread.
Cheers Richard
tevake is offline   Reply With Quote
Old 01-11-2015, 08:08 PM   #1363
wxbuoy's Avatar
Wildwood , Florida
Send a message via Skype™ to wxbuoy
I will put $100 in the kitty if I get an hour of your design talents while you are there!
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 01-11-2015, 09:24 PM   #1364
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Originally Posted by wxbuoy View Post
In an airstream?? What are you trying to do, the impossible! I'm happy if mine even kicks on when I turn on the thermostat!
Huh, kinda reminds me of last year blowing snow out beside the coach in the dead of winter when I heard a humming noise coming from the coach. I had never heard that noise before so I unlocked the door to find the blower in the furnace blowing happily away.....We didn't have her plugged in and no one had been inside for months. Clicked off the thermostat and the blower stopped, clicked the thermostat again and on she came. Turned it off, shook my head and left.
Now she has no furnace inside her at all.
Cheers
Tony
Old 01-12-2015, 12:46 AM   #1365
2007 22' International CCD
My furnace behaves normally as long as I have power and propane....
Of course, since I'm an engineer and have assorted tools handy, it knows better than to misbehave 😄
Old 01-12-2015, 06:26 AM   #1366
Vycan's Avatar
1994 36' Classic 36 Diesel
Colorado Springs , Colorado
So is it abnormal to have a fully functioning furnace?
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 01-12-2015, 07:26 AM   #1367
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Cheers
Tony
Happen to me too, only mine was plugged in, found my problem, didn't realize the switch wasn't in the off position from previous trip months before. Now I know to check it before parking it
Wow, everybody is mentioning Co. in the spring while we are looking out at full bloom Azeleas here now, maybe they will have an early spring too.
Old 01-12-2015, 12:00 PM   #1368
dadstoy's Avatar
_ , _
It's a John Denver morning at the ranch
"Take me home, down country roads"
Name:	ImageUploadedByAirstream Forums1421089050.859720.jpg
ID:	230298Click image for larger version
Name:	ImageUploadedByAirstream Forums1421089104.391766.jpg
ID:	230299Click image for larger version
Name:	ImageUploadedByAirstream Forums1421089129.409827.jpg
ID:	230300Click image for larger version
Name:	ImageUploadedByAirstream Forums1421089158.319280.jpg
Old 01-28-2015, 06:24 PM   #1369
dadstoy's Avatar
_ , _
I used the cabinet making quality Delta table saw today that my brother gave me. I'm trying to finish up the table top for my enclosed trailer. The top is the cut out from the sink counter. The existing table top in the pic is from my AS. Wow, what a nice saw! Wish I had another AS coach project to work on!
ID:	231308   Click image for larger version
Old 01-28-2015, 06:32 PM   #1370
dadstoy's Avatar
_ , _
I spent multiple days cleaning out my "garage" or my trailer so I can move my ATVs in and out without moving crap out of the way. This also means that I need to do something with the aluminum panels from the bathroom sliding doors in the motorhome that I removed. What should I make out of this aluminum?
ID:	231310   Click image for larger version
Old 01-28-2015, 06:46 PM   #1371
dadstoy's Avatar
_ , _
Well, I must have jinxed myself with all that talk about my "working" furnace in the MH...it died on me again!
I knew I really didn't fix anything the last time I pulled the furnace. I'm taking an "educated" chance that it is the control board that is the culprit. Again, the fan does not come on. When I connect the fan directly to 12 volts, it works fine. When the fan is connected to the board it does not work. I have 12 volts at the fan connection without the fan connected. If I touch with my finger the fan connector with fan not connected, the voltage drops to 6-8 volts. With the fan connected to the fan connection on the board, the voltage drops to zero.
My new Dinosaur replacement board has arrived...just have to pull the furnace one more time!
Old 01-30-2015, 10:21 PM   #1372
dadstoy's Avatar
_ , _
I've had on my list now for a long time to flush the water heater and check the anode rod that I installed on 2/23/12. When I arrive at the mh this afternoon and before I hooked up the water, I pulled the old anode rod. Yup, time to replace it! I also flushed the water heater and it was pretty clean. Click image for larger version
Name:	ImageUploadedByAirstream Forums1422681660.559478.jpg
Old 02-03-2015, 07:26 PM   #1373
dadstoy's Avatar
_ , _
Name:	ImageUploadedByAirstream Forums1423016711.151445.jpg
ID:	231658I installed the new furnace control board! Nice to have heat again.
Old 02-05-2015, 11:15 PM   #1374
dadstoy's Avatar
_ , _
I was walking around the mh this morning checking things out before the big storm hits and it came to me where the rain water might be leaking in at the floor level at the rear of the mh.
Years ago my dad had the spare tire mount removed from the rear bumper. The AS dealer installed a new aluminum panel on the lower rear just behind and above the bumper. The top edge of this new panel was put over the bottom of the panel above it instead of behind this panel. No caulking was used as well.
Rain water would run down right to the plywood floor.
I installed a section of flashing behind this "new" panel then caulked between the upper old panel and the lower new panel. Hopefully I've stopped this leak but the damage over 20 years has taken its toll.
Name:	ImageUploadedByAirstream Forums1423203235.663831.jpg
ID:	231816Click image for larger version
Name:	ImageUploadedByAirstream Forums1423203261.162893.jpg
ID:	231817Click image for larger version
Name:	ImageUploadedByAirstream Forums1423203302.879708.jpg
Old 02-08-2015, 06:15 PM   #1375
dadstoy's Avatar
_ , _
Trip to Yosemite
Join us for part two of our Trip to Yosemite!
http://youtu.be/gQbq4EtCXJY
Old 02-08-2015, 07:18 PM   #1376
2003 19' Bambi
Forestville , California
That is an awesome video. I made that trip from Fresno 41 to the park and then out to 120. Great time of the year but I'm going back again this spring when there's water.
Mvaug45 is offline   Reply With Quote
Old 02-08-2015, 07:53 PM   #1377
dadstoy's Avatar
_ , _
The colors were awesome last November. We also try to go in April...before spring break that is!
Old 02-08-2015, 08:45 PM   #1378
2003 19' Bambi
Early May is a great time, hopefully we'll get more snow so we have the Falls. I grew up near Fresno and didn't go there until just a few years ago. I missed out. Have you gone over Tioga Pass to the Eastern Sierra's? Some really nice country over there.
Old 02-09-2015, 08:03 AM   #1379
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Loved the video, don't usually change setting on youtube but it was worth it for this one. Moved it to HD and slowed it down from rollercoaster ride at 'normal to .25.
Excellent slide show, Ansel Adams with color.
If you want a suggested improvement, get a black dash mat, my Honda Fit had reflection so bad at wrong sun angles making it impossible to see, made a sunscreen mat painted flat black placed on the dash and it was a great improvement.
thanks for sharing.
Old 02-09-2015, 01:29 PM   #1380
dadstoy's Avatar
_ , _
Yes, I've been over Tioga Pass a few times and over to the eastern side. I certainly agree its very beautiful over there.
I've even been over Tioga Pass in Dad's Toy back in '91 when my mom and dad owned the mh. We were going from Las Vegas to the Bay Area. I took this pic at a turn out up there at the top!
1982 airstream 280, 28', motorhome
Airstream toy trailer, furnished, 2002 edition, 11" eBay Watch Airstreams on eBay 0 01-18-2011 09:00 AM
'68 Overlander to Toy Hauler maxtime General Repair Forum 5 01-01-2011 08:32 AM
